Upgrade Leaf Springs gen 2
Discussion in 'Suspension' started by jham101, Aug 29, 2024.
  1. Aug 29, 2024 at 3:43 PM
    jham101
    jham101 [OP] New Member
    Hey
    I need to redo my rear leaf springs. My truck has about 200k on it. I did an add a leaf a few years back to level out
    With the front. I also have air bags
    Any suggestions on upgraded leaf springs I should add? I do some towing but not a ton. I do a lot of driving on dirt roads. Ideally I could upgrade the tow capacity while maintaining the raised height of about 2 inches. Thank for the help.
  2. Aug 29, 2024 at 4:01 PM
    Call Alcan Springs and ask for Lew.
  3. Aug 29, 2024 at 5:13 PM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    These would do it for you.
    https://exitoffroad.com/product/dobinsons-l59-120-r-rear-leaf-springs-pair-for-toyota-tundra/
  4. Aug 29, 2024 at 6:21 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    For the use you described, I'd go with the Icon RXT leaf pack. I've been happy with mine for similar use.
    If overland/ prerun'n I'd choose Alcan's or Deaver's.
    jham101[OP] likes this.
  5. Aug 30, 2024 at 5:55 PM
    mfelton18
    mfelton18 I'M THE PROBLEM
    South Central Texas
    2014 Magnetic grey SR5 4x4 crewmax
    Eibach Stage 2, RCI armor, Method 705
    Three decent options being thrown your way. The Alcan option is great if you want a custom spring pack. Will run you around 1k. The Dobinsons one is great if you're looking for 2.5" of lift in the rear. The Icon's provide some level of customization with the AAL and vary in height.
    It kinda all depends on what you want. I am in the same boat as you and have looked at A LOT of options. With your current 2" lift i would think the Dobinsons would be a good option for you. Add in some Sumo Springs and that might be smooth ride.
