Upgrade DC to CM center console for rear AC vents
Discussion in '2.5 Gen Tundras (2014-2021)' started by SprinterAE86, Jan 27, 2019.
  1. Jan 27, 2019 at 3:48 AM
    SprinterAE86
    SprinterAE86 [OP] New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Did anyone ever tried to replace their DC center console parts with CM console parts to fit the it with air ducts and vents for the rear? Or do you have to replace the whole console to achieve it?
    Thanks!
  2. Jan 27, 2019 at 6:17 AM
  3. Jan 27, 2019 at 7:22 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  4. Jan 27, 2019 at 7:29 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There are vents under the seats. Could those be routed to the cm console i wonder?
  5. Nov 29, 2019 at 1:01 PM
    Craigsk
    Craigsk New Member
    Craig
    2017 Red Tundra 4x4 DC
    I have a parts list somewhere of what's needed to do it. Looks like about 315 dollars or so. As near as I can tell the ductwork is molded already into the center console. You need to open up the ductwork at the front and make the connection there, then you need buy the rear face of the center console which has the openings for the vents, the vents themselves, and the bezel. Keep in mind you'll be losing the cup holders if you do that. While I haven't personally done it, I did do the research and it looks very easily doable.
  6. Nov 29, 2019 at 3:07 PM
    SprinterAE86
    Ian
    That will be great when you find it. It gets hot back there.
    619Tundra and Jim LE 1301 like this.
  7. Aug 24, 2020 at 11:37 AM
    OverlandHiker
    OverlandHiker New Member
    Bennett
    SF Bay Area, CA
    2019 Tundra Limited / TRD Off-Road
    Was the parts list you mentioned ever posted? If not, any suggestions on how I might assemble such a parts list myself? I haven't used the techinfo.toyota.com site before, but was thinking that it might be a good place to compare how the DC and CM A/C systems differ.
    Cheers
    -- Bennett
  8. Aug 24, 2020 at 12:00 PM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    I was wondering about this for my dog that rides back there. He runs hot sleeps on the AC vents at home .
  9. Aug 18, 2021 at 11:21 AM
    TRDFett
    TRDFett New Member
    PA
    21 Tundra Limited
    Was anyone ever able to successfully do this? Curious on the parts list and the difficulty involved.
  10. Aug 18, 2021 at 11:28 AM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
  11. Aug 18, 2021 at 11:30 AM
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
  12. Aug 23, 2021 at 5:52 PM
    TRDFett
    TRDFett New Member
    PA
    21 Tundra Limited
    Not looking good :(
  13. Nov 17, 2022 at 6:20 AM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    I know this is an older thread and I am a new member, but YES you can add rear A/C to the double cabs, I have done it.
    You need the center console with vents (obviously) and the factory air duct that runs from the dash to the center console ducts.
    The attachment point for the duct is there under the dash, you will need to cut the oval out of the bottom of the blower box.
    Once you get under there, you will see exactly what you need to cut. It is in an awkward location to cut, but the plastic is fairly soft.
    the factory duct part number is: 58861-0C030
    Sundog, TRDFett and texasrho83 like this.
  14. Nov 17, 2022 at 8:50 AM
    TRDFett
    TRDFett New Member
    PA
    21 Tundra Limited
    Thanks so much for that information! Great to know its possible and seems pretty straight forward.
  15. Nov 17, 2022 at 8:55 AM
    Slag_Dynamics
    Arizona
    Gone
    No problem! I was researching for myself and figured I’d just go for it after I saw no one had really confirmed it was possible. With a Dremel tool to cut the HVAC box and razor blade for the carpet, it’s done in a few minutes. All mounting holes are present in the floor as well.
    NewImprovedRon likes this.
  16. Nov 17, 2022 at 9:56 AM
    Johnnyquad
    Johnnyquad New Member
    21 Pro double cab MGM
    Tint, clear bra, OEM stereo upgrade, tonneau cover, line x, 285/65/18 Toyo AT3
    Do you have any pictures of the final result? Do you have the part list you will need. I'm pissed Toyota decided to save a few bucks and not install it in the back. My boys hate that they don't have vents in my truck.
  17. Nov 17, 2022 at 10:02 AM
    Slag_Dynamics
    Arizona
    Gone
    What you’ll need is the factory console with rear A/C vents, I got mine locally at an LKQ (https://www.lkqcorp.com/) and the part number I listed above for the ducting piece.
    Make sure you look at the LKQ photographs and verify the console they have listed has vents. Also, try to get one out of a vehicle with no broken glass to minimize damage from the elements and glass scratches.
    Shipping isn’t cheap, but I was able to pick mine up at the local warehouse.
  18. Nov 17, 2022 at 10:09 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I actually use my cup holders and the kids never complain about the air temp in the back :notsure:
    That being said, I can see the viability in this little project.
  19. Nov 17, 2022 at 10:11 AM
    Slag_Dynamics
    Arizona
    Gone
    I’m in Arizona, so I guess it just makes me feel a little less guilty having the kids in the back now that there is some airflow. Especially with a black truck.
  20. Nov 17, 2022 at 10:40 AM
    Rubberdown
    That’s one of the reasons I traded my double cab in for a crew cab. And THE main reason I got rid of the 4Runner. No functional rear ac vents is so dumb.
  21. Nov 17, 2022 at 11:01 AM
    Slag_Dynamics
    Arizona
    Gone
    Just for information:
    Average Used Console: $200-350
    58861-0C030: $50-75
    You’ll need (4) 10mm Head M6 Bolts in 1” length for the console, this is a typical Toyota size and if you’re like me, you may have some laying around.
    You’ll re-use the two body clips holding the original trim piece under the A/C Controls for the new console to mount to the same locations and you’ll need (1) additional identical body clip to affix the ducting to the floor.
    DoublePro likes this.
  22. Jul 5, 2023 at 6:02 PM
    I'm going to pull my console panels this weekend and look at the internal box. If the DC and the CM have the same box, it looks like all that is needed is the duct, bolts, and the rear panel that has the vents. This would eliminate swapping out the entire console assembly.
  23. Jul 5, 2023 at 6:19 PM
    Slag_Dynamics
    Arizona
    Gone
    I had a jump seat, so for me, the entire console needed to be swapped.
    Tundra234[QUOTED] likes this.
  24. Jul 5, 2023 at 6:37 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It is the same box
  25. Jul 5, 2023 at 6:40 PM
    Nice. So all I need is the duct and the center vent panel.
  26. Jul 5, 2023 at 6:43 PM
    I wonder why the part numbers are different.....
  27. Jul 5, 2023 at 6:44 PM
    Slag_Dynamics
    Arizona
    Gone
    Maybe one number for the console with the vents and one number for the one without?
    *Assuming those parts are sold as an assembly
  28. Jul 5, 2023 at 6:48 PM
    Sorry I meant for the internal body.
  29. Jul 5, 2023 at 6:53 PM
    Slag_Dynamics
    Arizona
    Gone
    Ah I see. They both look to have vents in the images too.
  30. Jul 5, 2023 at 6:55 PM
    Yes I noticed that too. Maybe I'll try to take a peek at work tomorrow since it's slow.
