Upgrade battery cables
Discussion in '2nd Gen Tundras (2007-2013)' started by RodC, Jun 3, 2020.
  1. Jun 3, 2020 at 3:01 PM
    RodC
    RodC [OP] New Member
    Rod
    2009 beige 4liter v6 double cab Tundra
    6inch lift, tires/wheels, installed usb chargers inside, led interior lights
    I am trying to upgrade my battery cables to a heavier gauge. I was looking for how many cables, lengths, and lug size that will fit my alternator and grounds.
    I checked the manual and I looked online but couldn’t find any info.
    I tried following the lines but there is heavy loom and a “nest” and cannot tell where the wires go once under the alternator.
  2. Jun 4, 2020 at 2:04 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    That wiring harness loom will wrap around the engine block and will plug into the starter, and unless you have small hands you will have to remove the heat shields out and possibly the starter out as well... I'm not saying don't do it, I'm saying you will have to do some work to get it all out....
  3. Jun 4, 2020 at 2:21 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    you need to look up the big 3/4 upgrade. i did it on my truck. here is some info...
    https://www.tundras.com/threads/big-3-4-wire-upgrade.10285/
    i didn't post much info when i did it to my truck but, there are a few pictures starting here.
    the cable from ce auto electric is the best i've ever used. i do not buy wire from anywhere else now.
    my only advice is to go slow and take your time. you will need to remove passenger front wheel to get access to the alternator. it is the worst part about the entire process. you will not need to pull the starter.
  4. Jun 4, 2020 at 2:40 PM
    blackdemon_tt
    Damn it Jim, got me looking at this too... LOL.. I've been researching some of this stuff to upgrade my car's wiring
    smslavin likes this.
  5. Apr 30, 2022 at 12:37 PM
    tbone75
    tbone75 New Member
    2007 White Tundra TRD
    Resurrecting old post, sorry. I ordered everything from "The big 3/4" upgrade post (nicely done), but I have an additional question. Actually, two. I ordered all 1/0 wiring and now I'm thinking I should send it back and get 2/0 in it's place (only 15.00 more)? Thoughts? Also, for those who have tackled this project how long did it take? My Tundy is my only vehicle an need to factor that in when planning. I was looking at an LActrical 300amp alternator on ebay ( https://www.amazon.com/dp/B07Z5FS6WV?_encoding=UTF8) I know it's no 600 DC alt but maybe it's better than stock. Any opinions would be much appreciated -Thanks!
    Oh also, I was thinking of doing the diode upgrade since I'm dropping in a ODYSSEY 31 battery, too.
    NueveTundra and Leo's first like this.
  6. Jan 8, 2023 at 12:21 PM
    mj7juice
    mj7juice New Member
    GA
    2013 Sequoia Platinum
    Did you end of getting the High Output LActrical alternator? Was thinking of upgrading if it’s good to go. I ordered 1/0 big “3” upgrade wiring.
    W3agle likes this.
  7. Jan 9, 2023 at 2:01 PM
    tbone75
    tbone75 New Member
    I did and it has been working flawlessly through 105 F summers and -20 F winter's. Look at doing the Big 4 NOT 3. Also, if using an AGM battery do yourself a favor and do the GM fuse/diode (I don't remember what it's refered to) Basically it steps the recharge voltage to 14ish so it fully charged the AGM.
    As far as the alternator I'd buy again no problem. Good luck
    W3agle and Leo's first like this.
  8. Jan 10, 2023 at 5:12 AM
    tbone75
    tbone75 New Member
    Finished product
  9. Jan 10, 2023 at 8:02 AM
    mj7juice
    mj7juice New Member
    GA
    That looks great!
    JCBerb likes this.
  10. Jan 11, 2023 at 9:36 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
  11. Jan 14, 2023 at 2:49 PM
    Truelifelover
    Truelifelover New Member
    2009 Toyota Tundra SR5
    2 inch lift Mevotech TTX outer tie rods Mevotech Supreme inner tie and next are the control arms
    What is the GM FUSE/DIODE and why?
  12. Jan 14, 2023 at 6:12 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    WVI and Truelifelover[QUOTED] like this.
  13. Jan 14, 2023 at 6:25 PM
    Truelifelover
  14. Jan 14, 2023 at 6:57 PM
    Dawoofles
    Dawoofles New Member
    Cheyenne, WY
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Stock battery tray?
