Updates
Discussion in '2.5 Gen Builds (2014-2021)' started by 2015TRSPROSD, Mar 1, 2016.
  1. Mar 1, 2016 at 7:45 PM
    2015TRSPROSD
    2015TRSPROSD [OP] 2015 Tundra TRD PRO
    2015 TRD PRO CREWMAX
    XPEL protective Film (XPEL.com) Whole vehicle Tundra stamped letter insert (black) TRD PRO bed stamp letter insert Punisher Hood Decal (Matte Black) Fender and side cladding (TrdSparks) Side steps (Iron Cross- Linex coating) Retrax Pro Bed tonneau cover (Black) Punisher skull hitch cover (color matched custom paint) Michelin Defender LTX MS 295/70/18 Toyota Tundra 14-15 LED Taillights - Dark Red Smoked Lens Opt7 Headlights (bright as the sun pure white light) Tundra center console decider TRD Cold Air Intake Stubby antenna Weather Tech all weather mats TRD Brake pads Titanium exhaust wrap (covers exhaust pipes) Painted Engine Cover (Color Matched) Optima battery Billet Aluminum Optima Battery cover (Skull design-Optimatrays.com) TRD Sway Bar Kit Headlight Revolution (Gen 2 fog lights) Headlight Revolution Stealth light bar Color stable window tint Door sill protective trim Drivers side Grip Assist Hamdle add on LED bulbs inside & outside placements Focal front speakers and tweeters Kicker rear speakers JL stealth box subwoofers Kicker 4 channel amp Kicker mono amp Rebadged Whole
    image.jpg image.jpg image.jpg image.jpg image.jpg Update side steps, larger tires 295/70/18, changed badging. Took lighter color skull hitch cover and matched body paint code.
    driverdog and MotoTundra like this.
  2. Mar 1, 2016 at 8:24 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Looks great! How do you like the Iron Cross HD steps? I bought a pair but I'm waiting for spring to put them on, can't wait.
  3. Mar 1, 2016 at 8:29 PM
    2015TRSPROSD
    Really like them making apointment to have the Linex prayed with Bed liner for durability and traction including the stainless steps.
    MotoTundra likes this.
  4. Mar 1, 2016 at 8:58 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    My truck is all black, I was considering having just the polished aluminum step plates Line-X'd if the price isn't too bad. Either that or powdercoated, which I'm sure would need to be redone every few years...
  5. Mar 2, 2016 at 3:50 AM
    2015TRSPROSD
    I can have the whole setup Linex for 200.00. Powder coating the steps should be under a hundred. You can buy home owner coat kit for about 100.00 and do tons of parts yourself.
  6. Mar 2, 2016 at 5:19 AM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    I have the same Iron Cross steps. I bought them because the step is very useful getting in and out. If your truck is lifted then you have a tendency to slide in or out on the edge of the seat which will put extra wear and tear on it. These steps are more useable then most and I use them every time getting in or out and don't even touch the edge of the seat. I also installed the drivers side door pillar handle which is just as useful getting in and out.
    These bolt right up using the existing mounting holes. They literally only take 10 minutes a side to put on, very easy.
    MotoTundra[QUOTED] likes this.
  7. Mar 2, 2016 at 7:37 AM
    2015TRSPROSD
    Great info. Was upset about missing driver side grab bar. Maybe ordering a trim piece to correct That.
  8. Mar 4, 2016 at 7:09 PM
    2015TRSPROSD
    Added
    Grip bar
    Linex'ed the iron cross steps
    NewImprovedRon likes this.
  9. Mar 9, 2016 at 9:07 PM
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    Nice looking truck.
  10. Mar 11, 2016 at 4:58 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    The best lookin orange pickup I've ever seen.
  11. Mar 20, 2016 at 9:35 AM
    N3tho
    N3tho New Member
    2014 TRD SR5 CM SUPER WHITE
    Nice truck man! How is it going with the 295s any rubbing problems?
