Updated with Coach Shackles review
Discussion in 'General Tundra Discussion' started by Tracker, Mar 28, 2016.
  1. Mar 28, 2016 at 5:07 PM
    Tracker
    Tracker [OP] New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    So this job has sucked. They didnt give any directions so I have just been using common sense. I do have mechanical skills and am by far from a novice. However I cant get the alignment knob on the springs to fall into place. I have jacked the truck every which way and it just wont allign. Any help would be great. I have 2 hours into this one stupid step alone.
  2. Mar 28, 2016 at 5:09 PM
    Have you checked Youtube? I know he had a few videos out there.
  3. Mar 28, 2016 at 5:33 PM
    Cubanchem
    Cubanchem New Member
    Pedro
    Washington, DC
    TBD
  4. Mar 28, 2016 at 7:25 PM
    Tracker
    Shane
    Nice find, I should have searched it earlier. I finally got the springs to align. I have to kick the crap out of the tire to push the axle forward. 7 hour job and I got one shackle done :( tomorrow should go smoother since now I know the best jack spots and what to avoid. Plus I dont have to get up 400 times for to grab another tool.
    geno0506 likes this.
  5. Mar 28, 2016 at 7:29 PM
    Tracker
    Shane
    When I read before someone said you can leave the rear tires on. It appears that was the root of ALL of my problems.
  6. Mar 28, 2016 at 7:38 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yea def take the tires off. Won't pull the axle down so much. Lift by axle, remove tires, add jack stand to frame and remove jack from axle. Let axle droop.
    geno0506 and Black Wolf like this.
  7. Mar 28, 2016 at 7:38 PM
    DBL TAP
    DBL TAP Light 'em up
    USA
    Did you replace the factory bushings with CB poly bushings?
  8. Mar 28, 2016 at 7:40 PM
    Tracker
    Shane
  9. Mar 28, 2016 at 7:57 PM
    DBL TAP
    USA
    Thanks. Hope the other side is a cakewalk.
  10. Mar 28, 2016 at 10:55 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    That's strange... I must have had it in just the right place, because I didn't have this trouble. Let me ask, did you loosen the rear shocks?
  11. Mar 29, 2016 at 10:22 AM
    Tracker
    Shane
    Anyone know what these are for?
  12. Mar 29, 2016 at 2:44 PM
    TruckyTruck
    Gary
    They are to drop your carrier bearing. It keeps you from getting drive line vibrations. Definitely install them.
  13. Mar 29, 2016 at 2:45 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    Looks like a carrier bearing spacer to me.
  14. Mar 29, 2016 at 2:45 PM
    TruckyTruck
    Gary
    Did you get the shackles installed?
  15. Mar 29, 2016 at 3:04 PM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
    Black Wolf likes this.
  16. Mar 29, 2016 at 5:43 PM
    Tracker
    Shane
    Its all installed, took about an hour for the second shackle and that included starting fresh with the truck outside.
  17. Mar 29, 2016 at 5:51 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    So where's the pics?
  18. Mar 29, 2016 at 5:55 PM
    Tracker
    Shane
    Its pouring rain :(
  19. Mar 29, 2016 at 6:22 PM
    Not to mention lightening too. My big brave husky is hiding behind the couch.
  20. Mar 29, 2016 at 6:27 PM
    Tracker
    Shane
    Snow is upon us!
  21. Mar 29, 2016 at 6:31 PM
    It's only snow . Get out your creeper, mag lite and take some pics. while I'm watching NCIS. heh heh
  22. Mar 29, 2016 at 6:39 PM
    It'll be short lived. 80* next week lol
  23. Mar 29, 2016 at 7:15 PM
    Tracker
    Shane
    LOL, you know thats tempting
  24. Mar 30, 2016 at 1:41 PM
    Tracker
    Shane
    These spacers really helped straighten the driveline out. Im glad they were included.
    the old shackles
  25. Mar 30, 2016 at 1:46 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    nice... now is the bed bounce gone???
  26. Mar 30, 2016 at 1:48 PM
    Tracker
    Shane
    I tried to drive it but the highway was bogged down when I went out. I will get an update when I come home tonight.
  27. Mar 30, 2016 at 2:12 PM
    TruckyTruck
    Gary
    If your suspension flattens out, the nut on the bottom of your shackle could come in contact with your truck metal. I'm pretty sure I put the nut end to the inside because of that.
  28. Mar 30, 2016 at 3:52 PM
    Tracker
    Shane
    Wow thanks for the input, I will monitor it, hopefully since its a 2+ it won't be an issue.
  29. Mar 30, 2016 at 4:23 PM
    DBL TAP
    USA
    Did you check how much actual lift you got out of the +2 kit? Measure before and after?
  30. Mar 30, 2016 at 5:17 PM
    Tracker
    Shane
    I had a procomp 1" spacer already in . the 2+ added .25 after the swap, not noticeable which is what I wanted. So 1.25" of lift.
    DBL TAP[QUOTED] likes this.
