Update Suspension
Discussion in '1st Gen Tundras (2000-2006)' started by El Duche, Oct 3, 2019.
  1. Oct 3, 2019 at 8:49 AM
    El Duche
    El Duche [OP] New Member
    Seller has all suspension from 03 tundra in garage since purchase of vehicle. Wants $50. Wise addition to an 02 tundra with 164k?
  2. Oct 3, 2019 at 8:53 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    So he’s got basically unused original suspension?
    If you’re budget is really tight I would say go for it.
    If you’re willing to spend a little more I would just go aftermarket and improve your ride.
    edit: also, welcome!!
    Tundyfundy and 15whtrd like this.
  3. Oct 3, 2019 at 9:10 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    16 yr old shocks? Is he giving you $50 to take it away? Rubber seals don't last forever, I wouldn't buy it.
  4. Oct 3, 2019 at 9:25 AM
    15whtrd
    15whtrd Mr. Blonde
    Good point. Although for 50 bucks if it includes the leaf springs and a arms it might be worth it. He could upgrade the a arms bushings and leaf eyelet to polyurethane before he even takes his truck apart so it would just be a quick direct swap. Just thinking outside the box LOL
    831Tun[QUOTED] likes this.
  5. Oct 3, 2019 at 11:29 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Agreed. Leaf pack alone is probably worth it. Thing with 16 yr old shocks, either you pay or install yourself and 2 weeks later the seals fail and you're doing/paying twice.
    15whtrd[QUOTED] and joonbug like this.
  6. Oct 3, 2019 at 11:37 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Depends on a few things:
    What are the parts? Used original? How much mileage? Aftermarket? Gotta know more to answer.
    If it's used parts with low miles could be a good pickup. The post about "for a little more" is a little misleading. A pair of OEM ball joints alone is over $200 new. Arms bushings and all else you'll hit a thousand in no time, I know because I just did this in December.
    15whtrd likes this.
  7. Oct 3, 2019 at 12:25 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I would use the springs but not the shocks.
    because_wumbo-truck and 15whtrd like this.
