UPDATE *questions answered* Has anyone installed a Passive keyless entry? I have some questions
Discussion in 'General Tundra Discussion' started by Beau, Dec 28, 2019.
  1. Dec 28, 2019 at 3:09 PM
    Beau
    Beau [OP] De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    Hey everyone, those that have seen my build thread know that I am trying to modernize my 2008 Sequoia. One of the next upgrades I am looking at is a PKE from Easyguard. Has anyone successfully installed one of these units? Any thoughts? Some more specific questions also:
    1. When walking away and the hatch is closing or a door isn’t shut yet, will it lock the truck or just ring (the sound when a door is left open and you try to lock it). If the latter, will it attempt to re-lock again once the opposing door is secure?
    2. When approaching and the unit unlocks, do the puddle lights (lights under mirrors) come on like when you unlock it with the factory remote? If not, do they come on if you press the unlock button on the remote?
    3. Does the auto locking/unlocking activate/deactivate the factory alarm which beeps when locked/unlocked?
    Basically, these questions have to do with the level of integration of the PKE to the factory remote. I'm hoping that the PKE retains all of the factory alarm features. Thanks in advance for your input!
  2. Dec 31, 2019 at 4:56 AM
    davids_1718
    davids_1718 New Member
    2014 blizzard pearl platinum sequoia
    Alpharex nova gen 2 headlight Diode Dynamic ss3 pro fogs Dasaita head unit Blacked out interior silver panels Color matched rain visors, bug shield and oem fender flares AFE cold air Dirty Deeds 8" catback system
    good day just seen your post, i have a similar model made by cardot. i also am curious as to the install. i just wanted to know how you made out if you made the purchase and had it installed.
  3. Dec 31, 2019 at 6:04 AM
    Beau
    Beau
    I haven't installed it yet, still awaiting it's arrival from china:). I'll keep you posted.
  4. Jan 7, 2020 at 5:28 PM
    Beau
    Beau
    I was able to install this today! Came out great. Pics attached.
    Here are the answers to my original questions.
    1. When walking away and the hatch is closing or a door isn’t shut yet, will it lock the truck or just ring (the sound when a door is left open and you try to lock it). If the latter, will it attempt to re-lock again once the opposing door is secure? It will attempt to lock and will sound the horn notifying you of an open door. If that door is then closed (say, by your child) the system will attempt to lock again after a set interval. Seems to work pretty good.
    2. When approaching and the unit unlocks, do the puddle lights (lights under mirrors) come on like when you unlock it with the factory remote? If not, do they come on if you press the unlock button on the remote? No puddle lights, but the dome lights come on....next you, wiring the puddle lights to the dome light:)
    3. Does the auto locking/unlocking activate/deactivate the factory alarm which beeps when locked/unlocked? Yes
  5. Jan 7, 2020 at 5:41 PM
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    How was the install?
    do you know if this would work in concert with fortin remote start?
  6. Jan 7, 2020 at 5:53 PM
    Beau
    Beau
    I'm not sure if it would work with the fortin since mine is stock. Here is a great writeup done by a member on tundrasolutions HERE. The install was pretty straight forward and the outcome is MUCH better than I anticipated! It feels and looks OEM.
  7. Jan 7, 2020 at 7:01 PM
    egibson606
    egibson606 New Member
    Eric
    Georgetown, ky
    2019 super white SR5 tundra
    Okay, who's trying this on a tundra?
  8. Jan 7, 2020 at 7:22 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Wow very cool, and reasonably priced. Couple questions out of pure curiosity:
    What did you do about the tumbler in the steering column? Just leave it?
    How does it unlock the steering wheel?
    I see you placed the button where the coin tray was, good spot. Does it look easy to place on any flat surface?
    If new Sequoias are keyless, maybe the blank steering column shroud will fit?
  9. Jan 7, 2020 at 7:31 PM
    Beau
    Beau
    What did you do about the tumbler in the steering column? Just leave it? I left it since I tapped in to each ignition wire as opposed to disconnecting them...this way I can still use the key (I'm not "confident" enough in the system given it's price:)
    How does it unlock the steering wheel? Right now I just have the master key in the ignition and it turned to off, this bypasses both the steering lock and the immobilizer. I was literally just scouring the inter webs to figure out how to disable the steering lock permanently. ANY INPUT? I will be installing an immobilizer bypass as well.
    I see you placed the button where the coin tray was, good spot. Does it look easy to place on any flat surface? Not really with this particular key, it was really made to cover the key hole. They do have other push button models that are made for flush install on any panel. I liked this area because it looks very OEM since it fits the hole so well.
    If new Sequoias are keyless, maybe the blank steering column shroud will fit? I thought the same thing, but have yet to see if they start with a key (along with the push button) or not.
  10. Jan 7, 2020 at 7:42 PM
    HappyGilmore
    Trent
    Lakewood CA
    Ah I see. I looked at your link which I should have done first haha. Gave me some visuals and info to some of those questions.
    So basically if you tape the master key to the immobilizer ring, disconnect the wires instead of tap into them, and put in the cut off key it will keep the column unlocked and let the PKE system control it completely? I dont have any input on how to disable it. There's gotta be a way to remove whatever mechanism prevents it from spinning. Or see if a 2020 Tundra mechanism bolts up and electronically locks and unlocks it.
  11. Jan 7, 2020 at 7:54 PM
    Beau
    Beau
    Yes, this is the only feasible option attempted thus far but really works great. My goal is to wire in a bypass that only works when you have the key fob and also disable the steering lock.
    In reality, I'll probably just test the system out for a week or so (should be confident by then) with the key in the ignition, disable the keyed ignition, leave a cut key in the cylinder, and put a plug over all of it.
  12. Jan 7, 2020 at 7:59 PM
    HappyGilmore
    Trent
    Lakewood CA
    Yeah sounds like a good plan. At least you'll know where to start trouble shooting if it wont start, since you installed it yourself.
  13. Jan 7, 2020 at 8:04 PM
    Beau
    Beau
    That is exactly why I like doing my own work although I don't think it will mess up. I'm quite pleased with the quality. The buttons on the fob are engraved aluminum and all the wiring/sensors seemed pretty well built.
    HappyGilmore[QUOTED] likes this.
  14. Jan 7, 2020 at 8:39 PM
    Sunnier
    Sunny
    San Diego, CA
    I appreciate that you updated your thread title to indicate you found what you were looking for— should help others with future searches. You rock! :proposetoast:
    Tundratoofun and KarmaKannon like this.
  15. Jan 8, 2020 at 5:35 AM
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    The description from Amazon says this includes Remote start. which makes complete sense since it has its own keyfobs, and access to ignition control.
    Going to give this a whack on my 3rd gen. Going to add a immobilizer bypass module too.
    HappyGilmore likes this.
  16. Jan 8, 2020 at 6:34 AM
    Beau
    Beau
    I think the 3rd gen Tundra will be similar, if not the same, wiring and the attached guide was VERY helpful! There are a lot of wires under the dash to contend with if you unsure which ones to use:). I used T-taps to connect each wire and they seemed to do the trick. Good luck, you will be happy in the end!
  17. Jan 8, 2020 at 7:55 AM
    prerunnerseth
    Apex, NC
    I bought a spare fortin harness that I will modify as it has most if not all the connections to make this work without having to cut or tap into factory wiring.
  18. Jan 8, 2020 at 12:45 PM
    Beau
    Beau
    Wow, really? I wish that I had that harness yesterday:)
  19. Jan 8, 2020 at 6:07 PM
    erkme73
    erkme73 New Member
    Thanks for the link @Beau - I'm glad to see the level of interest in this PKE install. I've done it to both my 2007 Tundra and my 2011 Sequoia, the latter of which I used to do the write up. It works so well, that I'm seriously considering doing it on wife's 2019 Highlander - which already has factory PKE and remote-start. This system is just so much better. Far better range, and the remote start stays running when you get in - you just drive off.
    That said, as I pointed out in the write-up, unless you manage to use an immobilizer by-pass module, you're effectively rendering the factory immobilizer useless. That didn't matter to me because of where I live (I'm in BFE), but other users on the other forum raised legitimate objections to the bypass. I don't know if it's true that your insurer won't pay for a stolen vehicle if they find out you defeated the immobilizer (I actually doubt that) but, it is something that does need to factor into your risk/reward calculus.
    I've had mine in the Tundra for over a year now, and have had zero problems. The Sequoia I did back in late September of last year. I did have a problem (self-inflicted) where the spare key I had tied to the immobilizer antenna came loose. It didn't fall out, but it was just far enough from the antenna that I had extended crank times and ultimately a few instances where I couldn't get it started. I panicked thinking I had an issue with fuel/ethanol calibration issues (something common to the flex engines), but ultimately I figured out it was the key. Once I lined it back up again, it's been rock solid ever since.
    BTW, probably the most under-rated benefit of this system is the keypad that you can put on the windshield. It lets you push buttons (through the glass) to disarm the factory alarm, unlock the doors, and even enable the push-to-start button. Basically you can get full functionality of your vehicle WITHOUT A KEY/FOB. This is great when you're running late and can't find your keys. Or if you're outside and need to grab something from your car, but keys are in the house. Punch in your code, and you're in the car and on your way.
    Wynnded and Beau[OP] like this.
  20. Jan 8, 2020 at 6:12 PM
    Beau
    Beau
    Hey everyone, all the props of this install go to @erkme73! His writeup on tundrasolutions and his answers to all of my nagging questions were the difference of a successful vs failed install.
    erkme73[QUOTED] likes this.
  21. Jan 8, 2020 at 6:32 PM
    Beau
    Beau
    If you don't mind, maybe you can start a new thread about the PKE, introducing it to the forum members and telling them your experience. The title of this thread leaves a lot to be desired.
  22. Jan 8, 2020 at 6:39 PM
    prerunnerseth
    Apex, NC
    I'll be using a bypass module when I install. I'll keep you guys up to date on how that goes. The bypass needs a negative switch to activate but doesnt seem like the PKE has one for this purpose. I will have to investigate other wise I plan to use a relay that will activate the bypass module when the starter gets power.
  23. Jan 8, 2020 at 6:41 PM
    Beau
    Beau
    I haven't gotten that far yet, but the PKE does come with a 3 wire plug that I believe is for the bypass. Easyguard sells a bypass too, so I would think that it is set up for one...
  24. Jan 8, 2020 at 6:42 PM
    erkme73
    erkme73 New Member
    That would be a great addition to the write up. Admittedly, it's far from ideal - hence the glaring warning on the first page. It'd be nice to have a part list and description of how to do it the right way.
  25. Jan 8, 2020 at 6:44 PM
    Beau
    Beau
    I'll send Eddy, "OUR" buddy, a message and see if he can offer insight.
  26. Jan 8, 2020 at 6:44 PM
    erkme73
    erkme73 New Member
    Eh, you sound way more enthusiastic about it than I do ;) Go right ahead and do it. I need no credit. My problem is I've done it long enough ago that memory has faded on many of the critical points. You'll be a much better expert since you just recently did it. Once we know which immobilizer bypass works with it, and how to hook it up, I'll be happy to send the Word document to whoever wants to add/modify it to include the specifics.
    BTW, the link you had for the EC002 is slightly different than the kit I used (and wrote about). I bought the EC002-NS. It's $5 more, but the antennas and key fob look a little different. Sounds like the install was identical though...
    https://www.amazon.com/EASYGUARD-EC002-NS-Passive-Keyless-Password/dp/B00MBKVWJU
  27. Jan 8, 2020 at 6:52 PM
    Beau
    Beau
    In that case, this thread will serve the purpose of informing others and I'll update it on the feedback I receive from the manufacturer:).
  28. Jan 9, 2020 at 8:01 AM
    prerunnerseth
    Apex, NC
    My unit came in. I plan to buy the small panel where the pushbutton goes on a 2020 and the steering column covers to make this as factory looking as possible. Waiting on my bypass module to install.
  29. Jan 9, 2020 at 8:14 AM
    Beau
    Beau
    Did you figure out if the 2020 parts will work? If so, do you have part numbers?
  30. Jan 9, 2020 at 10:31 AM
    prerunnerseth
    Apex, NC
    My bypass module will come in tomorrow so I might find time to install this weekend.
