Up $h** creek right now, trans cooler install failure
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sciosh98, Apr 7, 2024.
  1. Apr 7, 2024 at 3:58 PM
    Sciosh98
    Sciosh98 [OP] ¯\_(ツ)_/¯
    Stephen
    Tennessee
    2020 Black Tundra 1794 TRD
    Today I finally got around to installing my trans cooler that I bought a couple years ago. I’m mounting the cooler now, top bolt in the horn location went fine, bottom bolt in the factory threaded location sheered off while I was wrenching it on… now I’m up a creek. Gotta get this install done tonight as I’ve got work in the morning and need my truck. Is the best course of action to remove my lower grill assembly, drill out the bolt, and use one of my own bolts and nuts to attach the bottom of the cooler? Anyone have this or something similar happen to them? The provided bolt felt too tight, but began threading normally and it was the one designated for this location.
    edit: this is the genuine cooling systems kit and just for the record, no power tools were used in the initial boogering of the bolt at hand.
  2. Apr 7, 2024 at 4:06 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Yeah I would probably remove the grill assembly and get the bolt out. If you have a bolt and nut to thread through, I would do that.
  3. Apr 7, 2024 at 4:08 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm lost. The world goes with GCS, what brand is this?
    Regarding the bottom bolt that sheered, against what? Itself or a hidden welded nut? I'm just lost.
  4. Apr 7, 2024 at 4:09 PM
    Sciosh98
    Stephen
    Tennessee
    Hidden welded nut. This is the genuine cooling systems kit with an MHX-514 cooler. Sorry, should’ve stated that.
    bflooks likes this.
  5. Apr 7, 2024 at 4:11 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Remove, drill, replace. It's newly installed, so shouldn't be hard. An easy out/screw extractor would be helpful.
  6. Apr 7, 2024 at 4:17 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    May not exactly help your situation. But this is what I used to get that bolt in, went in through the lower part of front bumper, direct shot to the bolt.
    Terndrerrr and bflooks like this.
  7. Apr 7, 2024 at 4:21 PM
    Sciosh98
    Stephen
    Tennessee
    I wonder if I can do that and not remove my bumper with an extractor to get it out now… it was so rough going in, I doubt I can extract.
  8. Apr 7, 2024 at 4:46 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    If you can get a straight shot to it and drill a small hole through, you can then take a small screw with a washer to work as a temporary fix until you get more time. That bracket doesn't look weight bearing as much as just securing it from flapping around. Then work on getting the tools you need for a proper bumper removal (not difficult) and extraction/re-tap and new bolt.
  9. Apr 7, 2024 at 5:39 PM
    Ericsopa
    Ericsopa Old man and the sea
    A large zip tie wrapped around the bracket and the radiator bracket behind it, holding it tight to the frame, should hold it fine till you can get back to it. As Toyotoholic said, it doesn't appear to be weight bearing at all. Hell, if you don't have zip tie handy, tie it with a shoe lace.
  10. Apr 7, 2024 at 6:06 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Probably different thread pitches. I don’t like using impacts unless I’ve started the bolt by hand.
    bflooks and texasrho83 like this.
  11. Apr 7, 2024 at 6:08 PM
    Sciosh98
    Stephen
    Tennessee
    I couldn’t reach it with my drill so I sheered that sucker with my wrench haha
  12. Apr 7, 2024 at 6:25 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This.
  13. Apr 7, 2024 at 6:32 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I have a handful of emergency stainless steel zipties for just the structural occasion!
  14. Apr 7, 2024 at 7:45 PM
    Sciosh98
    Stephen
    Tennessee
    Ran to Home Depot. This bolt is not fazed by the easy-out in the slightest. Moved to just trying to drill through it with my hammer drill… it’s still not amused… IMG_3177.jpg
    But I was smart enough to stick a piece of wood between the drill and the radiator in the event that I succeed.
  15. Apr 7, 2024 at 7:54 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    If that was mine, I would forget about that boogered up hole and just move the mounting bracket slightly to the left, drill a new hole, and secure it with a new nut, bolt, and locking washer.
  16. Apr 7, 2024 at 7:57 PM
    Mr Badwrench
    Mr Badwrench New Member
    As others have said, get it drivable for work tomorrow and tackle it another time when you're not as pressured. Probably not the answer you want right now, but take 5 and come back to it when there isn't as much urgency.
    If your transmission was destroyed, that would be a problem. This is an inconvenience, don't turn it into a problem.
  17. Apr 7, 2024 at 7:59 PM
    Sciosh98
    Stephen
    Tennessee
    I was considering that, but was unsure if there would be any negative effect on the cooler if it wasn’t straight up and down.
  18. Apr 7, 2024 at 8:04 PM
    TILLY
    Massachusetts
    Just move the bottom bracket, not the entire cooler which will still be level and it doesn't effect anything.
  19. Apr 7, 2024 at 8:13 PM
    Sciosh98
    Stephen
    Tennessee
    It’s a single piece bracket that holds the cooler
  20. Apr 7, 2024 at 8:16 PM
    TILLY
    Massachusetts
    My bad, thought the lower piece was separate.
  21. Apr 7, 2024 at 8:32 PM
    TILLY
    Massachusetts
    Since the bracket is one piece, still seems like you have plenty of room to drill an additional hole on either side to secure it. Good luck. :thumbsup:
  22. Apr 7, 2024 at 8:36 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Secure it with zip ties, shoe laces, or Gorilla Tape tonight so it’s drivable for work in the morning.
    Sleep on it, and contemplate a solution or the tools you need to un-bugger it tomorrow. Then proceed with a plan.
    Suggest you make it to next weekend, take off all the stuff in the way so you have room to work, and then do it correctly taking your time. Hit it with some zink primer and some Krylon to mask the damage and seal against rust once you get the hole cleaned up.
    Take a breather.
  23. Apr 7, 2024 at 9:09 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    This.
    sometimes the best thing you can do is walk away before you FUBAR it. Come back with some sleep and a clean fresh mind to attack the problem.
  24. Apr 8, 2024 at 6:26 AM
    Chip_Tundra
    Chip_Tundra New Member
    This is a cake walk for an easy out. Don't rush the extraction. Next time, thread the screw in by hand before the 1 ugga lol.
    If you have a tap and die kit, rethread the hole and you should be good.
    ZappBrannigan likes this.
  25. Apr 8, 2024 at 8:15 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I believe those are ss bolts, very hard.
    Sciosh98[OP] likes this.
  26. Apr 8, 2024 at 9:29 AM
    Sciosh98
    Stephen
    Tennessee
    The poor easy-out didn’t hardly make a scratch in the broken bolt. I ended up burning through a couple titanium bits with a hammer drill just to make the atrocious 1mm divot in the picture above.
  27. Apr 8, 2024 at 9:37 AM
    MedCityMoto
    Drop a tack of weld on it? Then it's someone else's problem in 20 years!
  28. Apr 8, 2024 at 10:15 AM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    If it's not cross threaded then weld a nut to it and it will come right out. Do it all the time with broken exhaust manifold bolts it cylinder heads.
  29. Apr 8, 2024 at 12:58 PM
    Sciosh98
    Stephen
    Tennessee
    The only thing I can think went wrong is that the bolt was pre-coated in loctite and the welded-on threads on the truck were probably pretty rusty after sitting for a few years empty (it looked rusty before I started, should’ve hit it with pb blaster). I got like 75% of the way threaded in before it broke, so I’ll be impressed if anything could get it back out.
  30. Apr 8, 2024 at 9:02 PM
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    let us know if / how you end up fixing this?
