Unplugged ecm and now it wont start
Discussion in '2.5 Gen Tundras (2014-2021)' started by 904Tundra4x4, May 1, 2021.
  1. May 1, 2021 at 11:13 AM
    904Tundra4x4
    904Tundra4x4 [OP] New Member
    alex
    2018 tundra SR5
    I unplugged my ecm and after about 10 minutes my radiator fan came on so i plugged it back in. Now the truck wont start. Any ideas?
  2. May 1, 2021 at 11:18 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Unhook the negative terminal on your battery for 10-15 mins. Hook it back up and give it a go.
    Saltyhero13 and 15whtrd like this.
  3. May 1, 2021 at 2:38 PM
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    Wut.. did you this with power on? And why
  4. May 1, 2021 at 2:41 PM
  5. May 1, 2021 at 3:06 PM
    904Tundra4x4
    alex
    2018 tundra SR5
    I forgot to unhook the battery. I did disconnect afterwards for almost 3 hours and still not turning over. Could this possibly have fried the starter
  6. May 1, 2021 at 3:09 PM
    Curious. What was initial reasoning to disconnect the ECU?
  7. May 1, 2021 at 3:12 PM
    904Tundra4x4
    alex
    2018 tundra SR5
    I was mounting a shelf for a compressor that my buddy made and it was going over the top of it. It was having clearance issues and i unplugged it before realizing i didnt unhook the battery
    Black Wolf likes this.
  8. May 1, 2021 at 6:02 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    Have you checked all your fuses?
  9. May 1, 2021 at 6:19 PM
    904Tundra4x4
    alex
    2018 tundra SR5
    Yea both fuse boxes were good
  10. May 1, 2021 at 6:29 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Did you add an electric cooling fan to your Tundra? I’m having trouble understanding how a belt driven fan came on after ten minutes if the engine won’t start.
    With the battery disconnected, check for any bent pins on the ECM / damage to the connector and then make sure it’s fully locked together. Reconnect the battery, and try it again.
    nixon, JimboSlice413, 15whtrd and 2 others like this.
  11. May 1, 2021 at 6:34 PM
    ejes
    ejes New Member
    Do the dash lights all come on? If so, it could be the ECU lost the immobilizer key codes.
    I agree with Phil. X2 and X3 check all your connections that you disconnected to make sure., and try again.
  12. May 1, 2021 at 6:41 PM
    904Tundra4x4
    alex
    2018 tundra SR5
    The dash lights come on. Its still the belt driven fan. Ill check the ecm pins tomorrow
  13. May 3, 2021 at 5:52 PM
    904Tundra4x4
    alex
    2018 tundra SR5
    Problem solved. It somehow blew my starter. All is well now.
