Unknown wiring behind blank switch
Discussion in 'General Tundra Discussion' started by ATUTundra, Apr 3, 2021.
  1. Apr 3, 2021 at 4:04 PM
    ATUTundra
    ATUTundra [OP] New Member
    What is this for? Any ideas? 2013 Base DC 4x4. My back window (moves horizontally) does not seem to have a motor in it but I know that this is around where the CM window button is right?
  2. Apr 4, 2021 at 5:57 AM
    ATUTundra
    I believe that this is the switch that is meant to be here. Idk how to tell if there is a motor in my rear window.
  3. Apr 4, 2021 at 8:52 PM
    15whtrd
    15whtrd Mr. Blonde
    He’s probably got a column shifter and the tow haul is at the end of the stalk.
  4. Apr 4, 2021 at 9:12 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    His tow/haul button is literally in his first pic you dummy...:eek2:
    Under the 2WD/4WD switch in case you can't find it..:thumbsup:
    Thanks for the input...:rolleyes:
    MTRock likes this.
  5. Apr 4, 2021 at 9:12 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    OP you have several blank switch covers.
    I'm guessing you have an SR5 or Limited.
    Any 2013 or lower SR5 chassis has wiring for all the options of a Limited or Platinum.
    Only the basic SR models didn't have all wiring options.
    After 2014 the SR5 had wiring for all Limited, Platinum, or 1794.
    Although many of those options didn't work unless you had the appropriate model and ECU.
    Again, only the basic SR models didn't have all wiring options.
    Things like fog lights and intermittent wipers to name a couple..
  6. Apr 4, 2021 at 9:53 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I guess I missed that didn’t I. Chill
  7. Apr 4, 2021 at 10:15 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Chill?
    I'm cool as a cucumber Bro....
    Be more like Fonzie, be cool yourself.
    Embrace this opportunity......:D
    https://youtu.be/0-iRW1SjKTc
    MTRock likes this.
