Universal o2 sensor?
Discussion in '1st Gen Tundras (2000-2006)' started by kevhef, Aug 31, 2022.
  1. Aug 31, 2022 at 2:39 PM
    kevhef
    kevhef [OP] New Member
    2001 Tundra 3.4 8'
    Greetings,
    My 2001 Tundra 3.4 2wd has an OBD code that indicates rear o2 sensor needs replacement... of course this is the more expensive of the 2 sensors... while searching for a compatible sensor I found a listing for a "universal o2 sensor" (I'm guessing that means good for front or rear?) ...can anyone advise if this is an acceptable replacement sensor or to be avoided?
  2. Aug 31, 2022 at 2:41 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Don't, universal are generic sensors that require splicing your old plug on.
    Denso or NTK would be ones that I'd use.
  3. Aug 31, 2022 at 7:21 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Front and rear are definitely different. I would definitely say get denso brand if you don't want a headache later on. If you have one going out it might be good to knock out all of them. (Does the v6 have 2 sensors or 4 I'm not sure). The sensor shouldn't be too expensive I don't think. The denso downstream is $48 on rockauto. Link
    The upstream for the v6 appears to be pricey at $120 for denso.
  4. Sep 4, 2022 at 1:13 PM
    This is one of a couple parts you absolutely do not want to use aftermarket parts for on your truck. Buy Denso brand, pony up, it's going to save you money and hassle later. You definitely DON'T want to use anything that splices into the cable, you'll be chasing gremlins a few weeks, months, or years down the road.
  5. Sep 4, 2022 at 4:30 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
