Uneven bed on TRD OR?
Discussion in '3rd Gen Tundras (2022+)' started by Patrazz, Jun 30, 2023.
  1. Jun 30, 2023 at 6:31 AM
    Patrazz
    Patrazz [OP] New Member
    Patrick
    23 TRD OR
    Noticed after the first 1000 miles my bed started to set uneven. It's even worse on a full fuel tank. Is this normal? I didn't see any mentions for the new gen yet. I want to break in the suspension to see if it settles to be sure. Any advice? I'll update with pictures when I get it on a completely level surface.
  2. Jul 20, 2023 at 8:13 AM
    Ddaanngg99
    Ddaanngg99 New Member
    2022 SR5 Tundra CrewMax Longbed
    I’m also curious about this. I have a similar issue with my crewmax longbed. I thought my eyes were playing tricks on my but if I mesure from the Center of the wheel to the fender it’s 3/4 - 1” less on the drivers side.
  3. Jul 21, 2023 at 3:59 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    This is common on almost every light duty truck out there, especially Toyotas. Do a quick Google search for "taco lean"
    It's been talked about in the Tacoma world for nearly decades
  4. Jul 21, 2023 at 9:09 AM
    Patrazz
    Patrick
    23 TRD OR
    Mines still off by nearly an inch after 2500 miles. Regardless of what's typical it's total BS a $70k truck has any deficiencies. I'll reach out to corporate and see if they can help.
    23 Platinum likes this.
  5. Jul 21, 2023 at 7:39 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    My old GMC sat uneven on every fill up
    I hadn’t noticed it my tundra yet
  6. Jul 21, 2023 at 7:58 PM
    CTundraForMe
    CTundraForMe New Member
    Every Toyota I've ever seen has the gas tank on the driver's side.
    Unless the suspension is tuned so that the left side is stiffer than the right, the driver's side is always going to be lower?
  7. Jul 23, 2023 at 6:23 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Yep. My F-150 leaned about an inch from the factory and Tundra about 3/4”. Spent a lot of time and money fixing it on the F-150 and just stopped looking/measuring on the Tundra.
    DMackler[QUOTED] likes this.
  8. Sep 20, 2023 at 6:13 AM
    ToyotaAl
    ToyotaAl New Member
    Does anyone that has new gen tundra feel like they lean towards the left when sitting in the drivers seat and/or the drivers side back seat?
  9. Sep 20, 2023 at 8:21 AM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    I checked mine just now. No suspension mods other than change in tires.
    With a full tank of gas and nobody sitting in the drivers seat the height from the ground to the lower edge of the fender well at the wheel center line on the back is 38 5/8 inches on the drivers side and 38 1/2 inches on the passenger side. On the front it is 36 5/8 inches on the drivers side and 36 1/2 inches on the passenger side. The lean is only 1/8 inch towards the passenger side and the truck has a rake of 2 inches. I have about 1000 miles on it as well.
  10. Sep 26, 2023 at 3:34 PM
    40man
    40man New Member
    I found a simple fix. Shave a little bit off the bottom of one shoe. I did it and now no more bed lean when I look at it.
    Unfortunately the rest of the world seems a bit crooked...
  11. Sep 26, 2023 at 3:59 PM
    SD Surfer
    Bruce
    So Cal
    I've read so much on here about the "Tundra Lean", shims, etc.
    For awhile I kept meaning to look/measure my '19 CM 'cuz I hadn't noticed it, but then I'd forget to do it.
    Then it occurred to me that I hadn't noticed it, and I also hadn't been bothered by it.
    "Hmmm... maybe I won't go looking for it." If one day I'm walking by and suddenly see it, then maybe I'll worry about it.
    Jaypown, Sixty9Four20 and Timmy23 like this.
