Underhood fuel leak
Discussion in '1st Gen Tundras (2000-2006)' started by 2000SCLB, Jul 15, 2021.
  1. Jul 15, 2021 at 11:23 AM
    2000SCLB
    2000SCLB [OP] New Member
    Hello all... having a major fuel leak, and I can't find the right replacement part. Took some pics, seems like a fitting where 2 hard lines come together rusted out, spraying gas everywhere :/
    It's a 2000 tundra with the 3.4...
    Circled in red General location and a closeup of the offending part. Any help is highly appreciated!
  2. Jul 15, 2021 at 11:29 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    If it’s anything like the power steering lines, the individual part is probably part of a complete assembly. I’m guessing mucho $$$. I don’t have the 3.4L FSM so I couldn’t tell you.
    When you pull it up on a dealer website, does it show a complete fuel line for sale?
  3. Jul 15, 2021 at 11:44 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    While I have different year/model, pretty sure the below is what your looking for....whatchamacallit. I'll look at McGeorge in fuel section, might find a part unless others know what they call it.
    Jack McCarthy likes this.
  4. Jul 15, 2021 at 12:13 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    That's gonna be a good one to find as it appears to go all the way to the tank. If you HAVE to drive it, I would consider getting a length of proper fuel line to go from red circle in pic below to hard pipe at the fuel rail.
    That's the farmer in me but perhaps others have better suggestions. Unless someone shows up with how to search hard lines to tank, the dealer might be able to help if you took pictures to them.
    Would definitely confirm with a dealer but it appears the part # is 23801-62100 that goes to fuel rail and the other goes to the fuel filter !
    Aerindel and Jack McCarthy like this.
  5. Jul 15, 2021 at 12:52 PM
    irhunter
    irhunter New Member
    '03 Tundra V8, AT, 4x4, extra cab
    I look forward to your solution. I am sure I have that in my future.
    Tying the un-rusted steel line into a rubber hose...that is not going to be easy. Especially considering (1) the male hose nut is very rusty, (2) the limited access, and (3) the need to contain relatively high pressure. Not like the old days of low-pressure carb fuel lines.
  6. Jul 16, 2021 at 5:05 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If you're not into buying the whole line from the tank to rail, here's what I'd do.
    Use a mini hacksaw to cut both ends away from that fitting.
    Use a proper tubing cutter on the rear line since it's not super rusty then install a new nut and flare it.
    Remove the line at the fuel rail, take it to a shop and have them remove the steel fuel rail side of the line and crimp it onto a new hose and have them make a new line with the correct flare fitting to match what you put on the old tank like.
    So ultimately you'd end up with something like
    old line from tank>male flare nut>female flare nut>new steel line>new rubber line>old banjo fitting to fuel rail.
    Siebler and KNABORES like this.
  7. Jul 16, 2021 at 5:16 AM
    irhunter
    irhunter New Member
    If he could manage to do that part...he could add a flare/hose barb to that unrusted tube and then a male/male hose barb fitting to tie the new rubber into the existing rubber.
    But, it sure looks like Festerw's Step #1 will be tough w/o removing the hose assembly from the truck.
    Roy
  8. Jul 16, 2021 at 6:28 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    There's a reason fuel lines are flared, crimped, etc, though. It should work but if there's a failure 40psi fuel spraying around a hot engine bay is a problem.
  9. Jul 16, 2021 at 7:02 AM
    irhunter
    irhunter New Member
    You got that right.
  10. Jul 15, 2022 at 10:15 AM
    Holzemer
    Holzemer New Member
    Bumping this thread to see if anyone has new suggestions. I have the exact same problem and am unable to find the parts. Can I replace the whole line with a specific type of fuel line?
  11. Jul 15, 2022 at 12:08 PM
    irhunter
    irhunter New Member
    Sure.
    There are hard-line options...steel, copper-nickle, and such.
    And, plastic/rubber.
    https://www.hemmings.com/stories/20...-line-hose-what-you-should-and-should-not-use
    I recently did a brake line using copper-nickle, and it worked well. Easy to bend for a hard line.
    https://www.youtube.com/watch?v=_Tm6N5l69_c
    One of the problems with replacing a fuel line is the tie-in between the new/old lines. After you decide what material you'll use...you can investigate material-specific tie in options.
    Roy
  12. Sep 21, 2022 at 6:07 PM
    2003DC
    2003DC New Member
    Any follow up on this issue? How did previous posters resolved this problem? Any pics?
  13. Sep 23, 2022 at 5:24 AM
    irhunter
    irhunter New Member
    I, too, continue to be interested. I just discovered my fuel filter is really rusty...along with the associated hard-line fitting. It is easy for me to imagine wrecking the fitting...ending up with the same, more or less, problem as the OP.
    Roy
  14. Dec 11, 2022 at 5:57 PM
    Jack McCarthy
    Bill
    North of Boston
    Looks like I'll be picking up where the OP left off. :bananadead:
    w666 and irhunter like this.
  15. Dec 12, 2022 at 6:15 AM
    irhunter
    irhunter New Member
    Rust never rests.
    I now not only need a new fuel filter, due to rust, I have a big rust hole in my resonator.
  16. Dec 12, 2022 at 8:15 AM
    Jack McCarthy
    Bill
    North of Boston
    Okay, made a couple phone calls today for the 2002 Tundra:
    Fuel line from fuel tank to fuel filter:
    Part No # 77252-0C012 $67.06 retail ($49.39 from their online website); probably don't need unless I mangle getting the fuel filter off
    Fuel filter:
    Part No # 23030-62010 $39.58 retail ($29.74 from their online website); not required but would like to do
    Fuel line from fuel filter to engine bay:
    Part No # 77251-0C012 $76.20 retail ($56.12 from their online website); necessary
    Fuel line from engine bay into fuel rail:
    Part No # 23801-50050 $71.03 retail - OBSOLETE!!!
    Time to shop online for residual Toyota stock then call the local shop to see if they can provide a fix without replacement
    w666 likes this.
  17. Dec 12, 2022 at 10:01 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  18. Dec 12, 2022 at 10:13 AM
  19. Dec 12, 2022 at 10:15 AM
    Jack McCarthy
    Bill
    North of Boston
    Looks like it corroded behind the fitting on the line to the fuel filter
    Now to inspect the rest of the line to the fuel filter.
  20. Dec 12, 2022 at 12:33 PM
    Jack McCarthy
    Bill
    North of Boston
    Well the fuel line is now squirting out of the fuel rail via a pinhole leak so it looks like a tow to get it to the local shop a mile away.
    Estimate is $200-$300 to replace the line from the fuel filter and splicing into the existing obsolete line connecting to the fuel rail using nylon hose and brass fittings. I'll be spraying the connections to the fuel filter so hopefully he can get it off by next Monday.
    If I de-pressurize the fuel line by disconnecting the fuel pump fuse and running the engine till it stalls, can I re-pressurize it and get it to run again?
    I'd like to carefully wrench the fuel filter after spraying daily.
  21. Dec 12, 2022 at 12:41 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    New fuel lines. All of em. What do your brake lines and load valve look like?
  22. Dec 12, 2022 at 12:59 PM
    Jack McCarthy
    Bill
    North of Boston
    Brake lines look fine. Just some minor surface rust.
  23. Dec 12, 2022 at 1:00 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    What about the hardware? And brackets.
  24. Dec 12, 2022 at 1:04 PM
    Jack McCarthy
    Bill
    North of Boston
    He’ll most likely bypass those to do it quick. My guess is zip ties. Those brackets would break apart if he played around with them and the nylon hose won’t fit in them I’m guessing.
    Mr.bee[QUOTED] likes this.
  25. Dec 12, 2022 at 1:16 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    When you crank it over it'll build pressure again. Just may take a couple extra revolutions to fire.
    You could also jump the fuel pump relay pins in the fuse box.
  26. Dec 12, 2022 at 1:19 PM
    Jack McCarthy
    Bill
    North of Boston
    Good to know, thanks. Hopefully re-pressurizing it won’t cause the pinhole to get much bigger.
  27. Dec 12, 2022 at 3:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Need to convince LMC Truck to start making discontinued parts
    bmf4069, Tundra2 and shifty` like this.
  28. Dec 12, 2022 at 3:13 PM
    You'll pay a fortune, but at least they'll have it. LMC has always been my go-to for older GM trucks.
    I'm actually surprised there's nothing available from Summit to rebuild the lines. Surely there must be someone out there making this stuff?
    I agree with whoever said it here or in another thread. Just get some AN fittings and cobble a solution together. I don't make lines anymore, but I have a flaring tool or two leftover from my hot rod days I can part with. I usually do braided lines with AN everything on GenIII/LS swaps these days. Just tape off the braided line, cut it, set your AN fitting, peel back the tape and twist it up, you're done.
  29. Dec 12, 2022 at 5:31 PM
    Jack McCarthy
    Bill
    North of Boston
    I’m beginning to wonder if brass fittings are a wise choice due to the potential for galvanic corrosion mating to the steel fitting of the fuel filter. I’ll have to see if he offers regular steel or if brass is the only option.
  30. Dec 12, 2022 at 5:44 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Me too. I still think it's weird which parts they are discontinuing. Brake booster and master cylinder for example.
    An obscure fuel line makes more sense but still sucks.
