Undercover Flex tonneau cover - first impressions
Discussion in 'Tonneau Covers, Caps and Shells' started by Flobrandx, Jul 25, 2015.
  1. Jul 25, 2015 at 9:12 PM
    Flobrandx
    Flobrandx [OP] New Member
    Brandon
    2015 TRD PRO
    Working on them now...
    After looking at the BakFlip G2 and Undercover Flex I decided on the Undercover for a couple reasons.
    1) I liked the FRP over the aluminum because of possible denting. I know BackFlip makes a FRP version but the cost is even more.
    2) 3 year warranty vs 1-2 year
    3) 400lb vs 300lb weight limit
    4) I like that it folds up and is locked in with struts and is not against my cab.
    The only thing I'm not sure about betweent the two is that it is attached to my bed rails and appears to block the use of the tie down hooks that attach to the rails. Anyone else know about this or have a solution for it?
    McNnutt likes this.
  2. Jul 25, 2015 at 9:16 PM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I have the bakflip fibermax and I bought a kit to drop the rails down so u can still use the tie downs. It's just a metal braket. Easy install. I believe it was $50.
    Flobrandx[QUOTED][OP] likes this.
  3. Jul 25, 2015 at 9:20 PM
    Flobrandx
    Brandon
    2015 TRD PRO
    Cool thanks for the info. Where did you get the bracket from?
  4. Jul 26, 2015 at 9:27 AM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I bought them from 4 wheel parts. :cheers:
  5. Jul 26, 2015 at 12:11 PM
    Flobrandx
    Brandon
    2015 TRD PRO
    Thanks, I'll start searching on their website. Don't suppose you have any more info on it?
  6. Jul 27, 2015 at 4:20 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Sorry I dont. They should know what ur talking about or contact Bakflip directly. When I bought mine I had 2 options 1 came with the brackets and 1 didn't. I bought the ones without then ordered the brackets
  7. Jul 27, 2015 at 4:22 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
  8. Jul 27, 2015 at 10:51 PM
    Flobrandx
    Brandon
    2015 TRD PRO
    Thanks JC!
  9. Jul 29, 2015 at 1:41 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Anytime. Let me know if you have more questions or need more pictures.
