Undercoating/Rustproofing
Discussion in 'Canada' started by RedRegCab, Dec 9, 2016.
  1. Dec 9, 2016 at 10:59 AM
    RedRegCab
    RedRegCab [OP] New Member
    A question for all Canadian Tundra owners, but specifically for those in Ontario (where salt is used in excess) did you get your trucks undercoated?
    Normally I suggest this for most vehicle owners, but I am hesitant to have holes drilled in my brand new truck.
    Opinions welcome!!!
  2. Dec 9, 2016 at 11:32 AM
  3. Dec 9, 2016 at 7:59 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Fluid film
  4. Dec 11, 2016 at 9:50 AM
    Bytes_U
    Bytes_U New Member
    2017 Silver Tundra SR5 CrewMax
    Oil Gard
  5. Dec 11, 2016 at 11:45 AM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Krown from Line-x and supplemented with Fluid Film myself.
  6. Dec 11, 2016 at 12:04 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm not in Canada but they love that steel eating liquid chemical crap around here.
    I also use Fluid Film but I'm considering having it professionally sprayed with something more permanent.
  7. Dec 11, 2016 at 4:28 PM
    RedRegCab
    I've used Krown on previous vehicles, I was curious too see how many people have had their trucks done.
    Aside from the drilling I think it's probably a good idea, looks like a real winter ahead !
  8. Dec 11, 2016 at 4:37 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    Not from up north but i used fluid film on my frame... Not great pics but i sprayed it on nice and thick.002.jpg 006.jpg
  9. Dec 11, 2016 at 4:44 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    How much prep is involved to do this? Doesn't look like a fun project although I can see the benefits.
  10. Dec 11, 2016 at 4:55 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    The truck is only 6 months old so it was still somewhat clean. but i did spend about 1 hour under the truck while on the lift just to wipe everything down. i sprayed the livin shit out of it and coated everything
    JC303, TXMiamiFan and MotoTundra like this.
  11. Dec 12, 2016 at 3:24 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    It may not be a true joy but 5 years from now when your vehicle is rust free while everyone else's is full of holes you will feel real good.
  12. Dec 12, 2016 at 3:30 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I'm stationed in the high desert but I still douched mine. I'm a huge stickler for preventative maintenance and cleanliness on my vehicles.
    joonbug likes this.
  13. Dec 12, 2016 at 3:40 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  14. Dec 12, 2016 at 4:38 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    You are right.. A little time getting dirty under my rig works for me
  15. Dec 12, 2016 at 4:44 PM
    TXMiamiFan
    Jose
    Y'all have pics of the prep? What did you cover so it wouldn't get sprayed, etc.? Would be cool to see what it took.
  16. Dec 12, 2016 at 8:41 PM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    I just looked the web site for fluid film. Did I read it right you have to reapply it once or twice a year?
    For those that have used it. Is it like a thick WD-40?
    wwolvverine likes this.
  17. Dec 12, 2016 at 9:12 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I do it every fall. I wear a Tyvek suit, goggles, and a respirator. Yes, I look like I'm headed to the moon but I don't get it all over me or smell it.
    Nothing like WD-40. WD-40 is actually a degreaser, not a lubricant. Fluid film is a lanolin based lubricant. It's thicker than WD-40 and dries leaving a bit of a dull "film". Dust and small debris sticks to it, but if you spray it in the fall, come spring time the film is still there. Water and stuff seems to bead off it.
  18. Dec 13, 2016 at 10:15 AM
    tacouser
    tacouser New Member
    Chicago
    Thanks for the info
  19. Feb 13, 2019 at 5:27 PM
    wwolvverine
    wwolvverine New Member
    2018 Tundra 1794
    I used 2 cans of Fluid Film and did it myself. Stayed away from sensitive areas like wire connections.
  20. Feb 13, 2019 at 6:02 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I ordered the spray gun kit, and a gallon of fluid film. Used entire gallon. Plan on doing every spring and fall. I think it was time well spent since I was able to get aquanted with underside. Hoping it helps me identify any problem areas that need attention. I think Krown, fluid film, or nhoil are prob the best solution. Personally I think drilling holes is minor compared to the alternative. Taking off the fender liners was the most time consuming part. I only used ramps and safety glasses. I also keep a couple spray cans around to do touch ups as needed.
    Pudge likes this.
  21. Feb 13, 2019 at 6:10 PM
    Luckydog
    Luckydog New Member
    Dominic
    Besides being clean and dry, I did not do any prep. I got a little overspray on exhaust but it burns off quick enough. The only thing I avoided was brakes. It builds up over applications. The oil saturates everything, so I doubt that a little dirt would affect it. Some guys even drive down a gravel road to coat the oil in dust.
    TXMiamiFan[QUOTED] likes this.
  22. Feb 13, 2019 at 7:12 PM
    Gts bruce
    Gts bruce New Member
    Krown works. I get Rustop which originally came from Canada. It's a little thicker than Krown. No rust on a guys impala that was 18 yrs old. Driven in the Buffalo salt rust belt all those years. Supposed to be applied every year. Every 2-3 years is adequate.
  23. Oct 29, 2019 at 1:42 PM
    neverstuck
    neverstuck New Member
    03 Sequoia Ltd 4x4
    Bilstein 5100's, KC slimlights, twin bed frame install
  24. Oct 29, 2019 at 3:32 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I used NH oil undercoating.
