Undercoating necessary?
Discussion in '3rd Gen Tundras (2022+)' started by Steelhant, Apr 27, 2023.
  1. Apr 27, 2023 at 5:42 AM
    Steelhant
    Steelhant [OP] New Member
    TRD- Pro
    none...new
    Just purchased a Platinum just curious if its needed ?
    Thanks
  2. Apr 27, 2023 at 5:48 AM
    I believe this would be subjective what state you’re in.
  3. Apr 27, 2023 at 5:54 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    agreed, depends where you live. I had mine coated by Krown last year and will continue to get it treated every year.
  4. Apr 27, 2023 at 7:03 AM
    Tom976
    Tom976 New Member
    Tom
    I'm a little more hands on. I use fluid film to coat it. Dont like the idea of using epoxy paints to protect from rust.
    Fluid film is an oil that coats the underside. Two cans is more than enough.
    Used it on my 13 Tacoma for years. When I went into Toyota service for frame warranty check they were surprised at how well it looked.
    Not to mention I am in NY and they LOVE to use salt / sand mix on the roads when it gets cold out.
    WILLINH, Russ_S, Ginsterkev and 2 others like this.
  5. Apr 27, 2023 at 7:09 AM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    Fluid Film and PB Blaster brand has a Surface Shield corrosion protection film also which I prefer.
    Russ_S and Ginsterkev like this.
  6. Apr 27, 2023 at 8:11 AM
    raylo
    raylo not so new member
    Frederick, MD
    I am doing FF on my Tundra after my Tacoma rust experience. We'll see if I can keep it up and how well I am able to cover it. It would be really nice to do this on a real lift instead of on the ground or jackstands but I don't have one.
  7. Apr 27, 2023 at 8:13 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    I was going to go the FluidFilm/WoolWax route but was running short on time before winter and decided to have it done at Krown. It's more expensive but they did a really good job so I'll just stick with them doing it.
  8. Apr 27, 2023 at 8:35 AM
    rozemab
    rozemab New Member
    Yes The state of Indiana uses some sort of alien acid blood for salt. I had my truck ziebart'ed and undercoated. Now, you pay once and get the yearly refreshing of both coatings for free.
    Tundra Dude 45 likes this.
  9. Apr 27, 2023 at 8:40 AM
    raylo
    Frederick, MD
    Brine. Most states use this stuff now. They spray the roads in advance of the dump and it dries to keep snow and ice from sticking to the pavement. In theory, or at least for awhile. Here we can see the traces down the road left by the spray trucks, at least until the snow comes. Not sure what all goes into this stuff but surely salts of some sort.
  10. Apr 27, 2023 at 10:01 AM
    Hella Krusty
    Hella Krusty New Member
    Its straight prune juice in BC. Has a very low freeze rate
  11. Apr 27, 2023 at 10:08 AM
    raylo
    Frederick, MD
  12. Apr 27, 2023 at 10:29 AM
    Fedtime
    Fedtime New Member
    Brine is common in Atlantic Canada, as is road salt in general, because of the continuous freeze-thaw cycles.
    Fluid Film is used, but Krown is by far the most popular. My preference is FF, but both seem to do a good job. It must be said that it also matters how careful and thorough the person is in applying the stuff. I'd take a good job with Krown over a poor one with FF.
    Russ_S likes this.
  13. Apr 27, 2023 at 10:49 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I'm in New England, traveling up to northwestern Maine for offroading often. Winter conditions are pretty much the same like in ON and QC (south parts of). I sprayed my new 2019 with Noxudol 700 cavity wax (inside the frame channels) and 1600 everywhere else. It holds up very well. Sprayed wife's new 2022 Sequoia, too. The only chance for rust to form under Noxudol is Toyota's contaminated weld seams: they rust internally and nothing you can do about that.
    https://bobistheoilguy.com/forums/threads/noxudol-pros-and-cons.349923/
    https://bobistheoilguy.com/forums/threads/rust-inhibitor-treatment.346218/
    Noxudol is a Swedish stuff, it is used by Volvo at assembly line, which knows quite a bit about winters and rust prevention.
    I recommend 1600 instead of 300 undercoating they used on BITOG. On my Volvo undercoating was gone in one trip to Trans-Taiga. 1600 resists gravel pretty well, if you apply it in a few thick layers.
  14. Apr 27, 2023 at 11:19 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Beet Juice in Manitoba.
    RookieEP likes this.
  15. Apr 27, 2023 at 11:41 AM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Falken Wildpeak tires
    I did corrosion free on my tundra, but didn’t find an installer down here so hit Newmarket to find one last fall. Did you find one down S/W Ont?
  16. Apr 27, 2023 at 12:11 PM
    MF140
    MF140 New Member
    2023 Tundra Platinum WCP Crewmax 4x4
    I was very happy with the coverage Woolwax provided when I used it on my Jeep Wrangler (known for being rust buckets). I plan on doing the same with my Tundra to keep the undercarriage looking new.
    BravoDeltaRomeo likes this.
  17. Apr 27, 2023 at 12:52 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Locally, Canadian Tire in Winnipeg does it. I wouldn't trust the CT monkeys with my tires, let alone rust proofing or drilling holes to spray.
    I do mine myself with a compressor and the gun. I'm guessing I don't do a good as job as a pro installer would, but it's cheaper, I can reapply in my driveway and it's better than doing nothing (like our previous vehicles).
  18. Apr 27, 2023 at 1:21 PM
    Tom976
    Tom976 New Member
    Tom
    The fluid film is in a spray can. (they do make a liquid if you spray) For me, two cans and you can get that stuff all over the place.
    I wouldnt do it on the driveway though as the stuff that drips can leave a mark.
    Doing it on grass is fine and can be easily done without lifting the truck.
  19. Apr 27, 2023 at 1:35 PM
    mass-hole
    mass-hole New Member
    I have used fluid film and wool wax black. I have the fluid film spray gun that hooks up to a compressor and do it myself in my driveway and it does work well. I do 2 car with a 1 gallon paint can of the FF and then I will use the rattle cans to do touch up here and there.
    Just be aware, working on the car afterwards sucks. Everything is oily. Also, dust and dirt will be stuck to everything.
    But the frame will look mint.
    Also, after applying it I do not heavily wash the underside of the car. I dont use a pressure washer or soap as I do not want to wash off the film. I will just rinse it with a regular low pressure hose if I do wash it.
  20. Apr 27, 2023 at 4:06 PM
    rohmbd
    rohmbd New Member
    +1 for Woolwax....I've used PB Blaster Surface Shield for a couple touchups
    MF140 likes this.
  21. Apr 27, 2023 at 4:45 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    I live in New England the roads get rocksalt and some other liquid shit for the winter so the dealership is going to apply something new to me called waxoil from what they said anything that doesn't move,rotate or spin will get coated.
    Let's see how it holds up off roading on the beaches...
  22. Apr 28, 2023 at 3:46 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    After having mine coated by Krown it dripped for at least two weeks! The mess was crazy. But they assured me that if it was on concrete it would wash away after a few good rains, but if it was asphalt it would stain it permanently. I have a concrete driveway, I was worried it would stain with how much was dripping so I power washed the driveway after about a week. You could still see the spots a little and the truck still continued to drip a little. But after 4-5 good rains you couldn't see the spots anymore. Not sure about the other products but that is my experience with Krown.
  23. Apr 28, 2023 at 3:51 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    When I had mine coated by Krown I asked them about washing the undercarriage and they said to wait a week for the fluid to creep into areas and fully coat before washing the undercarriage. They said it would take a very high PSI rating to remove it and at that PSI it would remove paint so it would be safe to power wash with a regular power washer and nozzle, I have a wheeled attachment that has 4 sprayers that angle up to clean under the truck, works pretty good.
  24. Apr 28, 2023 at 3:54 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
  25. Apr 28, 2023 at 4:06 AM
    raylo
    Frederick, MD
    That sounds similar to the treatment Toyota applied to my Tacoma for that frame recall. For some frames that weren't too bad they coated them instead of replacing them. That stuff dripped for a couple of weeks during which I parked it out on the street. Seemed to work well.
  26. Apr 28, 2023 at 4:20 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It means it washes away from truck in the same time frame. I think it's a part of their business model that customers are hooked forever and need to reapply it regularly.
  27. Apr 28, 2023 at 6:30 AM
    raylo
    Frederick, MD
    Tundratic and Mattedfred like this.
  28. Apr 28, 2023 at 6:53 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    The dripping was excess fluid, the undercarriage was still plenty coated weeks after application. It's not any one companies business model, all of these rust preventative fluids require reapplication every year.
  29. Apr 28, 2023 at 7:00 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
  30. Apr 28, 2023 at 7:11 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yeah, that's the point. I tired re-spraying undercoatings every few months, don't do it anymore with 1600. Not single one undercoating survived through the New England slushy salty winter on my car.
    Given the fact OP is in Canada, he'll be seeing the same picture over and over again: rust spreading, despite yearly re-application.
