undercoat products
Discussion in 'General Tundra Discussion' started by TTL, Apr 20, 2022.
  1. Apr 20, 2022 at 4:05 PM
    TTL
    TTL [OP] New Member
    I bought truck from TX , no rust. I live in NJ and afraid it will get rusted. First step in build I would like to rustproof undercarriage. There are million of products, I am having hard time to process. I will appreciate any help to select a right product. If you know any undercoating shops in New Jersey.
  2. Apr 20, 2022 at 4:10 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    Cosmoline direct RP342
  3. Apr 20, 2022 at 4:19 PM
    Do it yourself either use Fluid Film or Amsoil Heavy Duty Metal Protectant. I spray mine with the Amsoil HDMP every fall.
    NueveTundra, Wallygator and Ely010606 like this.
  4. Apr 20, 2022 at 4:22 PM
    18" TRD Off Road Wheels
    Top right of the forum you'll see the search bar if on PC or a magnifying glass if on mobile. Type in "Fluid Film" and there's loads of info. For undercoating you don't want anything that is rubberized. It'll trap all the bad stuff and rot your frame.
    https://youtu.be/nXvl9nt57Kg
  5. Apr 20, 2022 at 4:26 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    Highly recommend fluid film in gallon jugs and applied by air compressor/spray gun. I have used cosmoline and that works but it’s nasty stuff and once it’s on, it’s on and sometimes it leaves exposed areas as it doesn’t cling like fluid film.
    I like to be able to wash off the undercarriage and fluid film in the spring time and then reapply a fresh coat in the fall which works perfectly with fluid film.
    Wallygator and jeller75 like this.
  6. Apr 20, 2022 at 4:44 PM
    jeller75
    jeller75 New Member
    Joshua
    NC Mountains
    2017 CC Platinum Pro 4wd
    I follow this same process. Works great!
  7. Apr 20, 2022 at 5:13 PM
    MEWaters
    MEWaters New Member
    Maine
    There are superior products over FF. Spend some time researching
  8. Apr 21, 2022 at 4:19 AM
    jeller75
    jeller75 New Member
    Joshua
    NC Mountains
    FF works great as I previously stated however, when I use all the bulk FF I purchased, I plan to use Blaster Surface Shield. BSS claims to be far longer lasting than FF and there may be additional improved products as well. There are several good YouTube videos that compare these products over the long term in the "Rust Belt"
    https://blasterproducts.com/product/surface-shield/
  9. Apr 21, 2022 at 9:10 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    NHOil
    Jack McCarthy likes this.
  10. Apr 21, 2022 at 10:02 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I think the big thing is going with an oil based product like Fluid Film or BSS as they both use Lanolin oil. I'm sure there are other oils out there too. From my understanding rubberized coatings are only good if it is a brand new truck otherwise they will trap moisture and rot the frame eventually. I'm in the Pittsburgh area and we get a fair amount of snow resulting in large exposure to salt and I've been having mine sprayed with FF since new and there no rust on the frame and surrounding parts.
  11. Apr 21, 2022 at 10:05 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2^^, I normally do mine every 2 years.
    Wallygator likes this.
  12. May 8, 2022 at 7:25 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Fluid Film :hattip:
  13. May 8, 2022 at 7:47 PM
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 Tundra and 2011 Sequoia
    I’ve used woolwax, very similar to fluid film.
    So far so good, the stuff really stays on after you get some dust build up.
    it’s messy to work on it after it’s been applied, but it’s a good trade off.
    one thing I did notice was some breakdown on my CV axle boots, right at the end by the shaft, I tried to cover them a little but some might have gotten on them by the axle shaft.
    they do warn you not to get it on rubber components.
    the boots are starting to breakdown and are only 2 years old. They haven’t failed yet but it was weird that they are cracking and weather checked.
    I’m not 100 percent sure that’s the reason, or it’s inferior NAPA boots.
    We’ll see how they hold up moving forward.
  14. May 9, 2022 at 4:07 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Check out my thread from a while back, a lot of good info in there;
    https://www.tundras.com/threads/undercarriage-treatment-yay-or-nay-pros-cons.99051/
  15. May 10, 2022 at 11:16 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I don’t think they have a place in Jersey.
  16. May 10, 2022 at 11:19 AM
    Jack McCarthy
    Bill
    North of Boston
    POR-15 work well. I’ve been using it for 10+ years now and it’s done a great job externally. It does require periodic touch up every few years.
    Only downside is my truck is rusting from the inside out. :(
