Underbody oil
Discussion in '1st Gen Tundras (2000-2006)' started by DirtMerchant63, Mar 13, 2020.
  1. Mar 13, 2020 at 6:50 AM
    DirtMerchant63
    DirtMerchant63 [OP] New Member
    Peter
    '06 Tundra
    Okay, here's one I'm throwing out there... Talked with a mechanic I trust yesterday. He owns a Toyota 4 Runner I believe. He told me about something he did to his undercarriage called N.H. oil. Had it done at a place close to my house... He swears by it and recommended it to me. Anyone ever heard of it? He said they spray it on and you never wash your undercarriage then. I'm going to look in to it myself but I wanted to see if anyone else has heard of it...
  2. Mar 13, 2020 at 7:04 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Similar to Fluid Film, or Krown in Canada. I think NH oil has. Black option that looks good underneath vehicle. I would definitely use it. I spray FF on my truck. They all make a difference in protecting against rust.
    DirtMerchant63[OP] likes this.
  3. Mar 13, 2020 at 7:15 AM
    Professional Hand Model
    Hand Protectors
    Buy two tubs of moly-b grease and Shmear it all over your underchassis. Use a plunger rigged up to push the grease in the boxed frame portion. Over time the shiny slick grease layer develops into a hard black shell. You’ll never need to coat your frame again.
    Rex Kramer, Ely010606, chrisb and 3 others like this.
  4. Mar 13, 2020 at 8:37 AM
    ncomeau35
    ncomeau35 New Member
    North of Boston
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    I got my 2019 TRD sprayed by New Hampshire Oil Undercoating last summer. It's a quick, inexpensive way to protect your investment!! Especially if you live in an area where they treat the roads with sand/salt during the winter months!!
    https://nhoilundercoating.com/
    Check'em out for yourself!
  5. Mar 13, 2020 at 9:29 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    My buddy has his truck fluid filmed regularly, this past year he tried out NH Oil an didn't like it, felt it didn't hold up as good and the splatter / over spray on the truck was more noticeable, which could have been how it was applied. Personally I feel fluid film is to thin to hold up for long, at least where I live through salty winters. I opted to buy a kit on Amazon that uses Woolwax brand undercoating, it came with a undercoating specific spray gun you use with an air compressor and applied it myself. Its definitely thicker then fluid film and stuck like glue for me, even in areas that get a lot of road spray really held up well. I was very impressed with the Woolwax product and it doesn't stink like fluid film..
    DirtMerchant63[OP] and N84434 like this.
  6. Mar 13, 2020 at 9:54 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    I had my Tundra sprayed with NH Oil last fall, it is still all on there and seems to have protected the underside really well. I'm probably going to wash the bottom off in the spring so I can work on the truck without getting greasy and have it reapplied in the fall.
  7. Mar 13, 2020 at 7:41 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Just happen to be doing mine myself tomorrow. I am using Woolwax.
    Seems to be better rated than the others like Fluid Flim
  8. Mar 13, 2020 at 7:53 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    17inferno likes this.
  9. Mar 14, 2020 at 7:59 PM
    RR60
    RR60 New Member
    I had found where a test was done with the major brands. The Amsoil sounds good but came in 4 th.
    They were rated on this order based on test.
    1. Fuildfilm (I usedd woolwax since made by same company and just thicker)
    2. WD-40 Specialist Long-Term Corrosion Inhibitor
    3. Corrosion X HD
    4. The Amsoil MP
    5. Framesaver
  10. Mar 14, 2020 at 8:29 PM
    TILLY
    Massachusetts
    Do what you want, its your truck, but here's another comparison test you might not have seen.
    https://youtu.be/oXlhmbvdKBo?t=1
    conman likes this.
  11. Mar 14, 2020 at 10:26 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I used the Amsoil MP HD and it has held up pretty good so far for me.
    TILLY likes this.
  12. Mar 15, 2020 at 5:03 AM
    DirtMerchant63
    Peter
    '06 Tundra
    Lot of choices.. Thanks for all the recommendations. I'm guessing nothing is perfect. Professional Hand Model, I've not forgotten your suggestion... Just looking at the options... I know I have to do something that's for sure..
    Luckydog likes this.
  13. Feb 7, 2022 at 4:48 AM
    Cb19
    Cb19 New Member
    Ive got a Pro and just wasnt sure about it covering the red shocks, skid plate, etc... how has it been holding up? where did you get your done? i was checking this place - https://www.rhinoliningsofcapecod.com/
  14. Feb 7, 2022 at 4:57 AM
    Northbound Train
    Glenn
    Western MA
    The NH oil is available either clear or black. The clear is the way to go.
    Cb19 likes this.
