Under seat storage
Discussion in '2.5 Gen Tundras (2014-2021)' started by 14crewmax, Oct 1, 2020.
  1. Oct 1, 2020 at 4:38 PM
    14crewmax
    14crewmax [OP] New Member
    Oroville Ca
    2014 TRD off road crew max 4x4 silver sky metallic
    Stock
    Has anyone done the under seat storage mod? I was thinking about doing it to my tundra because eveytime I carry stuff it ends up sittin on the back floor or on a seat. If you have done it can you post a pic and what storage did you purchase?
    4x4_Angel likes this.
  2. Oct 1, 2020 at 4:45 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Look up ESP storage I’m the search bar. I did it a couple weeks back.AE261492-518C-4B03-88F0-6C408D8FB078.jpg
  3. Oct 1, 2020 at 5:27 PM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Are there any other options besides the ESP? I’m just leery of cutting into the carpet.
  4. Oct 1, 2020 at 6:29 PM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    Only way to make room under the seat in Gen 2.5 is to cut into the carpet and foam. Many have done it on here with pics. Luckily, my ‘11 RW has the seats on the slide and tilt forward so I can still fit gear under them and behind them. One of the STUPIDEST changes Toyota made to the Crewmax interior imo.
    aelarson, R-ROD, Mitchell and 2 others like this.
  5. Oct 1, 2020 at 8:45 PM
    Blueknights75
    Ron
    Clayton, NC
    Very simple mod! Just do what I did have a few shots of whisky and a few beers and start cutting...honestly one of the best mods once I got the balls big enough to cut the carpet and insulation. Remember to cut inside the line to make it a snug fit and you will absolutely love it. I keep a first aid kit, a pull rope, ratchet straps and a few towels.
    gkelm, 4x4_Angel, Huckwheat and 2 others like this.
  6. Oct 2, 2020 at 5:45 AM
    nhw544
    nhw544 Food fight!
    RVA
    Do you guys notice any more road noise since you have to cut the insulation?
  7. Oct 2, 2020 at 6:06 AM
    Blueknights75
    Ron
    Clayton, NC
    None whatsoever.
    ElNopal and nhw544[QUOTED] like this.
  8. Oct 2, 2020 at 7:58 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Do it, I promise you won't regret it. After it's in, you will think it's a OEM piece. It's not hard at all, 1 hr tops. Best mod ever!
    nhw544, 14crewmax[OP] and ElNopal like this.
  9. Oct 2, 2020 at 9:31 AM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    B598A895-AD9E-4598-9CEF-0AD94C032DCC.jpg It’s an EASY unit to install. Just go slowmy and carefully. It’s 1000% worth it.
    ElNopal likes this.
  10. Oct 2, 2020 at 9:52 AM
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    Looks like a lot of wasted room, is there a reason why they cannot offer the longer door version in plastic, like their steel version?
  11. Oct 2, 2020 at 9:56 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    One of the best mods. It's a little scary to cut into a brand new (3 days old) truck's carpet, but so worth it.
    ElNopal and nhw544 like this.
  12. Oct 2, 2020 at 10:02 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Any version is going to be a plus vs not...
    I echo the same sentiments... go for it!
    7E42C077-3E51-4802-B4A5-F751424B799C.jpg BCF852E7-9CA8-43F5-9D2D-D5A8DF49D4CB.jpg 5BD4158B-7756-4303-BEF1-755E86972D86.jpg
  13. Oct 4, 2020 at 9:34 PM
    TonyNCo
    TonyNCo New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    Hi all,
    I get cutting through the carpet, pad. To the interior side of the sheet metal. However, is this mod actually cutting through the sheet metal leaving a big hole, the opposite of a sunroof hole?
    Any photos along the way of this?
    Thx
  14. Oct 4, 2020 at 10:35 PM
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    The only cutting is to carpet and foam. You’ll find a number of videos on YouTube for the ESP installation.
  15. Oct 5, 2020 at 3:42 AM
    18" TRD Off Road Wheels
    Yes. The reason they do 3 small bins is because the seat mounting brackets run in between each of the bins.
    They do make a "long box" version that is metal, and it comes with new seat brackets. Personally, I'm not willing to take the seats out, rip up all the carpet, and replace the seat brackets. I have the 3 bin version waiting in the truck. Hoping today is the day I have time to install.
    RookieEP and ElNopal like this.
  16. Oct 5, 2020 at 4:24 AM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    The long box is a great choice. The install isn't hard and you pick up enough storage for essentials. I keep jumper cables, first aid and other roadside emergency gear stowed. I didn't notice any additional noise after the install beyond some gear rattle that I repacked to resolve.
    deptrai, 4x4_Angel, Ely010606 and 2 others like this.
  17. Oct 5, 2020 at 5:23 AM
    timsp8
    NY
    I have mine out right now cause I’m installing an inverter. Here is what it looks like underneath.
  18. Oct 5, 2020 at 6:27 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Adam, today CAN be the day! The previous offer of helping you with your mods still stands. Besides, it can be a preliminary “sound-off” of at least the two “loudest mouths” of the Cavalry Blue Brothers! :argue:
  19. Oct 5, 2020 at 7:27 AM
    RookieEP
    RookieEP New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    I have a 2020 CM limited. Im worried about the key fob remote sensor or any wires- is this a real concerm? Anyone do CM limited or platinum addition?
  20. Oct 5, 2020 at 7:42 AM
    timsp8
    NY
    I think they redesigned it for the 20s. I think there was a thread about it.
    GODZILLA likes this.
  21. Oct 5, 2020 at 7:48 AM
    TrashcanBand
    CenTex
    Tundra
    It’ll fit. From what I’ve seen, when you’re cutting the foam in the middle section, cut from the passenger side to the driver’s side. There’s a sheath around the wires and it’ll, for sure, protect the wires from the blade if you come from that side. If you come from the other side, there’s less protection. The bundle of wires runs pretty close to the center of the section.
    GODZILLA and ElNopal like this.
  22. Oct 5, 2020 at 7:22 PM
    TonyNCo
    TonyNCo New Member
    Tony
    Awesome, Thx for the info
  23. Oct 5, 2020 at 8:14 PM
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
  24. Oct 5, 2020 at 8:18 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    biebs96, nhw544 and RookieEP like this.
  25. Oct 5, 2020 at 8:34 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I have this set up in my truck. Definitely worth the and effort put in to install! I also cut a thin yoga mat for the bottom so the gear does slide or rattle in it
    No sheet metal cutting. Literally only carpet and foam
  26. Oct 5, 2020 at 8:39 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I used the carpet cutout but I think the mat probably helps better with the gear not rolling around :thumbsup:
  27. Oct 6, 2020 at 4:06 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    It definitely helps lol.
    ElNopal[QUOTED] likes this.
  28. Jan 13, 2021 at 12:41 PM
    theomedic
    theomedic New Member
    Theo
    2016 Tundra SR5
    Stock so far
    Has anyone tried putting the weathertech mats over the storage compartment with the lockable bins? I don’t want to cut up my mats...
  29. Jan 13, 2021 at 1:36 PM
    timsp8
    NY
    I saw a picture where someone cut their mat to make it fit, but not on top. Just try it. The front seats should make it stay in place.
  30. Jan 13, 2021 at 2:20 PM
    Boerseun
    Ferdie
    Sarasota Florida
    It will be a pain to get to the bins if you have to fold the mat over to the front to get to the locks so that the lids can be folded up the other way so you can get into the bin while holding the lid in one hand and the mat in the other hand...
