Uncomfortable ride after 6000 miles.
Discussion in '3rd Gen Tundras (2022+)' started by offshore2005, Oct 5, 2022.
  1. Oct 5, 2022 at 7:16 PM
    offshore2005
    offshore2005 [OP] New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    I have a 2022 limited 4x4 with the coil suspension and at 5000 miles I started to notice a little difference in the ride. Now the truck has 6400 miles and we drove 4 hours today and my wife made the comment she felt as though she was going to bounce out the back seat. Before she would only ride in the back with the baby due to the smooth ride. Is anyone else experiencing this?
    I am thinking about upgrading the rear shocks to see if that will help or can someone point me in a different direction. I am leaning towards the ICON 2.0 VS IR. but have never ran Icon so any input would be appreciated.
  2. Oct 5, 2022 at 7:52 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Do you have Trd package?
    I see that you have RC leveling kit installed? Could the issue be aftermarket leveling kit?
    Terndrerrr likes this.
  3. Oct 5, 2022 at 7:57 PM
    offshore2005
    TEXAS
    No I don’t have the TRD Package. I had the leveling kit and 35” tire put on at 300 miles so I would not think it would be the leveling kit. I can push on the rear bumper and make the truck go down with ease. This makes me think the shocks are gone in the rear but I just can’t see that with only 6400 miles.
  4. Oct 5, 2022 at 9:13 PM
    Keeptipsup52
    Keeptipsup52 New Member
    22 SR5 TRD OR
    Before going for a full suspension change I’d be looking at wheel balancing especially with you quickly going to 35s and a levelling kit.
    unless, of course, this is just a good excuse for new shocks and maybe a lift.
    GODZILLA likes this.
  5. Oct 5, 2022 at 9:38 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I would suggest to take it to the dealership and have them figure it out. But in your case they'll probably blame it on the big tires and leveling kit.
    Just curious, have you considered getting the Trd lift kit? That preserves the warranty?
    My truck will also have regular shocks, no Trd, no avs, so I'm planning on what to do with it...
  6. Oct 5, 2022 at 9:42 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    RC lift, baby bounce after the install?
  7. Oct 5, 2022 at 9:46 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    All Toyota factory black shocks are garbage, from factory they are already under dampening, and they are known to leak before warranty.
    offshore2005[OP] and Kap1 like this.
  8. Oct 5, 2022 at 10:09 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    How was the ride before you switched to the 35's, and leveling kit?
  9. Oct 6, 2022 at 4:54 AM
    arock
    arock New Member
    Could be due to tire wear. Not sure what type of tires you have but maybe you have worn through the "softer" parts of the tread lugs? Might be able to play with tire pressures to see if that helps any. Would be a cheap easy fix if it does help.
  10. Oct 6, 2022 at 5:46 AM
    offshore2005
    TEXAS
    The ride before and after did not seem to change. Tires and leveling kit got put on at 300 miles. Starting to notice a difference at 5000 and only getting worse now.
  11. Oct 6, 2022 at 5:47 AM
    offshore2005
    TEXAS
    Cooper STT Pros with only a little over 6000 miles on them.
  12. Oct 6, 2022 at 5:48 AM
    offshore2005
    TEXAS
    Nope rode like a dream after installing. That was over 5500 mile ago. Now it’s bouncing in the back.
  13. Oct 6, 2022 at 5:50 AM
    offshore2005
    TEXAS
    I was told by my dealership a leveling kit will not void warranty. I bought the extra 100,000 mile warranty and that was the first question I asked before buying it.
    JoeInMinn and Sunnier like this.
  14. Oct 6, 2022 at 5:52 AM
    offshore2005
    TEXAS
    I went to 35’s and a leveling kit at 300 miles. Now over 6000 miles later I have a problem. I would not think it would take that long for a problem to be linked to the tires or leveling kit. I would think that would happen in the first thousand miles or so. The truck was smooth after install. Almost like a factory ride.
  15. Oct 6, 2022 at 5:56 AM
    timsp8
    NY
    Before you go with icon, read up on digressive vs progressive shocks. Icon will most likely get rid of the bounce, but won’t necessarily be a smoother ride.
    offshore2005[OP] likes this.
  16. Oct 6, 2022 at 9:14 AM
    Sunnier
    Sunny
    San Diego, CA
    Did you recently take it anywhere that someone could have filled your tire pressure higher than it was after the install? I run Cooper STT Pros and keep them significantly lower than top pressure. When they have occasionally been inflated more (after tire rotation), the ride is stiff and uncomfortable.
    Terndrerrr and GODZILLA like this.
  17. Oct 6, 2022 at 9:19 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    how much tire pressure?
  18. Oct 6, 2022 at 9:19 AM
    offshore2005
    TEXAS
    What tire pressure do you run? I just checked and they are at 40-PSI.
  19. Oct 6, 2022 at 9:20 AM
    offshore2005
    TEXAS
    40-PSI. What should I be running in 35” coopers.
  20. Oct 6, 2022 at 9:22 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    40psi cold? Seems high to me. Check the max psi vs load and calculate your weight and go from there. I went from 35psi cold to 32psi cold and it was significant in small bump harshness.
  21. Oct 6, 2022 at 9:24 AM
    offshore2005
    TEXAS
    That was after a 2 hour drive this morning (40 psi)
  22. Oct 6, 2022 at 9:31 AM
    alex17117
    alex17117 New Member
    Alex
    2024 limited, Lunar Rock
    I put TRD rear shocks on my standard SR5 and the ride improved significantly. The damping is much more substantial and makes a huge difference.
  23. Oct 6, 2022 at 9:46 AM
    offshore2005
    TEXAS
    I was looking at adding ICON 2.0 and the REAR FOAM BUMP STOP KIT from ICON to the rear. They are saying it will improve the ride better than new.
  24. Oct 6, 2022 at 10:04 AM
    Sunnier
    Sunny
    San Diego, CA
    I knew you’d ask :rolleyes: but I’m running 33’s not 35’s. Anyway, I typically run 38psi on highway, so if you’re for sure at 40psi, that’s probably not the problem. Also, I’ve got more than 5k miles on mine, much of it off-road, so I don’t guess tire wear is your problem either.
    Edit: our trucks are not equivalent either; the one I’m running STT Pro’s on is a 1st gen long travel with King Shocks… so the only thing we have in common is tires.
  25. Oct 6, 2022 at 10:28 AM
    offshore2005
    TEXAS
    I have 35’s on my 2018 tundra and don’t have this problem with it but I have bilstein shocks on it. So I am thinking if I upgrade the shocks and replace the bump stops it will help. Hopefully!
    Sunnier[QUOTED] likes this.
  26. Oct 6, 2022 at 10:50 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    too bad truck is too new, not much shocks is out there
  27. Oct 6, 2022 at 11:09 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Did the leveling kit lift the back also? If so then I would say that the OEM shocks are shot since they are not rated for lift.
  28. Oct 6, 2022 at 11:15 AM
    offshore2005
    TEXAS
    No nothing was done to the back. Just 1.75” to the front.
  29. Oct 6, 2022 at 11:19 AM
    pursuit2550
    Have you checked to see if they are leaking?
  30. Oct 6, 2022 at 11:55 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I don’t think the regular black shocks you usually see on these trucks from the factory are very good. I wonder if one of them is bad already. Could be worth having the dealer take a look at it and they could replace them if so. If you want to upgrade them to something better anyway, I guess now would be the time! Anyway, Here is a meme that nobody asked for because you might as well laugh about it.
