Unable to Install Running Boards
Discussion in '2.5 Gen Tundras (2014-2021)' started by go_cubbies22, Dec 27, 2022.
  1. Dec 27, 2022 at 7:43 AM
    go_cubbies22
    go_cubbies22 [OP] New Member
    I bought Clamber running boards for my 2020 Tundra Crewmax.
    The bolts that came with it won’t thread all the way in. They make it about 1/3 to 1/2 way and then become stuck.
    I bought some M8x1.25x25mm bolts to check if the manufacturer sent the wrong size but still having the same issue. I also cleaned the inside of the threads with a wire brush.
    Here’s a picture of the bolt getting stuck.
    Any ideas? Thanks
  2. Dec 27, 2022 at 7:51 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Are you the original owner? I'm wondering if there were steps installed previously and the threads might have gotten boogered up. Did you have bolts in the holes when you went to install yours? There should be some M8x1.25x20 (I think that's the length) bolts in there from the factory. Grab a tap and chase the threads maybe?
    BTW I like the screen name #gocubsgo
    LS3, NewImprovedRon and FrenchToasty like this.
  3. Dec 27, 2022 at 7:53 AM
    go_cubbies22
    I’m not the original owner. I just bought it certified pre owned from a Toyota dealer. The original bolts that come installed from the factory were not there when I bought it.
    I guess a tap and die set would be the best option if they are messed up?
    Go cubs!
    LS3 and TRDFerguson like this.
  4. Dec 27, 2022 at 7:58 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, you can try a thread chaser tap like this.
    https://smile.amazon.com/BILITOOLS-...75&sprefix=m8x1.25+chaser,aps,167&sr=8-8&th=1
    Go slow and use WD-40 or another oil/lube to slowly work through the threads. You could also get under there with a flashlight and see if there's rust or something else stuck and clear it out with a pick.
    Do any of the other holes work with the bolts you have?
    FrenchToasty likes this.
  5. Dec 27, 2022 at 8:11 AM
    go_cubbies22
    I’ve got 2 to work. The rear ones are really bad and the bolt will only go in a few turns. Here’s some pics of the inside of those 2- kind of hard to see.
  6. Dec 27, 2022 at 8:15 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Ah, those just look rusty. Hit them with some PB or other penetrating oil and work them slowly with a spare M8x1.25. That's a bummer that the factory bolts were removed. They would have prevented this.
  7. Dec 27, 2022 at 8:20 AM
    go_cubbies22
    Ok- I’ll give that a try. I tried a wire brush to clean them out but guess it wasn’t enough to take care of the rust.
    Thanks for the help.
  8. Dec 27, 2022 at 8:52 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    If you've got rust inside that area due to the missing bolts, might be the time to spray some Fluid Film or WoolWax inside there first before closing off the area with the bolts. Ounce of prevention and all that.
    LS3 and NewImprovedRon like this.
  9. Dec 27, 2022 at 9:17 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Yup. Tap the bolt holes to clean them up. They look pretty rusty and are probably preventing the bolts from threading in. Use the die, on the bolts only if you have to/ if you tried to force the bolts in just in case you messed up the threads on them.
    LS3 likes this.
