UltraGauge vs ScanGauge
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueBottle, Apr 18, 2017.
  1. Apr 18, 2017 at 3:18 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    I have been looking both of these. Just for added monitoring gauges. Are they worth it?
    Let's see what you have, how you have it mounted, and if they are worth it or not.
    What guages do you normally monitor?
    Which one is better? UltraGauge or ScanGauge?
  2. Apr 18, 2017 at 4:12 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    831Tun, Filthyphil, 040Tundra and 2 others like this.
  3. Apr 18, 2017 at 4:35 PM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    The Ultra guage will Not give you trans temp if you are needeing that. The Scan guage Will.
    BlueBottle[OP] likes this.
  4. Apr 18, 2017 at 5:13 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    :anonymous:
    Haha I got everyone spelling gauge wrong. Thanks for the tip though. Good to know.
    :transformer:
  5. Apr 18, 2017 at 5:15 PM
    sull1820
    sull1820 New Member
    Dave
    2017 CM TRD OR
    Trd Pro Dual Exhaust
    I have the ultra guage. I really like having it. I just installed it in to my Tundra. Not sure if you can program it to show Trans temp for the tundra but I did it in my tacoma. I have the window suction mount and really like having it.
    mudslinger79 and BlueBottle[OP] like this.
  6. Apr 18, 2017 at 8:28 PM
    TTund16
    TTund16 New Member
    I have a scan gauge to monitor trans temps once in a while. it is not mounted and I lay it down near the shifter. the cable that comes with it is very stiff I am looking to find a shorter & softer cable or maybe make one myself. u can monitor up to 4 and I have trans torque converter and pan temps and coolant temp and intake temp. sometimes I switch intake temp with voltage.
  7. Apr 19, 2017 at 6:48 AM
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    I use the Ultra Gauge to monitor the transmission temp on my Tundra (it also worked on my Tacoma).
    This is for the Ultragauge MX 1.3, the other version does not allow you to program it.
    The Blue ( Bluetooth version) that works with a cellphone also can be setup to do this. But we did not want to rely on a phone .
    Ultragauge codes
    Codes for 2012-2015 Converter Lock Up:
    TDATA: 07E02182
    MTCH: 6182
    RPOS: 1F01
    RCTRL:21
    TCTRL:92
    X: 0001
    /: 0001
    +: 0000
    Output format: 00
    AVE: 00
    Left/Right is 30
    Codes for 2012-2015 Trans temps *F: TC Torque Converter
    TDATA: 07E02182
    MTCH: 6182
    RPOS: 2808
    RCTRL:21
    TCTRL:92
    X: 0009
    /: 0005
    +: FFD8
    Output format: 00
    Left/Right is 31
    Codes for 2012-2015 Trans temps *F: Transmission oil Pan
    TDATA: 07E02182
    MTCH: 6182
    RPOS: 1808
    RCTRL:21
    TCTRL:92
    X: 0009
    /: 0005
    +: FFD8
    Output format: 00
    Left/Right is 31
  8. Apr 19, 2017 at 9:43 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Great information!!!! Thanks!
    Are the temps accurate?
  9. Apr 19, 2017 at 9:49 AM
    ramonortiz55
    ramonortiz55 I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
    You said Tacomas - is your Tacoma a second gen?
  10. Apr 19, 2017 at 10:16 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i have the ultragauge in my tundra. i like it. also run one in my excursion..would love to have trans temp for my 08. any love for my year with trans code?
  11. Apr 20, 2017 at 2:47 AM
    TTund16
    TTund16 New Member
    ATHiker,
    FYI
    there is some similarities (as it should be) between ultragauge and scangauge code.
    scangaugeII TDATA is same, anything after TCTRL is the same. that is I have programmed the same data 00090005FFD8
    for oil pan I have 2808 and you have 1808, for TC I have 3808 and you have 2808 !!!
    anyways I may be comparing apples and oranges ... as I have mentioned before, I got my code from HTGreen thread on this site.
    question:
    Just curious what is the output of Torque Converter lockup? is it Yes/No?
    I may try to program that into scangauge see if it works. I can tell if it is locked or not but a displayed msg would be nice also.
    when I bought the scangaugeII, I don't think ultragauge had trans temp so I did not give it a consideration. I like the big display of ultragauge.
  12. May 5, 2018 at 6:14 AM
    Yota18
    Yota18 Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    So are people running the codes for a 2012-2015 tundra for a 2016+ or was the general consensus that ultragauge doesn’t work the 2016+ for trans temps?
    These are the codes for trans temps from ultra gauges web site but I’m still getting error
  13. May 5, 2018 at 11:00 AM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    Just switched to the 2012-2015 codes and they're working for me.
    NewImprovedRon likes this.
  14. May 5, 2018 at 12:12 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    I have the Ultra gauge in my 1st gen. Had it in my Xterra before that. I'm pretty happy with it.
  15. May 9, 2018 at 1:46 AM
    Yota18
    Yota18 Inferno Club
    Stock
    I just switched to the 12-15 codes as well and are now reading a number at least. I just finished wiring up the ultra gauge so when I get home I’ll mount it. Curious if they are ‘real’ representive numbers or not we’ll see
  16. May 10, 2018 at 10:23 AM
    Wintyfresh
    Ramona, CA
    Having observed them for several days now I'm positive they're correct.
  17. May 10, 2018 at 10:26 AM
    Yota18
    Yota18 Inferno Club
    Stock
    Ya I’ve had it in two days now, from what a few other post I read state they seem normal tc spikes, pan stays fairly steady but runs high
  18. May 10, 2018 at 10:27 AM
    Wintyfresh
    Ramona, CA
    Have you pinned the Trans T-stat?
  19. May 10, 2018 at 10:28 AM
    Yota18
    Yota18 Inferno Club
    Stock
    No thinking about it saw that post too. I’ll run it without for a bit get a base line then do it.
    TTund16 likes this.
  20. May 10, 2018 at 10:46 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    have you looked into any of the apps? your phone is already in the car so why not use that as the display rather than mounting another unit?
    both of these run on iOS or that other one with the little green guy.
    https://www.plxdevices.com/Kiwi-OBD-OBDII-Interface-Gauges-Scan-tool-Diagnostics-s/195.htm
    http://www.palmerperformance.com/products/dashcommand/iphone/index.php
    there are a number of others.
  21. May 10, 2018 at 10:47 PM
    TTund16
    TTund16 New Member
    your readings are in typical range of my scangauge. Not that it proves anything, they both could be off/wrong since the codes are very similar ... But most likely we can assume they are correct since I can't think of any other way to verify the readings :pccoffee:
    I like the digital readout of gmc!
  22. May 10, 2018 at 11:48 PM
    Yota18
    Yota18 Inferno Club
    Stock
    True. We’ll see I’m curious as to how much the higher temp helps with gas mileage. Ima run it as is for a while see what I’m getting gas mileage wise then attempt to pin the thermostat and see how much cooler and how much worst the gas mileage gets. Apparently the higher tranny running temps where Toyota’s way of improving gas mileage
  23. May 11, 2018 at 10:16 AM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    exactly! i run torque pro on my green guy phone. phone mounts in a proclip and i think is the perfect spot! very customizable and perfect placement!
  24. Dec 4, 2018 at 6:15 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Now that we have had a group buy, how do you guys like the Ultragauge?
    I did something that might be different from most, I put my SG2 back in my truck and put the UG in my GTI since it apparently can do air fuel ratio. I still need to do a lot of calibration but it was sending me low fuel alarms when I had a quarter tank. Then it sent an RPM alarm when I hit 4k RPM, but I fixed that one. Same day it gave a speed alarm when I hit.... well, double the speed limit for Canada, but I don't live in Canada. I looked to my wife and said this thing is worse than you! She likes it.
    Too early to compare it with the trusted SG2.
  25. Dec 12, 2018 at 11:38 AM
    Yota18
    Yota18 Inferno Club
    Stock
    I like mine. Take the time to set it up and turn off the stupid alarms and good to go. I had mine from my taco though so. I only use it for the tranny temps. The truck comes with pretty much everything else I’d need.
  26. Dec 12, 2018 at 12:28 PM
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    I have had the UltraGuage for 5+ years. If you are into tuning and real time performance monitoring, they help. I went with UG over SG due to pricing. SG is at least double of UG last time I checked. After a while it became a novelty item for me, so it's just sitting in a box now. There are wireless OBDII devices which work equally well and are probably cheaper. I have used TorquePro and it can be customized just the UG.
  27. Dec 12, 2018 at 1:41 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I have been using a sg on my daily(civic si) and I like it.
  28. Jan 8, 2019 at 2:45 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    I have been running a SGII on my Tacoma for 5 years.
    It was absolutely essential to monitor Trans-temps when towing.
    At the time I was towing a 5000lb 6.5'tall tandem enclosed which was sucking the life out of my Tacoma.
    It has helped me troubleshoot coilpack issues, monitor voltage, clear codes,
    I like the SGII for the code reader / customizable screen color/ programmable Xgauge.
    I purchase a 2nd unit for my Tundra recently.
    If you watch or sign-up for Advance Auto emails, they send out 25% off coupons every so often.
    With Bank of America Cash back deals and 25% off coupon I scored a SCII for 118$
  29. Feb 18, 2019 at 2:01 PM
    socal147
    socal147 None Specified
    Patrick
    Oak Hills Commiefornia
    2019 Tundra Tonka
    Stock is so temporary
    I just ordered the blue. I did not want to add a gauge cluster to the truck. Have had SG in the past. It was ok, did the job
  30. Aug 12, 2019 at 1:12 PM
    woodywoodward
    woodywoodward New Member
    Josh
    2018 TRD OFF Road Tundra
    bone stock
    Does anyone have the scan gauge codes for the pan and TC for a 18' 5.7?
