Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Feb 5, 2020 at 8:27 AM
    #2461
    kwsprouse
    kwsprouse New Member
    Kevin
    2019 Tundra TSS
    Can you send me the link for this part?
  2. Feb 5, 2020 at 8:33 AM
    #2462
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    GODZILLA likes this.
  3. Feb 5, 2020 at 8:36 AM
    #2463
    kwsprouse
    Kevin
    2019 Tundra TSS
    Roman[QUOTED][OP] and GODZILLA like this.
  4. Feb 5, 2020 at 9:02 AM
    #2464
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Yessir! Most definitely the 4x A0219. Second order inbound. Thanks! I didn't realize they're the same same as the front most hitch bolts.
    Roman[QUOTED][OP] likes this.
  5. Feb 5, 2020 at 10:38 AM
    #2465
    Roman
    Roman
    Franklin, TN
    Me either, and it's confusing too when looking for them in two different diagrams. I bet a lot of parts guys get confused on this one. :D
    blackoutt[QUOTED] likes this.
  6. Feb 5, 2020 at 12:21 PM
    #2466
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Can I get a part number for oem windshield wipers, not the sight lines. But what they come from the factory with. 2017
  7. Feb 5, 2020 at 12:35 PM
    #2467
    Burdturger
    Burdturger New Member
    @Roman can assist.
    should be on page 1 of this thread
  8. Feb 5, 2020 at 2:07 PM
    #2468
    Roman
    Roman
    Franklin, TN
  9. Feb 5, 2020 at 2:14 PM
    #2469
    easleycrawler
    Travis
  10. Feb 5, 2020 at 3:30 PM
    #2470
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Amen to that. Very disappointed with this. Expected more from Toyota. Asking if headlights have replaceable bulbs is not a question most would ask, since headlights have had replaceable bulbs since the truck was invented. This information should be one of the first things stated about these headlights when you purchase them. Now, my Pro won't pass inspection until I replace it. Great. Just great. Less than a year old. Okay, rant is over.
  11. Feb 5, 2020 at 6:12 PM
    #2471
    Dodger46
    Dodger46 New Member
    2019 Silver Sky Metallic SR5 Crewmax
    Thank you for the info about the predator running boards
  12. Feb 6, 2020 at 6:54 AM
    #2472
    Roman
    Roman
    Franklin, TN
    That's probably my fault. I should have described the headlights better in the OP. I assumed it was common knowledge that all OEM LED headlights are integrated into the housing, and that's where I screwed up. I'm going to edit it now.
  13. Feb 6, 2020 at 12:08 PM
    #2473
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    @Roman I have a 2016 Limited DC. I know I lose BSM if I buy the power folding tow mirrors (plan on adding it back myself w/ sail panel LED), but do I lose cross traffic alert, too?
  14. Feb 6, 2020 at 12:29 PM
    #2474
    Roman
    Roman
    Franklin, TN
    Yes sir, you will lose cross traffic alert as well.
  15. Feb 6, 2020 at 1:45 PM
    #2475
    Uhhhh....
    Dave
    7” BDS, 37s
    That stinks. Thanks for the info. Do you know why? There's cross traffic sensors in the regular mirrors that aren't in tow?
  16. Feb 6, 2020 at 2:46 PM
    #2476
    Roman
    Roman
    Franklin, TN
    They haven't changed part numbers on the tow mirrors since 2007 when they released them. Toyota, for whatever reason, just hasn't updated the tow mirrors like they have with the stock ones.
  17. Feb 7, 2020 at 5:12 AM
    #2477
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    Good morning, Roman.
    Hoping you can help me out as I have exhausted the parts fiche.
    I cannot explain the rationality of the previous owner, but he removed the lower inside body mount for the headlights. The headlights mount at four different point: two screws at the top, a hidden bolt behind the lower headlight trims by the fender, and the part I am missing which bolts to the radiator support frame.
    These are located, if looking at the headlights, on the lower inside. The headlights have a ramp-style retention clip that slides onto this part. I am missing both sides and was hoping you could find the part numbers better than I.
    2011 DC SR5 5.7 4x4 non-ffv
    thanks
    edit: it is the metal piece in the pic below
  18. Feb 7, 2020 at 6:47 AM
    #2478
    Roman
    Roman
    Franklin, TN
    That's an odd part to remove. Here's both sides:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-mount-bracket-539050c010
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-mount-bracket-539060c010
    focal[QUOTED] likes this.
  19. Feb 7, 2020 at 6:56 AM
    #2479
    focal
    Nikolai
    VA / NC
    After looking at my truck and then my buddies, I think the previous owner may have removed it with the bumper because it looks like it ties the headlight, radiator support, and bumper together. There is an aftermarket bumper on the truck.
    Thanks so much. You are heaven-sent!
  20. Feb 9, 2020 at 3:53 AM
    #2480
    Phillip
    Phillip New Member
    Phillip
    2016 crewmax
    Hey there Roman I tried to see if someone else posted the info but can’t find it… I see all the hood scoop information but do you have a quick total for all the parts needed and an estimate of shipping to Phoenix? just a ballpark on shipping?
  21. Feb 9, 2020 at 4:25 PM
    #2481
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    Hey Roman, can you help me find the brackets needed for the factory running boards (part # PT212-3407) on my 2020 Platinum Crewmax...had a little mishap and bent the mounting brackets on the passenger side running board, especially the front 2 brackets (one closest to front passenger tire and the next one)...thanks in advance!
  22. Feb 9, 2020 at 9:04 PM
    #2482
    easleycrawler
    Travis
    I can help you out a little bit. As far as the piece below the headlight, you will need to have it painted. As for the exhaust tip, if you have the 5.7 it should fit. I had the Toyota chrome tip and it fit perfect, no difference except color.
  23. Feb 10, 2020 at 7:41 AM
    #2483
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    @Roman I am in need of the bolts that fasten the bumper cover to the truck...the 4 silver bolts (2 on each side) that are on top of the bumper cover...also think they are the same bolts as the bottom ones under the end caps...Thank you!
  24. Feb 10, 2020 at 9:39 AM
    #2484
    Roman
    Roman
    Franklin, TN
    Once you add all of those parts in the OP to your shopping cart on the site, you can then enter your zip code for a shipping quote.
  25. Feb 10, 2020 at 9:44 AM
    #2485
    Roman
    Roman
    Franklin, TN
    Are you talking about the stainless step boards with the black step pads?
  26. Feb 10, 2020 at 9:45 AM
    #2486
    Roman
    Roman
    Franklin, TN
    It would have to be painted.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-extension-panel-539310c903
    Here's a link to the black chrome exhaust tip:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tundra-exhaust-tip-black-pt9323418002
  27. Feb 10, 2020 at 9:47 AM
    #2487
    Roman
    Roman
    Franklin, TN
    LogCabins[QUOTED] likes this.
  28. Feb 10, 2020 at 10:21 AM
    #2488
    LogCabins
    'Merica
    2017 TRD Pro
  29. Feb 10, 2020 at 7:01 PM
    #2489
    2020Platinum
    Patrick
    Northeast PA
    Yes sir, here’s a pic of the ones I’m referring to, thanks again!
    Deafmate likes this.
  30. Feb 10, 2020 at 8:04 PM
    #2490
    easleycrawler
    Travis
    Holy shit, zero gravity.
    yoshi82, Mcoop and PKFan like this.
