Ultimate OEM Toyota parts thread
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Apr 9, 2019 at 7:19 AM
    #1741
    Cdorman
    Cdorman New Member
    Oklahoma
    2015 - SR5 - CM - MGM
    Color match MGM Bulge/Grille Trim Pro Grille TRD Pro Headlights(black) OEM led fog lights upgrade Headlight Revolution HID upgrade TVD vinyl decals Fog lights Always MOD Bilstein 5100’s 12Volts remote start kit PowerBass plug/play speaker upgrade
    Trying to find drip molding for drivers side on the website but not having any luck. Could you post the link for me please
  2. Apr 9, 2019 at 7:49 AM
    #1742
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    @KLLVMDCL hey if you go on their website and just do a search for tundra door handles they show up for purchase. I’m assuming they changed the link
  3. Apr 9, 2019 at 7:51 AM
    #1743
    YsoSeRiouS!
    NorCaL
  4. Apr 9, 2019 at 8:01 AM
    #1744
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Had to update our URLs since the website changed. Should be good to go now.
    YsoSeRiouS! likes this.
  5. Apr 9, 2019 at 8:04 AM
    #1745
    Roman
    Roman
    Franklin, TN
    Looks like it should be here on 4/13, so not too bad at all. Hopefully, this means Toyota is getting on the ball and will have plenty Cavalry Blue grilles available soon.
  6. Apr 9, 2019 at 8:05 AM
    #1746
    Roman
    Roman
    Franklin, TN
    Unfortunately, they only sell those in the hardware kit. I'd hit up a local bolt shop if you are only needing the one.
    KnuckleHD likes this.
  7. Apr 9, 2019 at 8:05 AM
    #1747
    Roman
    Roman
    Franklin, TN
    Yep, I just had to update the URLs in the OP. They should be good now.
  8. Apr 9, 2019 at 8:08 AM
    #1748
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Thank you sir! Any way to find out the dimensions of the bolt? I can’t really remove it without taking the whole plate off. Thanks!
  9. Apr 9, 2019 at 8:42 AM
    #1749
    YsoSeRiouS!
    NorCaL
    @Roman thanks just ordered #45710
    Roman [OP] likes this.
  10. Apr 9, 2019 at 8:49 AM
    #1750
    Roman
    Roman
    Franklin, TN
    I'm having a tough time finding them as well. What are they for? Do you have any pictures of them out of the package? There are only bolts holding the bed rails in, and the cleats go into the rails, but there is no additional hardware showing to be available other than that.
  11. Apr 9, 2019 at 8:54 AM
    #1751
    Roman
    Roman
    Franklin, TN
    The nut is a 15mm hex M10. It just says the bolt is a 5mm allen head and does not give a length.
  12. Apr 9, 2019 at 10:01 AM
    #1752
    KnuckleHD
    Okay that works, I can “guesstimate” the length. Thank you!
  13. Apr 9, 2019 at 12:59 PM
    #1753
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, WARN 9.5XP-S Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    Thanks for the response @Roman!
    Actually I just need the cleats that go into the bed rail and their bolts... should be something like these..
    Thanks!
  14. Apr 9, 2019 at 2:24 PM
    #1754
    Roman
    Roman
    Franklin, TN
    Those look like what comes on the back of the cleats to slide into the rails.
  15. Apr 9, 2019 at 2:36 PM
    #1755
    KnuckleHD
    Is that a Toyota part? Looks kind of like the brackets they use to install tonneau covers with the bed rails.
  16. Apr 9, 2019 at 2:38 PM
    #1756
    Roman
    Roman
    Franklin, TN
    I can't find just those things by themselves anywhere.
  17. Apr 9, 2019 at 3:20 PM
    #1757
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
  18. Apr 9, 2019 at 3:42 PM
    #1758
    1794-BlackTundra
    Sergio
    Watt maker likes this.
  19. Apr 10, 2019 at 2:36 PM
    #1759
    easleycrawler
    easleycrawler TOYOTA ADDICT
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    @Roman
    I placed a order for a set of TRD PRO wheel center caps. Do you have those in stock? If not, how long should it take to get them?
  20. Apr 10, 2019 at 4:01 PM
    #1760
    YsoSeRiouS!
    NorCaL
    Just got my tracking number @Roman sweeeeettt!
  21. Apr 10, 2019 at 4:15 PM
    #1761
    Aaron1023
    Aaron1023 New Member
    Do you know where I can buy oem bed lights for my 2019.
  22. Apr 11, 2019 at 7:48 AM
    #1762
    Roman
    Roman
    Franklin, TN
    The earlier model center caps? We should have those in stock. If we're out of them by chance, we should be able to order them in within a day or so.
  23. Apr 11, 2019 at 7:51 AM
    #1763
    Roman
    Roman
    Franklin, TN
    Toyota just recently added bed lighting for the Tundra to the accessory catalog, but they have not been made available yet. Currently, there is no ETA.
  24. Apr 11, 2019 at 9:41 AM
    #1764
    easleycrawler
    Travis
    This is the part number. PT280-34150
  25. Apr 11, 2019 at 10:48 AM
    #1765
    easleycrawler
    Travis
    Got shipping notification today. Thanks
  26. Apr 11, 2019 at 7:02 PM
    #1766
    Aaron1023
    Thank you for the response. That’s kinda what I thought someone else that works in Toyota parts told me that Toyota will start shipping the led bed lights mid August when the 20s come out. The led lights are in production now. I will check back with you in a few months. Thanks again.
  27. Apr 11, 2019 at 8:00 PM
    #1767
    goldldr
    goldldr New Member
    Andy
    Spring,TX
    2019 SR5 CrewMax (Cavalry Blue)
    Sorry ahead of time if these are stupid questions, but this is all pretty new to me.
    I have a 2019 SR5 crew cab, and I am interested in replacing the stock headlights (halogen with single LED drl) with the trd led lamps. Is this plug and play, or do I need a harness of some sort? I assume they will fit in the same space as my halogens. If I buy the led headlamps, do they come with bulbs or do I need to purchase separately?
  28. Apr 11, 2019 at 8:22 PM
    #1768
    goldldr
    goldldr New Member
    Andy
    Spring,TX
    Thanks, Ron! I will check that out.
  29. Apr 12, 2019 at 11:30 AM
    #1769
    Black@Blue19
    Black@Blue19 New Member
    Ken
    45 Gulf Freeway Galveston County
    19Tundra TRD Sport 4X4 CrewMAX
    TRD upgrades, everything except leather, sunroof, and electric passenger seat
    TRD guy called today and stated that on the Flex Fuel Trucks they are still testing and have to get approval for the TRD Cold Air Intake Upgrade. Once testing is over and they get approval then there will be TRD Cold Air intake parts numbers at dealers but did not have a time line??
  30. Apr 12, 2019 at 1:23 PM
    #1770
    Jrharvey02
    Jrharvey02 Meh.
    Skyland Village, Colorado
    2010 Tundra CM 5.7FFV Platinum Dark Black
    A.R.E. Topper, Clifford Remote Start/Alarm, Pioneer Avic8200-NEX Entertainment System, Passport 9500ix Radar Detector, Compustar Dash Front and Rear View Cameras, ADVX Rear view mirror camera, front grille camera, JL Audio 10” sub, Focal 6.5”, Thule Rack Mounts & Rocky Mounts Basket, Dual Batteries, Bedrug Bedliner, LED Bed Lights, TRD Sport Shocks, TRD rear sway bar. Custom Fitted Denver Outfitters Fly Rod Vault, BreezeGuard rear pet screens, DTMoto Headlights, color-matched aftermarket grille
    @Roman
    Hey, my 2010 Platinum 5.7 crew max has the gaudy fake wood plastic trim on all 4 doors surrounding the power window controls. I want to switch all 4 doors to gray like in picture...parts please? Thank you.
