Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Feb 11, 2021 at 10:19 AM
    #3391
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    @Roman is there a part number associated with just ATF hose circled?
    Thank you.
  2. Feb 11, 2021 at 11:13 AM
    #3392
    PhilActual
    PhilActual New Member
    Phil
    2018 Doublecab SR5 5.7 4x4
    SDHQ ABS guards, Hondo Garage/Ram phone/GPS mounts, 275/65r18 duratracs
    That's great info @Roman ! I appreciate the response. Can I get a part # just in case?
  3. Feb 15, 2021 at 10:01 AM
    #3393
    Lyon
    Lyon New Member
    2018 Tundra Limited
    Thanks so much for all of the great service @Roman. I'm new here and have been following quite a bit, but do have a quick questions if anyone can help me out.
    I have a 2018 Limited with TSS and whatnot, with the full chrome grill. I'd like to change out for either the platinum without chrome or the 2019+ PRO grill. If changing to the platinum grill, I know I'd need the new sensor, as mine is the old style. Would this be the case for the PRO grill as well? I'm trying to decide which is cheaper and easier to change to.
    Thanks!
    French Avocado likes this.
  4. Feb 24, 2021 at 7:48 AM
    #3394
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Just checked, and it looks like the new and reman options are discontinued.
    32941-0C060
    T'would be 58510-0C472-C0
    ElNopal[QUOTED] likes this.
  5. Feb 24, 2021 at 6:59 PM
    #3395
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    Where are you located? I have a contact that rebuilds LC steering boxes
  6. Feb 25, 2021 at 5:19 AM
    #3396
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I’m in Southeast Idaho.
  7. Feb 25, 2021 at 5:43 AM
    #3397
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Great thread, thanks.
    Now, if you can find me the 6 way power mudflaps it will be just perfect..
  8. Feb 25, 2021 at 8:38 AM
    #3398
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    4" Pro Comp Lift 35x12.50x20 Toyo RT's 20x9 +20 Fuel Mavericks Rough Country soft tri-fold bed cover LED headlight and Fogs with LEDs throughout the cab as well
  9. Mar 2, 2021 at 4:59 PM
    #3399
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    TRD Pro Wheels
    What is the difference between PT960-34200-02 ($610 list) and PT960-34190-02 ($811 list)?
    I understand both are the BBS forged TRD Pro wheels but there is a big price difference?
    Will these wheels fit on a 2020 Platinum? There seems to be some discussion about larger brakes on the Plats and wheels not fitting.
    Thanks.
  10. Mar 2, 2021 at 6:57 PM
    #3400
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    This is what the cheaper one has marked on it, and the marking along with the “BBS Forged” writing on the other side is all black.
    The more expensive one is the actual TRD Pro wheel, and that spot is machined flat/silver with black “PRO” in the middle, and the “BBS Forged” words on the other side are engraved silver.
    At least you asked the question before buying - I know a few others have been unpleasantly surprised when their order showed up...
  11. Mar 2, 2021 at 10:05 PM
    #3401
    French Avocado
    Utah / Wyo
    Thanks Casey. Any idea about using the 18" Pro wheels on the Platinum and whether they interfere with the brakes?
  12. Mar 3, 2021 at 4:58 AM
    #3402
    RainMan_PNW
    Casey
    Clark County, WA
    Unless you’ve got the Big Brake Kit (not standard for any trim), you should be good to go. As far as I know, all the trucks use the same brakes.
  13. Mar 3, 2021 at 5:34 AM
    #3403
    Ericsopa
    Ericsopa Old man and the sea
    @Roman .... Is Toyota no longer supporting the DVD nav systems with upgraded map data DVDs? I think the one I have is a 2018 version, and it's missing a lot of new roads, etc.
  14. Mar 3, 2021 at 8:17 AM
    #3404
    French Avocado
    Utah / Wyo
    Thanks
  15. Mar 4, 2021 at 7:38 AM
    #3405
    azTony
    Tony
    Sun Lakes, AZ
    I am in the same boat, 2018 and a Nav that is not current
  16. Mar 4, 2021 at 4:47 PM
    #3406
    Midnight66
    Midnight66 New Member
    Georgia
    2021 Super White Limited/TRD Off RD
    @Roman is there an avenue available to order from you right now since the online store is not working? I need a TRD Pro grille, sensor cover, hood bulge, and mirror caps for a ‘21 in super white.
  17. Mar 5, 2021 at 1:54 PM
    #3407
    twin_boys_tundra
    twin_boys_tundra New Member
    Terry
    San Jose, CA
    2020 Super White SR5 2WD
    2020 Tundra SR5 Super White * Chrome Mirror Caps and Door Handles * Bedrug Mat and Tailgate * Toyota Running Boards (Free Love It) * Toyota 20" Limited Alloy Wheels and Tires (Free Love It) * All LED conversion * FRAC Harness * Toyota Power Tailgate Lock * Bakflip G2 * Bull Ring Stake Pockets * Tech12Volt Kenwood/Hertz full audio combo * Bilstein 6112/5160 in the works, maybe Black Friday special * BAM 10" Std
  18. Mar 6, 2021 at 11:22 AM
    #3408
    Anyone know the part number for the passenger seat rear outer bolt cover?
  19. Mar 8, 2021 at 8:35 PM
    #3409
    CheeseTaco02
    CheeseTaco02 New Member
    PA
    2020 Tundra Voodoo Blue Crewmax Limited TRD
    Sign me up for one of those folks "unpleasantly surprised", I ended up ordering the "fake" ones last year from Cool Springs..... why would they, Toyota market 2 different sets?
    Maybe they are not fake, but just feel a bit blindsided. Thought I did my research... Is there any manufacturing difference between the 2?
  20. Mar 8, 2021 at 8:41 PM
    #3410
    RainMan_PNW
    Casey
    Clark County, WA
    No idea... don’t look any different except the machining and the label
  21. Mar 9, 2021 at 7:11 AM
    #3411
    Mgmtundra
    Mgmtundra MGM Crew
    @Roman any chance you can source this PTR18-35092?
  22. Mar 9, 2021 at 1:19 PM
    #3412
    French Avocado
    Utah / Wyo
    @CheeseTaco02 - Sparks Parts tells me that both are official TRD Pro wheels and neither is a "fake" or a "forgery" with "minimal" differences between the two. When asked why the large price difference, Sparks' comment is that Sparks assumes that they are different OEM manufacturers but that Toyota does not state or provide detail on that point. Obviously important for someone replacing a wheel but not important for someone purchasing a full set.
    @Roman have any information on the topic? Anyone know who makes the wheels for Toyota?
  23. Mar 9, 2021 at 1:31 PM
    #3413
    RainMan_PNW
    Casey
    Clark County, WA
    The TRD Pro wheels are made by BBS. The difference is that one is authentic to the TRD Pro trim, and the other is a TRD accessory. Want to really blow your mind, the exact same rim powder coated Bronze with a Toyota center cap is exclusive to the heritage edition Land Cruiser and can only be ordered if you have a valid VIN number to match it.
  24. Mar 9, 2021 at 3:39 PM
    #3414
    French Avocado
    Utah / Wyo
    Mind blown
    RainMan_PNW[QUOTED] likes this.
  25. Mar 10, 2021 at 6:32 AM
    #3415
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    The links in the first post aren't working for me. Can someone direct me to the correct website?
  26. Mar 10, 2021 at 6:48 AM
    #3416
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Page isn’t open again, yet.
  27. Mar 10, 2021 at 11:51 AM
    #3417
    Anyone have the part number to the white clips that hold the dash together?
  28. Mar 11, 2021 at 11:39 AM
    #3418
    xnaron
    xnaron New Member
  29. Mar 11, 2021 at 11:39 AM
    #3419
    TundraWife
    TundraWife New Member
    Candace
    2020 Quicksand Tundra Crewmax Limited
    Color matched mirror caps. Soon to do color matched bumper end caps.
    I called Toyota of Cool Springs, was told they shut down their online parts page. I was told to call if I needed to order anything. Anyone else have this experience? I am looking for textured black door handle covers for the hubs 2020 Tundra Crewmax. Any help is greatly appreciated!
  30. Mar 11, 2021 at 5:23 PM
    #3420
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    I'm waiting also
