Ugh, how screwed am I? Coilover help/oil leaking
Discussion in 'Suspension' started by d0zer, Jan 15, 2018.
  1. Jan 15, 2018 at 7:04 AM
    d0zer
    d0zer [OP] I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Whelp, I went to adjust the hoses that run to my coilover reservoirs as they were making some minimal contact with the spring. I break it loose and it starts shooting oil everywhere, as soon as I've come to my senses there is a puddle of about 6-8 oz of suspension oil on the ground. To make matters worse thinking I learned my lesson on the drivers side, I slip the wrench on the passengers side and lose about 3 oz.
    I've probably lost all my nitrogen that charges the coilovers i'm just wondering if I've lost enough oil where I need to get them pulled off and refilled.
    They are ADS 3.0" coilvers with clicker adjusters.
  2. Jan 15, 2018 at 7:19 AM
    What city / state are you in?
  3. Jan 15, 2018 at 7:26 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Just send em in for recharge. Just going to have to live with some down time.
    joonbug likes this.
  4. Jan 15, 2018 at 7:41 AM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    You can purchase a nitrogen shock refill kit, but yeah, your oil levels are also going to be wrong now. You could put a little N2 into it for now until you can have them rebuilt, but I wouldn't push them real hard. Losing oil means the N2/oil separator piston is going to ride in a different spot - I don't know how good that is for wear.
    Black Wolf and TXMiamiFan like this.
  5. Jan 15, 2018 at 7:58 AM
    d0zer
    2017 MGM Platinum
    @Sean266 , live in Phoenix AZ.
    @KevinK , I was going to call @sdhq_offroad and see if I could bring it by, they should be able to charge with N2?
    TheBeast and T-Rex266 like this.
  6. Jan 15, 2018 at 9:57 AM
    KevinK
    Tundras to Sedona
    Well shit. I live in Gilbert and have N2...
    I need to refill my bottle this week. Come over and I’ll fill them for you. But SDHQ should be able to pressurize them too. They’re about 2 miles from me.
  7. Jan 15, 2018 at 9:57 AM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Did you adjust them with the weight of the truck on them? Or jacked up off the floor?
    Black Wolf and TheBeast like this.
  8. Jan 15, 2018 at 10:21 AM
    KevinK
    Tundras to Sedona
    I just looked. I may have enough to get a couple hundred lbs in each side if you wanna come over today.
    480-455-0091
    Send nudes
    Slayer, 14burrito, Black Wolf and 6 others like this.
  9. Jan 15, 2018 at 11:14 AM
    d0zer
    2017 MGM Platinum
    Will send you a note.
  10. Jan 15, 2018 at 11:27 AM
    KevinK
    Tundras to Sedona
    Don’t forget the nooooods.
  11. Jan 15, 2018 at 11:28 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    send some noods this way too while you are at it.. @KevinK cant get all the glory...
    Tacotundra likes this.
  12. Jan 15, 2018 at 11:30 AM
    KevinK
    Tundras to Sedona
    I’ll forward anything good if you don’t get any.
    :thumbsup:
    dcsleeper408[QUOTED] likes this.
  13. Jan 15, 2018 at 1:18 PM
    d0zer
    2017 MGM Platinum
    Thanks guys, nudes all around. Will swing by Kevin's today and evaluate after re-pressurizing.
    Black Wolf and dcsleeper408 like this.
  14. Jan 15, 2018 at 1:19 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    good luck! hope it works out... dont forget the noooooodz
  15. Jan 15, 2018 at 1:48 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I wanna see:broccoli:
    Black Wolf likes this.
  16. Jan 15, 2018 at 6:06 PM
    d0zer
    2017 MGM Platinum
    @KevinK is the man. Nudes were scarce, but fear those 37s and all those suspensions, they will eat you up, for real. We even figured out how to use his special leak-less valve. Will see how this plays out and either let SDHQ or ADS fix any lasting issues.
    Such a great forum.
    KevinK, Black Wolf and ColoradoTJ like this.
  17. Jan 15, 2018 at 6:12 PM
    I would so get your own N2 kit, oil and tooling. So. Easy.
    KevinK likes this.
