UCA's for Toytec 3"
Discussion in 'Suspension' started by Gtundra86, Dec 6, 2018.
  1. Dec 6, 2018 at 1:55 PM
    Gtundra86
    Gtundra86 [OP] New Member
    Garrett
    2012 Tundra TRD 4x4
    Guys I have a 2012 Tundra 4x4 TRD. I am going to put The ToyTec/Eibach 3" coilovers on the front end. Do you think I will have to get new UCA's? I would rather not have to spend the $600 on some Camburgs at this point.
  2. Dec 6, 2018 at 2:05 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Its a good recommendation to insure proper alignment the first time without any issues. However, we have seen a lot of people/ installed a lot of kits that retain their factory uppers and we are able to align them just fine.
    Just something to think about down the road honestly..
    Stroke250 and Erichudgins like this.
  3. Dec 6, 2018 at 2:07 PM
    If you do, ToyTec has solid SPC UCA's that won't break the bank. Right ToyTec?
    Erichudgins likes this.
  4. Dec 6, 2018 at 2:10 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I got the ToyTec BOSS 3/1 on my truck....for my own piece of mind (and because of what ToyTec said above) I bought the SPC adjustable UCAs
    Black Wolf likes this.
  5. Dec 6, 2018 at 2:15 PM
    YZTundy
    YZTundy New Member
    Denver, Co
    2011 Crewmax Rock Warrior
    SPC's are the way to go!
    15Yota and Black Wolf like this.
  6. Dec 6, 2018 at 2:17 PM
    Made in Longmont, Colorado too!
    YZTundy[QUOTED] likes this.
  7. Dec 6, 2018 at 2:26 PM
    fliberto38
    fliberto38 New Member
    Ft. Worth, Texas
    2019 Silver Tundra TSS Off-Road
    Toytec/Radflo coil overs, SPC UCAs, Diff drop, Toytec/Deaver AAL, Toytec Boss rear shocks
    We install a lot of 3/1 kits on Tundras. A good tech doing the alignment can get it into acceptable range. But usually just barely. With the SPCs you can get it perfect.
    4x4_Angel and 15Yota like this.
  8. Dec 6, 2018 at 2:28 PM
    Gtundra86
    Garrett
    2012 Tundra TRD 4x4
    Thank you for the input guys/girls!
    I am new of this site, and new to moding on my tundra. Appreciate all the help.
    4x4_Angel likes this.
  9. Dec 6, 2018 at 2:37 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    think of it like this...Like @Toytec Lifts said...its all about the alignment.. that being said, an alignment is gonna be 100ish bucks...if your having an install done go ahead and save yourself some cash and do the ucas.
    1. on the labor
    2. for another alignment if you happened to need the uppers after you get your first initial alignment.
    just my 2 cents tho.
    fliberto38 and 4x4_Angel like this.
  10. Dec 6, 2018 at 3:36 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    I have the BOSS coilovers and left my stock UCAs and my tech team was able to get me in the green for alignment. I am, however, awaiting on my ICON Tubular Delta Joint UCAs to arrive and will get those installed next week. I think in the long term I will be happier.
  11. Dec 6, 2018 at 3:43 PM
    Berkdawg
    Berkdawg New Member
    2013 Rock Warrior
    Clazzio Seat Covers, Eibach/Toytec Coil Overs (3"), Toytec Boss Rear Shocks, Firestone Airbags
    I just went with Eibach and used the same reasoning as Erichudgins after consulting the install shop and Toytec. Did anyone else notice a change in (improvement) on turning radius after the install of coil overs and SPC UCAs? I had rubbing on my factory skid plate because the tires seemed to turn in more. I do not want to put more stress on the components with over steering.
  12. Dec 6, 2018 at 3:46 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    I ran the Eibach 3/1 kit from @Toytec Lifts with stock UCAs without issues and it aligned fine.
  13. Dec 6, 2018 at 3:52 PM
    fliberto38
    Ft. Worth, Texas
    I just had the Radflo/Toytec coil overs and SPC UCAs installed on Monday, so I haven't had a chance to test the turn radius yet. My tech went ahead and trimmed the skid plate before reinstalling it. He does a lot of 3/1 spacer/block kits for us, so he does that on all of them.
    Berkdawg[QUOTED] likes this.
