UCA Clearance
Discussion in 'Wheels & Tires' started by McReef, Mar 6, 2017.
  1. Mar 6, 2017 at 8:13 AM
    McReef
    McReef [OP] '17 Tundra TRD Pro Crewmax
    Eastern MA
    Throwing my new shoes on, I have about a pinky's width of space between the rubber and the UCA's. This seems awefully tight, looks like I'll be picking up some spacers a little sooner than planned...
    How much space (minimum) do you think I should be looking for?
  2. Mar 6, 2017 at 8:29 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    FWIW: I've been running a pinky width for going on 2 years now. No rubbing or other issues. Not sure if there is a spec for minimum clearance there, but my guess, is you'd have to have a pretty big wobble for your tire to make contact.
    But to answer your question, I'd guess the minimum spacer width available would give you sufficient clearance to ease your concern.
  3. Mar 6, 2017 at 8:36 AM
    McReef
    Eastern MA
    That is interesting, maybe not as tight as I thought...
  4. Mar 6, 2017 at 8:45 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I think you'd be fine with a pinky. Although I would try airing down to about 20 psi and make sure you still clear. In case you ever need to air down or get a flat.
    McReef[OP] likes this.
  5. Mar 6, 2017 at 10:28 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Hehehehehehe you said pinky!!
  6. Mar 6, 2017 at 10:43 AM
    Some pinkies are bigger than others....
    zcarpenter92 and McReef[OP] like this.
  7. Mar 6, 2017 at 1:16 PM
    McReef
    Eastern MA
    LOL
    That's a good idea, I'll give it a shot...
  8. Mar 9, 2017 at 11:22 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    I have about that much clearance also. Good to know you've had no problems.
