UCA bolt not budging
Discussion in 'Suspension' started by smslavin, Aug 19, 2017.
  1. Aug 19, 2017 at 9:22 AM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Arg. Is there a trick or am I just not strong enough to break this thing loose? I've hit with Liquid Wrench and heat. The nut is not moving. With the brake lines right next to the nut, there isn't a whole lot of space. Ideas welcome.
  2. Aug 19, 2017 at 9:24 AM
    Have you tried a breaker bar? Sometimes they are on there pretty tight. Same for the LCA's.
  3. Aug 19, 2017 at 9:25 AM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Cheater bar, if you have a long hollow tube, throw it over the breaker bar or ratchet and you should be good.
    Black Wolf, smslavin[OP] and T-Rex266 like this.
  4. Aug 19, 2017 at 9:25 AM
    smslavin
    Hudson Valley
    Some stuff
    Would love to but I can't get the bar to fit in there with the socket.
  5. Aug 19, 2017 at 9:28 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Have you tried the other end? Sometimes the bolt head is easier than the nut
  6. Aug 19, 2017 at 9:36 AM
    chadjamesr
    chadjamesr New Member
    Chad
    Atlanta
    2016 Tundra Platinum 4x4 Crew Cab
    Fox 2.5 w/ DSC Remotes F&R Coach Builder +3 Shackles RW Wheels w/285/75/17 Terra Grappler G2 Interior and exterior changed to LED Retrofit headlights with DS2 4.0 Morimoto LED fog lights Morimoto 40" LED bar in front bumper Retrax PRO Tonneau cover RCI front skid plate Crystalline tint on all windows and windshield P&P Rock sliders and full skip plates
    When I changed out my UCA, I had to use a cheater bar on my breaker bar to get the nut loose. Ended up using the arm from the floor jack as my cheater bar. That nut was on crazy tight, even my impact wouldn't budge it.
  7. Aug 19, 2017 at 9:43 AM
    smslavin
    Hudson Valley
    Some stuff
    Yea. It moved a tiny bit. Working on it.
    Law323[QUOTED] likes this.
  8. Aug 19, 2017 at 9:47 AM
    If you need me to drop by to help get it loose- shoot me a pm. Headed down towards your way for an event off 136/85
  9. Aug 19, 2017 at 9:49 AM
    smslavin
    Hudson Valley
    Some stuff
    Seriously? You're awesome.
    Law323 likes this.
  10. Aug 19, 2017 at 9:51 AM
    Ya- Henderson right? PM me ur addy real quick
    SouthBoundSteve and Law323 like this.
  11. Aug 19, 2017 at 9:54 AM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Dammit Sean. I want a shirt.
  12. Aug 19, 2017 at 10:47 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Gotta love this forum huh? So many good people willing to lend a hand!
  13. Aug 19, 2017 at 11:26 AM
    Unfortunately our schedules couldn't align this weekend with time constraints on both ends. Another day and we'll figure it out.
    smslavin[OP] and 4x4_Angel like this.
  14. Aug 19, 2017 at 1:54 PM
    smslavin
    Hudson Valley
    Some stuff
    :cheers:
    T-Rex266[QUOTED] likes this.
  15. Aug 19, 2017 at 3:57 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Changed mine recently - 2nd Gen
    Sprayed liquid wrench overnight and again next morning.
    I used a 22mm 6-point closed wrench. Then used another large wrench to lock into the open end. Then slowly break nut.
  16. Aug 19, 2017 at 4:31 PM
    I have a long used catheter tube you can borrow.
  17. Aug 27, 2017 at 6:46 AM
    smslavin
    Hudson Valley
    Some stuff
    Got the nuts removed on both sides. Now, how do I get the bolt out? I'm stymied as there doesn't seem to be much room and I'm not sure what can be moved. The Haynes manual I have is zero help.
  18. Aug 27, 2017 at 6:55 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Pull the bolt out towards the battery (I think you have to remove it first) it's a long and aggravating sumbitch, but it can be done
  19. Aug 27, 2017 at 6:58 AM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Drivers side = remove battery, and loosen battery wire that is bolted to side (i think)
    Passenger side = thread through the hoses, helps with two people, or wiggle/push to try to get movement.
    The driver side was much easier than passenger for me.
    smslavin[QUOTED][OP] likes this.
  20. Aug 27, 2017 at 8:19 AM
    Les7311
  21. Aug 27, 2017 at 8:35 AM
    smslavin
    Hudson Valley
    Some stuff
    Got passenger side. Working on driver side. Thanks for the input. Finally feel like I'm making progress this morning.
    TheBeast and Black Wolf like this.
  22. Aug 27, 2017 at 8:46 AM
    Les7311
    Post a pic of what you working with.......
  23. Aug 27, 2017 at 10:12 AM
    smslavin
    Hudson Valley
    Some stuff
    Well. Shit. I think the driver side nut is either stripped or super stuck. It keeps bouncing between the third and fourth thread. Now what?
    Camburg Kinetik UCAs and King coilovers with remote resis. I think I need to go find a spring compressor to get these in there.
  24. Aug 27, 2017 at 10:16 AM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Your bolt is stripped between those threads.
  25. Aug 27, 2017 at 10:28 AM
    d0zer
    2017 MGM Platinum
    I thought you got both nuts out, and were just working on the bolts? If you have a friend, use a bar to pry the LCA down and align the shock, it takes a bit of finesse to get everything aligned. I did it w/ a breaker bar and my knee. Took me probably 5-6 tries to get the lower shock bolt aligned and in. I tightened the top almost all the way before attempting the bottom.
  26. Aug 27, 2017 at 10:40 AM
    smslavin
    Hudson Valley
    Some stuff
    Yea. So did I. It was moving when I typed and I get overly ambitious.
    Been trying the break bar method. Can't get the LCA to drop low enough. Disconnected the seay bar link as well. Top of the shock gets about halfway into the tower and no more.
  27. Aug 27, 2017 at 10:56 AM
    d0zer
    2017 MGM Platinum
    Do the top first. I tried both methods, and bolting the top was the only way I could get the coilover to position correctly. Also, make sure that the unbolted sway bar isn't hitting the bottom of the coilover, this also caused me issues when trying to get my setup bolted in. I had to totally push it out of the way, check the photo below.
  28. Aug 27, 2017 at 11:53 AM
    smslavin
    Hudson Valley
    Some stuff
    Cutting it off. Advance Auto down the street has a replacement bolt. Camburg included new nuts with the arms. Running up to get new blades for the SawzAll then to pick up the bolt and spring compressor. The rears better be a breeze after this. Hope I didn't just jinx myself...
    Btw, you guys are awesome. Thanks for all the help. Virtual or by phone. Much appreciated. Drinks on me. :cheers:
    aperezsh, Les7311 and T-Rex266 like this.
  29. Aug 27, 2017 at 11:58 AM
  30. Aug 27, 2017 at 12:02 PM
    Les7311
