U-Haul Trailer with Lifted Truck
Discussion in 'Towing & Hauling' started by DanTundra, Sep 15, 2021.
  1. Sep 15, 2021 at 11:54 AM
    DanTundra
    DanTundra [OP] Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    Hello all,
    Wanted to get everyone's opinion prior to purchasing a new ball mount. Relocating next week and renting a 6x12 U-haul cargo trailer. U-Haul says to have your ball about knee height (19 inches) for the trailer.
    I just lifted my truck with larger tires and my hitch is now 21 inches. According to my math seems like I would only need a 2 inch drop ball mount and should be good to go, however, logically I think I would need a larger drop because my truck is noticeably higher.
    1. If anybody has rented a U-haul lately what have you used as a ball mount height?
    2. I've thought about just purchasing an adjustable ball mount so looking for recommendations on models/brands. I know B&W has the tow & stow which is nice, but I usually just leave a hitch cover on so doesn't have to be that fancy with features.
    Thanks!
  2. Sep 15, 2021 at 12:53 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    U haul trailers are on the high side. For my stock truck with 33inch tires, I usually need a straight hitch for a uhaul trailer. But for my own trailer or pop up, I use about a 5 inch drop. Boats larger trailer, straight hitch bar usually is correct.
    So, you should be pretty close with some lift and a 2 inch drop. B&W makes great stuff, you could buy one height adjustable with multi balls and never have to worry about trying to not have the correct hitch again.
  3. Sep 15, 2021 at 12:58 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    I just looked into this as well. Mine’s stock height, hitch center is about 18.5”. 2” drop puts centerline of ball close to center of hitch, which according to them is where they want it. 4” drop hitch would put center of ball 2” lower than hitch receiver.
  4. Sep 15, 2021 at 1:59 PM
    Sundog likes this.
  5. Sep 15, 2021 at 2:49 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    No need to get fancy unless you want to. I picked this one up for my front mount hitch
  6. Sep 15, 2021 at 5:44 PM
    DanTundra
    Wilmington, NC
    Thanks everyone! I went ahead and just purchased the B&W Tow and Stow. Figured I can sell my 3 ball hitch to make some money back since I won't need that anymore.
    ColoradoTJ likes this.
  7. Sep 16, 2021 at 8:10 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    ColoradoTJ do you run this drop ball hitch mount yourself? This one looks like the highest quality one Ive seen next to the $300 - $400 units
    I'm looking into this as we have multi trailers here at the shop, this will keep me from having to locate the corresponding ball mount when I want to just back up and roll.
  8. Sep 16, 2021 at 8:17 AM
    I didn’t have multiple bumper pull trailers, so I had a 3” drop shank that I still have (15 years old). Now I only have gooseneck trailers.
    If I had multiple trailers, I would have an adjustable hitch like this one.
    RdKing[QUOTED] likes this.
