Two things
Discussion in 'General Tundra Discussion' started by nebhuskman, Dec 2, 2021.
  1. Dec 2, 2021 at 9:04 AM
    nebhuskman
    nebhuskman [OP] New Member
    Mark
    2007 tundra limited
    Level kit
    First thing, has anyone one replaced the front dif needle bearing one the 2007, tundra, drivers side? If so what all did you do to do it? Second I have a slight vibration in the reared when I leave a stop, not all the time, was told to rotate my tires and make sure there is no mud or anything in the rims, what can I inspect on the rear before I get too far into it?
  2. Dec 2, 2021 at 10:17 AM
    2mchfun
    Mileage? Do you back a boat in water? Check driveshaft u joints, jack rear and with the truck in neutral try to wiggle tires side to side as you slightly rotate them back and forth to check for bearing play. Lots of folks here use the ecgs bearing bushing on the front. Search box is your friend and some folks here share the special tool too.
  3. Dec 2, 2021 at 11:16 AM
    nebhuskman
    Mark
    2007 tundra limited
    Level kit
    It has 210000 on it don’t go in the water with it I did go in a bunch on mud a while back, cleaned it up, it is due for a tire rotation, the u-joints were done at 150000, along with the carrier bearing when I get back from vacation I’ll put it in the air
    2mchfun likes this.
