Turning issues.
Discussion in 'Suspension' started by davebo, Aug 13, 2019.
  1. Aug 13, 2019 at 6:43 PM
    davebo
    davebo [OP] New Member
    David
    Greenwood, Arkansas
    2017 Tundra crewmax Platinum
    BDS 4.5 lift with fox shocks 325 60 R20 BFG KO2 Fuel MOAB 20 x 9 2 inch wheel spacers Amp Research power folding steps Rock lights Undercover tonneau cover TRD Pro grill DVD headrests Bull bar with 20 inch LED light bar
    Has anyone ran into this issue when turning full lock at slow speeds? My front tires lean out and they squeal like they are skidding. Also the truck jumps and bucks like it is in 4wd ev3n though it isn’t. No excessive tread wear patterns like alignment problems. I have a suspicion that is may be the combination of aftermarket wheels with wheel spacers. The truck has a 4.5 inch bds lift with 35x13 20s. The previous owner set that up. Any help would be appreciated. The pic from the back shows the tire lean.
    BakNBlk2014 likes this.
  2. Aug 13, 2019 at 7:12 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Boom. Mic drop.
    15Yota, davebo[OP] and Prostar 190 like this.
  3. Aug 13, 2019 at 7:15 PM
    Oh by the way Welcome from Ohio.
    15Yota, davebo[OP] and Mountun Goat like this.
  4. Aug 13, 2019 at 7:18 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha welcome as well! Your truck looks badass
    davebo[OP] likes this.
  5. Aug 13, 2019 at 7:23 PM
    davebo[QUOTED][OP] likes this.
  6. Aug 13, 2019 at 7:45 PM
    davebo
    David
    Greenwood, Arkansas
    Tundra234. I’m really not sure on the offset. I do know that there is also a wheel spacer behind there. So what ever the spacing, it’s pretty big. I don’t think it’s hitting anything. I felt that. It would rub in reverse on the body mount bracket until I had it chopped off. This is something different from hitting something.
  7. Aug 13, 2019 at 7:47 PM
    davebo
    David
    Greenwood, Arkansas
    15 Yota. I will for sure check out the alignment. It just doesn’t have any of the typical alignment issues. Doesn’t pull. Doesn’t have any excessive tire wear. Drives straight as an arrow down the road. Smooth as it can be except full lock turning at slow speeds.
    Mountun Goat and 15Yota like this.
  8. Aug 13, 2019 at 7:48 PM
    davebo
    David
    Greenwood, Arkansas
    2ndgenny. Thanks!
    Pro star 190. Thanks!
    Mountun Goat likes this.
  9. Aug 13, 2019 at 7:51 PM
    The offset is usually stamped on the back side of the wheel. As far as spacing, a wheel spacer brings a wheel out, but when you turn it, it puts it closer to the bumper or body mount. I have a Readylift 3/2 kit and a 0 offset with 34's and i am really close to rubbing at full lock. Did you just purchase the truck? I'm just wondering how long it has been like that.
  10. Aug 13, 2019 at 7:53 PM
    Also, what size is the wheel spacer?
  11. Aug 13, 2019 at 7:58 PM
    davebo
    David
    Greenwood, Arkansas
    I did purchase like this. I’ve had it for about 6 months. Has 17k on it. The original owner did all the mods to it. It has a 4.5 bds lift with the fox shocks. Has 325 60 r20s. Nothing rubs anymore since I did the body mount chop. But yes. The truck has done that since I purchased it. Honestly. All other driving I do from city driving to interstate at 85 mph is smooth as butter. It’s just when I go to turn into a parking space or something like that.
  12. Aug 13, 2019 at 8:00 PM
    davebo
    David
    Greenwood, Arkansas
    So the SPcs are upper control arms?
  13. Aug 13, 2019 at 8:01 PM
    davebo
    David
    Greenwood, Arkansas
    They look to be 2 inches.
  14. Aug 13, 2019 at 8:04 PM
    davebo
    David
    Greenwood, Arkansas
    Sweet. Thanks for the info.
    15Yota likes this.
