Turn trac off and it comes back on?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundyFromDownUndy, Nov 8, 2022.
  1. Nov 8, 2022 at 10:35 AM
    TundyFromDownUndy
    TundyFromDownUndy [OP] New Member
    2020 Platinum Tundra
    Is this a feature or a bug? . . . Got some snow last night and I wanted to go rippin. Turned trac off. And 2 mins later noticed it was on again (display msg of trac off disappeared) .. repeated this 3 times and gave up
  2. Nov 8, 2022 at 10:36 AM
    Taco-Spike
    Two Trucks
    Did you hold it for a few seconds or just press it?
    KNABORES likes this.
  3. Nov 8, 2022 at 12:32 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    I think at a certain speed it goes back on.
    Taco-Spike likes this.
  4. Nov 8, 2022 at 12:37 PM
    TundyFromDownUndy
    Just pressed it, the dash said trac off, so assumed I was good, after a min or two it goes back off. Like the other commenter said, could have to do with speed, testing shortly.
    Taco-Spike[QUOTED] likes this.
  5. Nov 8, 2022 at 12:48 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It should do something with the first press. There's three stages, press, hold, and double hold.
    It's not speed based, I have everything turned off every time I drive the truck.
    Unless there's some weird shit with the 20s, I have no idea OP. Only way I know traction control can renable is with the button being pressed again or ignition being cycled.
  6. Nov 8, 2022 at 12:53 PM
    snivilous
    SW UT
    Though OP it would be worth a shot to do what @Taco-Spike said. If you hold the button for 3 seconds one of the dash lights should turn off, that will put you into the "second stage" of turning things off. If you release the button and then hold it again in quick succession for another 3 seconds then it should just say trac off and vsc off, which is the system truly being 100% off. Maybe there's some timer for the lowest level? Worth a shot to try the other two levels of turning it off and see if that makes a difference (and for doing donuts and stuff you want it fully off anyways).
    Taco-Spike and TRDFerguson like this.
  7. Nov 8, 2022 at 12:58 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    My 2020 manual says this....
    ■ Automatic reactivation of TRAC, Trailer Sway Control and VSC systems After turning the TRAC, Trailer Sway Control and VSC systems off, the sys- tems will be automatically re-enabled in the following situations:
    ●When the engine switch is turned off
    ●If only the TRAC system is turned off, the TRAC will turn on when vehicle speed increases
    ●If both the TRAC and VSC systems are turned off, automatic re-enabling will not occur when vehicle speed increases.​
    It sounds like TRAC will reenable at a certain speed but not if TRAC and VSC are off.
    Wrongside, snivilous and Taco-Spike like this.
