Turn signals out
Discussion in 'General Tundra Discussion' started by Makaraba, Oct 28, 2021.
  1. Oct 28, 2021 at 1:13 PM
    Makaraba
    Makaraba [OP] New Member
    2010 TUNDRA 4.6
    Help needed...
    The turn signals don't work on my 2010 4 6 Tundra.
    The hazards work fine...I replaced the flasher still nothing ...AL The fuses are good bulbs as well. There does not appear to be any cut wires anywhere that I an see that would cause a short. Could it be the turn signal handle itself????
  2. Oct 28, 2021 at 2:16 PM
    Is it all 4 corners? I think there is a relay in the engine compartment fuse box.
  3. Oct 28, 2021 at 6:59 PM
    2mchfun
    Welcome to the forum. Did you also check the fuse box under the dash? Little skinny one way up in there about 2" wide 4.5" long. Right above park brake.
  4. Nov 15, 2021 at 3:45 PM
    Makaraba
    2010 TUNDRA 4.6
    All four corners not working
    All fuzes are good
  5. Nov 15, 2021 at 3:59 PM
    2mchfun
    Rodent damages somewhere maybe?
  6. Nov 15, 2021 at 4:53 PM
    Welcome from NY.
    Maybe it's the switch/contacts on the steering column?
    Good luck, let us know when you figure it out.
  7. Nov 15, 2021 at 5:02 PM
    2mchfun
    Me thinks you may have missed a blown fuse. I think a slow verification would be wise. If it were me, I would even swap them around, same amperage ratings of course, just to verify.
    TTund16 likes this.
  8. Nov 19, 2021 at 1:58 PM
    Makaraba
    2010 TUNDRA 4.6
    I have a new turn signal handle have to get new battery .
    I will double check all fuses.
    Thanks for your help...much appreciated
    2mchfun and 1lowlife like this.
