Turn signals not activating when headlights are on? (TRD headlight conversion issue)
Discussion in 'Lighting' started by Limp Mode, Jul 2, 2021.
  1. Jul 2, 2021 at 3:07 PM
    Limp Mode
    Limp Mode [OP] New Member
    Well, this was fun to find out during the vehicle's inspection...
    2016 SR5
    TRD Pro headlights with Headlight Revolution's basic conversion harness
    LED front and rear turn signals (no resistor yet)
    With headlights off, the blinkers function as intended (but hyperflash due to lack of resistors at the moment)
    With headlights or high beams on, the rear blinkers still function as intended, however the front amber DRLs stay in the on mode and don't blink.
    Did I miss something simple or could this be an issue with the harness?
  2. Jul 2, 2021 at 4:55 PM
    Taco-Spike
    Two Trucks
    It’s this the first time it’s happened? Or first time you noticed? Both?
    first inspection with this set up?
    I would suggest ihacker harness.
  3. Jul 2, 2021 at 5:04 PM
    Limp Mode
    When I checked the blinkers after installation, I only checked with headlights off and thought it was good to go. It's the first inspection with this setup.
  4. Jul 3, 2021 at 2:10 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Check the blinkers plug, I heard about this problems with the HR harness and they know it but refuse to fix their installation guide.
    They suggest to flip the wires in the signals plug but this is worthless and instead of fixing the hyper flash make it worst creating more issues with dash and taillights, their harness is missing one part to fix this.
    The instructions they provide only work for the trucks with the single LED strip and don’t apply for truck with amber DRL.
    To fix your problem put the wires back to the original location and don’t use the violet wire just cover the metal pin with electrical tape and secure it to the wiring looming, seal the hole with clear silicone to keep water out of the plug.
    I hope this resolve your problem.
  5. Jul 8, 2021 at 12:56 PM
    Limp Mode
    To be clear, you're referring to the violet wire for the J29 plug under the dash?
    With your harness, would I still have to mess with that wire?
  6. Jul 8, 2021 at 3:40 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    No the violet wire in the turn signal plug
  7. Sep 27, 2021 at 4:19 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    On my 2015 this did not work I had to move the white wire over and just remove the violet one from the middle location for it to work correctly. I tried moving the white wire to the middle and my turn signals just hyper flashed. I would for sure recommend anyone just getting the Ihacker harness to avoid having to figure this mess out.
    iHacker[QUOTED] likes this.
