turn signal debacle
Discussion in 'General Tundra Discussion' started by Frustrated mongoose, Sep 7, 2025 at 4:57 PM.
  1. Sep 7, 2025 at 4:57 PM
    Frustrated mongoose
    Frustrated mongoose [OP] New Member
    Sunday
    Dave
    2008 5.7 V8 tundra
    I am having turn signal issues with my truck. I have replaced all of the turn signal bulbs with new ones but only the driver's side rear signal is working. Any thoughts?
  2. Sep 7, 2025 at 5:26 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    factory halogen bulbs? Have you checked the connector on the bulb? any burn marks or melting? Do the hazard lights work? Or only the 1 rear one?
  3. Sep 7, 2025 at 5:48 PM
    Frustrated mongoose
    Sunday
    Dave
    2008 5.7 V8 tundra
    No modifications were made to the truck as far as i can tell. I bought it about 5 years ago. There are no scorch marks on any of the connectors. The turn signal relay hyper clicks. The hazard lights do not hyper click but only the one left rear light flashes.
    I hooked up a trailer to the truck and ALL of the lights work and flash properly on the trailer.
  4. Sep 7, 2025 at 5:51 PM
    Frustrated mongoose
    Sunday
    Dave
    2008 5.7 V8 tundra
    Fyi no LED lights are used.
  5. Sep 7, 2025 at 5:58 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Maybe I am not understanding but…
    Why did you replace the bulbs to begin with? Were they blown?
    If you replaced the bulbs simply as preventative maintenance you either installed the wrong bulbs or installed them incorrectly.
  6. Sep 7, 2025 at 6:22 PM
    Frustrated mongoose
    Sunday
    Dave
    2008 5.7 V8 tundra
    I replaced the turn signal bulbs because three of the four were not working. The front bulbs were definitely burned out. The rear ones i couldn't tell. But there was no change from before or after bulb replacement.
