Turbo silencers?
Discussion in '3rd Gen Tundras (2022+)' started by Limitrd, Nov 17, 2022.
  1. Nov 17, 2022 at 12:01 PM
    Limitrd
    Limitrd [OP] New Member
    Oregon
    22 Lunar Rock Limited Hybrid TRD Off Road CM 6.5
    Has anyone looked to see if there are silencer rings on the turbos? If so, has anyone removed them?
  2. Nov 17, 2022 at 12:24 PM
    mass-hole
    mass-hole New Member
    Not sure on the tundra, but the "silencers" that were in the F150 Ecoboost intakes were actually there to cause the air to swirl in the intake in the opposite direction than the compressors were spinning. Literally like OEM Tornados :rofl:
    This helped improve spool and compressor efficiency. Shops have dyno'd with and without them and shown no change in peak power.
    So I wouldnt just pull them out for woosh noises.
  3. Nov 17, 2022 at 12:26 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  4. Nov 17, 2022 at 12:31 PM
    Black@Blue19
    Ken
    SE Texas
    Bigger Turbos would make more noise,, a neighbor has redone his super duty and put a bigger turbos in there and you can hear the whirl from a block away over the diesel motor!:)
  5. Nov 17, 2022 at 12:33 PM
    mass-hole
    I bet that "silencer" on that thing was to smooth airflow into the compressor like a velocity stack or similar. Look at how big the intake tube is compared to the compressor.
