Turbo question
Discussion in 'Performance and Tuning' started by Alex261, Aug 23, 2022.
  1. Aug 23, 2022 at 5:57 PM
    Alex261
    Alex261 [OP] New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I’m new to the turbo scene and I’m curious if the turbos are always spinning when the engine is running. My truck has a gauge and it only shows psi when I give it decent gas. If the truck is parked and idling are they still spinning as well
  2. Aug 23, 2022 at 6:03 PM
    MaxPower
    MaxPower New Member
    18 Tundra TRD Off road
    Yes, the turbos are spinning any time the engine is running. They don't build significant boost until the RPMs are over 1500ish.
  3. Aug 23, 2022 at 8:37 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    There’s two main parts to a turbo.
    The turbine
    The compressor
    the exhaust spins the turbine. The turbine spins the shaft. The shaft spins the compressor.
    with enough load on the engine the exhaust comes out with enough force to spin the turbine hard enough to cause the compressor to push more air than the engine would normally ingest. This is ‘boost’
    at light loads true turbine basically free spins.
    here’s something fun to do. From an idle stomp the throttle to the floor for half second. Then kill the motor and run to your turbo. Put your ear to it and hear the turbine/ compressor wheels free spin. It does this with my comp oiless turbo. Not sure if a journal turbo would do this.
  4. Aug 23, 2022 at 9:09 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    That would seem like there are 3 important parts... The shaft is always important!!! ;)
    ...sorry I couldn't help myself!
  5. Aug 24, 2022 at 7:38 AM
    dirtydeeds
    Keith
    USA
    That’s what she said?
