tune up
Discussion in '2nd Gen Tundras (2007-2013)' started by chop123, Jul 1, 2018.
  1. Jul 1, 2018 at 3:48 AM
    chop123
    chop123 [OP] New Member
    clifton
    2007 dark green tundra sr5
    My 07 tundra with the 4.7 engine is coming up on 120,000 miles,what do you guys get done for a tune up, plugs I know, but what else is very important to get done.I not having any problems wires,fuel injection cleaning,throttle body,just let me know what you guys recommend.Thanks,Meinke wanted to charge $450 to get it done,plugs and fuel injection cleaning and throttle body decarb,does it sound right on price. Thanks again looking for all opinions Thanks
    Black Wolf and Leo's first like this.
  2. Jul 1, 2018 at 4:14 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Good morning @ Clifton. I wouldn't take my Tundra to Meinke if you were paying for it. If your gonna get a full tune up, then I suggest taking it to Toyota, unless you know a mechanic you trust and is good. Depending on what your Tundra has been used for, I would get a transmission drain and fill or flush before plugs. I'm a .....If it ain't broke don't fix it.I kinda live by that.There are some exceptions. Like transmission, differential, and oil changes obviously. Just my .02. Good luck :thumbsup:
    Brian3UR, Black Wolf and Leo's first like this.
  3. Jul 1, 2018 at 4:19 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    I was curious about this myself my 07 5.7:benchpress:just turned 110k
    Does garage do anything different to injectors besides put chemicals in fuel
    Has anybody fogged their intake system (seafoam)
    :threadjacked: Sorry
  4. Jul 1, 2018 at 4:23 AM
    rons23
    Ron
    Kill Devil Hills
    @ Mike, unless you've been putting seafoam in your Tundra from the beginning, I wouldn't put any kind of additives in my Tundra. Me personally, I think your opening a can of worms. :eek::eek2:
    TXRailRoadBandit73 likes this.
  5. Jul 1, 2018 at 4:28 AM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    I use seafoam every so often in both my 2002 and 2016 Tundras. No harm, may do some good.
    Is it time for a timing belt?
  6. Jul 1, 2018 at 4:35 AM
    Leo's first
    Groton ma
    Thanks Ron
    I pretty much go with your theory if it ain’t broke I’m going to have tranny serviced (the one under truck) for some reason I really want to change plugs prob wait til fall
    rons23[QUOTED] likes this.
  7. Jul 1, 2018 at 4:42 AM
    Leo's first
    Groton ma
    I like seafoam run it in wife’s car haven’t put any in Tundra but prob will
    I was wondering if anyone has fogged intake system but like Ron said I think that could open another whole can
    5.7= timing chain :militarypress:
    rons23 likes this.
  8. Jul 1, 2018 at 4:45 AM
    Lots of great advice so far Clifton. Plugs are fairly easy to check/change. When needed. I recently pulled out a couple plugs when I hit 90K. Both looked great. Going to wait a while longer before I change all of them.
    Leo's first likes this.
  9. Jul 1, 2018 at 4:47 AM
    rons23
    Ron
    Kill Devil Hills
    Yeah, it's recommended @ 120 k. I need to get tranny done soon. Timing belt for our 2nd gens with the 4.7 is a must . I had mine done @65k when the AIP went. New water pump and timing belt. :cool:
    Leo's first[QUOTED] and DaBoro54 like this.
  10. Jul 1, 2018 at 9:30 AM
    Brian3UR
    Brian3UR New Member
    2013 Silver Sky DC 4x4
    Drop in K/N filter with TRD airflow accelerator BullyDog GT Tuner 2.5" Suspension leveling kit TRD rear sway bar Line-X bedliner Charcoal Filter (in air box) delete Deleted screen in throttle body gasket Coolant to throttle body bypass LED lighting inside bed and under hood Center console from 2007 Tundra with LED light for cup holder Small amplifier and subwoofer to enhance factory radio BAMuffler TRD Dual Replacement system (on order) LED headlights, fog lights, brake, tail and interior lights Side mirror glass with turn signal indicators (from Platinum model)
    Def do the timing belt and waterpump (you're there and it's going to save you money in the long run). If you do the pump, you'll have to drain the coolant so it's a good time to just put new in (use the Toyota SLLC). I'd do plugs (they are iridium and due every 120K) and clean the throttle body. Also get the plugs from the dealer, don't use Champion or Bosch platinum as our engines do not respond well to that. Don't worry about Seafoam or fogging the intake. I work on these every day and I can tell you it's unnecessary. And don't take it to a place like Meineke, you're better off not doing anything.
  11. Jul 1, 2018 at 12:32 PM
    Maybe your '02 but not your '16
  12. Jul 1, 2018 at 12:36 PM
    I cleaned out my MAF and TB, got the cans from Autozone, easy to do ther is a can for each one, also changed out my plugs at 50k driver side some what of a PITA also changed my tensioner and idler pulley and belt not that bad to do, were squealing at 35k when I bought truck used with 26k
  13. Jul 1, 2018 at 6:20 PM
    chop123
    clifton
    Thanks a lot of good info,i have had the timing belt done already at 90,000
