Tune up/flush
Discussion in '2.5 Gen Tundras (2014-2021)' started by tomboyk78, Nov 29, 2023.
  1. Nov 29, 2023 at 6:02 PM
    tomboyk78
    tomboyk78 [OP] New Member
    Kat
    2014 Tundra 4X4
    Hello,
    Looking for recommendations on quality tranny fluids & coolant for a flush on both. Pushing 220k & have just done reg oil changes, besides getting a new set of tires due to blowout (dry rot). Would like to see about getting a chip for better fuel economy. Mostly hwy driving but have dropped to less than 13mpg. Thanks for all your help!
  2. Nov 29, 2023 at 6:08 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    If at 220k you haven't done a trans flush then the consensus is, let it be. If you have done it before, I would go OEM fluid or Valvoline. Coolant is also specific to the engine material so OEM or something that is made the same as OEM. Brand doesn't matter but it has to be the same type. Chip will not gain you any noticeable gains in MPG, it a 6000lb brick. Have you done the air filter, spark plugs, etc?
    Ruggybuggy and AZBoatHauler like this.
  3. Nov 29, 2023 at 8:27 PM
    tarathetundra
    tarathetundra New Member
    Nate
    2018 white CM
    37x13.50R18
    Yeah agreed if your trying to get it done I heard aamco does a decent job planning on doing that as well with a filter replacement
  4. Nov 29, 2023 at 8:46 PM
    You appear to have a level and bigger tires. Both of those will rob you of MPG. Fresh oil, air filter and plugs will help. Also clean the MAF and throttle body. O2 sensors can slowly fade and cause poor mpg as well. So maybe refresh the 4 sensors there. Drain and fill the trans is safe and puts fresh fluid with fresh detergent and friction modifiers. Coolant should be changed every 100k miles or so. The pink stuff. No chip will help with MPG. Also driving 65mph or less will net big MPG gains.
    JLS in WA likes this.
  5. Nov 29, 2023 at 8:50 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If it were me, I'd just do a series of 2 or 3 drain and fills (not flush) the transmission using only Toyota ATF WS.
    For the coolant, I'd use OE Pink 50/50 Long Life :thumbsup:
    ZappBrannigan and gnatehack like this.
  6. Nov 29, 2023 at 8:53 PM
    tomboyk78
    Kat
    2014 Tundra 4X4
    Thank y’all for your help! Yes, I’ve done the oil change, 2 filters & Iridium plugs…will keep you posted on the progress
  7. Nov 29, 2023 at 9:59 PM
    tomboyk78
    Kat
    2014 Tundra 4X4
    Anyone familiar w/High Performance Lubricants? They carry a HP Green which is compatible w/Toyota WS…
    stevesgraytundra likes this.
  8. Dec 1, 2023 at 11:15 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Unless the trans pan has been down before your going to have a bad day. The bolts sieze because of dissimilar metals and will break off.
  9. Dec 1, 2023 at 11:57 AM
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    Love their motor oils, but have no experience with their ATF. I am considering using their product for my next drain and fill. As others have said, you may want to reconsider a drain and fill or a flush if that AT has over 200,000 miles on it with original fluid.
  10. Dec 2, 2023 at 9:26 PM
    tarathetundra
    Nate
    2018 white CM
    37x13.50R18
    Gotcha thanks for the heads up!
    Ruggybuggy[QUOTED] likes this.
