2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Nov 7, 2018 at 3:06 AM
    #1021
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    OK I thought you were talking about an after-market camera system. I've started researching the Factory "Bird's eye view" camera system. Toyota introduced it in the Rav4 and Highlander but it has now expanded to the Camry, Sienna, and Avalon. It might not be long before they add it to the their trucks as well. So this is a good reminder that I need to study up!
    blackoutt[QUOTED] likes this.
  2. Nov 7, 2018 at 10:09 AM
    #1022
    Jai LI
    Jai LI New Member
    TX
    2018 CM 1794 5.7 4x4 FFV
    Rear sway bar, CAI and sound deadening
    Lou, I just noticed that my GPS stops working if I have the single toggle switch to Off.
    Also, for some reason, I don't have to have the single switch on. The double switch works on its own. Is this correct? Not a biggie, still love it. Just wondering if I missed something.
  3. Nov 7, 2018 at 4:35 PM
    #1023
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    @TundraTex One of your first 10 customers here . Still love it !! use it every day , My girlfriend has a 2015 Lexus GX 460 and wants a forward camera would the FRAC work with her Lexus ? thanks again for coming up with the FRAC!!
  4. Nov 8, 2018 at 4:44 AM
    #1024
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Jai LI your FRAC Harness is functioning normally. Check out post 663 for more details. You can also read more about the VIM switch function on Page 5 of your instruction manual. Glad to hear you're enjoying your FRAC harness!
  5. Nov 8, 2018 at 4:48 AM
    #1025
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Scpringle, The FRAC Harness will work with a number of Lexus vehicles, but I'm not certain with the 2015 GX460. I'll have to dig in to the tech data this weekend and research it a bit more. Thanks again for being one of the FRAC Harness pioneer customers!
    DiamondW and Scpringle[QUOTED] like this.
  6. Nov 9, 2018 at 6:31 AM
    #1026
    Jai LI
    Jai LI New Member
    TX
    Awesome, just wanted to be sure I didn't do something wrong during installation. Really appreciate it.
  7. Nov 13, 2018 at 7:08 AM
    #1027
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    @TundraTex which fuse does this use. Mine stopped working need to check fuse. No camera any time.
  8. Nov 13, 2018 at 6:32 PM
    #1028
    InfernoPro15
    InfernoPro15 New Member
    So i've been looking for a harness that would enable the rear camera with a switch. Don't need a front facing camera or Nav bypass. Do you make something simple like that?
  9. Nov 13, 2018 at 10:28 PM
    #1029
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    You can configure the FRAC Harness to operate only the rear camera if that's all you want, but the other functionality is built in. I don't make a rear only anytime harness.
  10. Nov 17, 2018 at 3:19 AM
    #1030
    Ragecage92si
    Ragecage92si New Member
    Josh
    17 blue TRD
    7" BDS lift kit,3” body, King 2.0’s, Mammoth Guards, Custom powder coating, Nitro 5.29, D.A.P. Tuned, Coachbuilder shims, Coachbuilder Steering kit, Wether Tech vent visors, and hood protector, spray in bed liner, Bakflip, Fuel wheels, 38” TOYO tires, Bushwacker fender flares, Dirty deeds exhaust , TDK front bumper, Rigid light bar/floods/spots. Husky fronts, Weather Tech rears, ESP under seat storage, PowerX2 battery, Android Tesla unit, AJT chrome delete, Horn Blasters, Custom switch cluster, Interior leds, Revere leds, 19 pro headlights, Rocklights, Custom MAYHEM projector
    @TundraTex i have this unit and had the camera that mounted in the emblem also, I have since changed grilles and no longer have the emblem. I ordered a different camera, it has a red mini 4 pin connector where the old one was black. When plugged in no video. Do you know if there is a difference in the two? 97F4AFB4-640A-4F8A-865B-76BF7E0A3AA2.jpg
  11. Nov 17, 2018 at 4:27 AM
    #1031
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    From what I’ve seen in the past they are usually the same. Try hooking up your old camera to make sure everything is still working and then plug the new one in again. The cameras do occasionally go bad or have a bad cable.
  12. Nov 17, 2018 at 4:46 AM
    #1032
    Ragecage92si
    Josh
    17 blue TRD
    I did hook up old camera, all still works. Maybe it’s just a bad camera. Just wanted to make sure there was no difference before I order another one.
  13. Nov 18, 2018 at 3:25 PM
    #1033
    niedejb
    niedejb New Member
    Sumter, SC
    '17 Platinum
    Got my front camera installed...thanks TundraTex
    Switch:
    Aluminum mount
    Close up
    Nice and hidden
  14. Nov 18, 2018 at 3:58 PM
    #1034
    Blackrr
    Blackrr New Member
    2016 Inferno SR5 TRD
    Any good clean camera options for the TRD Pro grille?
  15. Nov 26, 2018 at 6:45 PM
    #1035
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Check the "products discussed" links at the bottom of this thread page. Also the post immediately proceeding yours is a great example of the NOAUKA camera install, which would be very similar on your PRO Grill.
  16. Dec 22, 2018 at 8:33 AM
    #1036
    Trebor57
    Trebor57 New Member
    Rob
    Sacramento, CA USA
    2018 Toyota Tundra SR Double Cab - 2-wheel drive
    @ProtoJ What camera are you using and where did you get it from?
    I have a 2018 SR Double Cab and now am wanting to put a front camera on my truck.
    Anyone else put in a front camera on their 2018, any suggestions?
    Thank you
    Donkeypunch likes this.
  17. Dec 22, 2018 at 9:27 AM
    #1037
    Donkeypunch
    Donkeypunch New Member
    X2. I have a 2019 Platinum and also wondering if the FRAC works on these as Toyota changes stuff on the electrical.
  18. Dec 22, 2018 at 9:37 AM
    #1038
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Yes the Frac does work on the 2018 ...
  19. Dec 22, 2018 at 11:00 AM
    #1039
    cjscinta
    cjscinta New Member
    Nashville TN
    I really want to do this. I’ve watched Tex’s install video. It looks pretty involved. I always get nervous pulling off all those plastic panels and ripping apart the dash. Although I’ve pulled panels off before they never seem to go back on quite right. Broken tabs, clips, etc. and I use the plastic tool kit. How much time and how involved is the install in your opinion? Wish I had a bud that owned a stereo shop.
  20. Dec 22, 2018 at 5:48 PM
    #1040
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    If you take your time and go easy it might take 2-3 hours. Just remember to pull the panels straight out. The Toyota design is pretty nice and the clips are very durable. I’ve had my HU out at least 7-8 times and it still fits snugly.
  21. Dec 22, 2018 at 5:51 PM
    #1041
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. It works with all 2019 trucks.
  22. Dec 22, 2018 at 6:02 PM
    #1042
    cjscinta
    cjscinta New Member
    Nashville TN
    Thanks Tex. Your 2-3 is probably 5 to 6 for me but I appreciate your confidence. I’ll watch the video a few more times to get my confidence up. Thanks for the response.
    TundraTex[QUOTED][OP] likes this.
  23. Dec 25, 2018 at 6:52 PM
    #1043
    For $38 more I would buy the @TundraTex harness.
    It's made in America, he is a fellow enthusiast and he provides excellent tech support and stands behind his product.
  24. Dec 27, 2018 at 6:16 AM
    #1044
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @cjscinta, You can do it!! Like many new projects, it seems intimidating until you break it down step by step. Feel free to reach out with any questions or concerns you may have.
    831Tun likes this.
  25. Dec 27, 2018 at 1:40 PM
    #1045
    cjscinta
    cjscinta New Member
    Nashville TN
    Thank you sir and I really appreciate that offer. I ordered the camera just to motivate me. I will be placing an order with you soon.
    TundraTex[OP] likes this.
  26. Dec 31, 2018 at 7:46 PM
    #1046
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Great! Go ahead and install the camera and get the wiring routed into the cab. The FRAC installation is a breeze after that!
  27. Jan 13, 2019 at 6:20 PM
    #1047
    Jadoti
    Jadoti New Member
    Central TX
    2017 sr5 5.7l
    Roll n lock, viper remote start, RC 6" lift, 35" Toyos, 1.25" Spidertrax adapters, Bullydog BDX tune
    Ordered mine tonight @TundraTex, can't wait to put it in!
    Thanks!
  28. Jan 14, 2019 at 9:37 AM
    #1048
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Good deal, Mike. I appreciate your business. Received your order and sent your invoice.
  29. Jan 14, 2019 at 10:08 AM
    #1049
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    For you guys with this kit that have been looking into cameras, do they offer ones that have a longer pigtail connection? What I would like to do is instead of a front mount camera, I would like to run from the HU back to the hitch area and then have a camera mounted on the back of my camper. Obviously I would need to be able to disconnect it at the hitch area and then just plug in again when I'm ready to go. Does such a thing exist?
  30. Jan 14, 2019 at 11:41 AM
    #1050
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    All of the cameras link in this thread convert the camera video output to a standard RCA connector. So you could run the camera extension as far as it goes, then connect to a standard RCA cable and route it to the HU as desired. You can buy RCA cables up to 100 feet long. Plenty of length for what you want to do.
    831Tun likes this.
