Why do you hate Nickelback
  1. Because they suck
    9 vote(s)
    34.6%
  2. Because they are Canadian
    1 vote(s)
    3.8%
  3. Because they suck and they are Canadian
    6 vote(s)
    23.1%
  4. I actually like Nickelback. I listen to them while shopping at Target
    10 vote(s)
    38.5%
  1. Jul 21, 2024 at 8:04 AM
    Blue Thunder
    Washington
    Don’t fight it Prospect…
    T-Rex266, NWPirate, GODZILLA and 2 others like this.
  2. Jul 21, 2024 at 8:23 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :fistbump:
    :101010:
  3. Jul 21, 2024 at 8:31 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Usually tub and shower drains get threaded in from the top, underneath is a female fitting, so you shouldn’t really need access underneath unless something broke
  4. Jul 21, 2024 at 8:40 AM
    18" TRD Off Road Wheels
    That's awesome, Tyler. Subsistence living would be great, wouldn't it?
    You have a link for that seasoning? Or a pic?
  5. Jul 21, 2024 at 8:53 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    There are a few different places selling battery adapters too… I’ve been eyeballing the Ryobi handheld pressure washer and getting an adapter to run it with the Milwaukee batteries
  6. Jul 21, 2024 at 8:55 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Keep your hands off your pecker till something else goes first then
    OldGuy03, T-Rex266, GODZILLA and 5 others like this.
  7. Jul 21, 2024 at 9:26 AM
    RainMan_PNW
    Casey
    Clark County, WA
    I rarely use string… I’m only looking at getting one for detail work, though I just discovered “reciprocating cutter” attachments and might go that route.
    For actual brush cutting, including blackberries, I’ve got a couple different heads. The Milwaukee came with a four tooth blade that does decent:
    I have a polycut trimmer head on the Stihl most of the time - been using that design since I was old enough to handle a brush cutter. The blades aren’t as robust as I remember as a kid, but for grass and less dense green brush they do well.
    when I need to put on armor and foray into the brambles of a dense blackberry thicket, I turn to this thing. I can’t find the brand on it, but I’m fairly certain it’s made locally here in SW WA somewhere. This thing will fuck up anything it hits. The blade is tri-lobed so it builds the momentum like you get from the star shaped blades and has carbide teeth so it cuts into pretty much anything. And the three turned down set off teeth serve to chop up shit under the blade as well… you can use a stabbing and plunging action to really push deep into the nasty blackberry piles. After 18 years of hard use (never sharpened it since I bought it), I’m just now thinking about replacing this one. But don’t use this for detail work…it’ll tear apart a hog wire fence or anything else it touches
    I’ve also tried the chainsaw style blades over the years but they dulled too easy and only really worked for cutting into standing trees. This blade will do that but also work for standing grass (not as good as a poly-cut or star blade though).
  8. Jul 21, 2024 at 10:03 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I was getting ready to run to the store 30 min ago and couldn't find my wallet. I looked all over the house, garage, truck, and then over every square foot that I cut grass yesterday. A lot of which is ditches and road frontage, and all of it is rough and bouncy.
    was looking for a while. assumed it fell out of my left cargo pocket (which has never happened before an where it always is) along the road and someone picked it up.
    that would've put a huge damper on everything. Aboi to do a road trip 1200 mi south, buy a trailer, etc.
    I took my pants off in the garage after working yesterday because they were covered in debris that I don't want to track in the house. I threw them over a tool bin and my wallet fell out and down between a garbage can and the tool bin (an I looked there, twice already)
    moral of the story is, this is why I have little habits, routines and try to plan things. I always put my stuff in the same pockets and always keep them in the same places in the house. so I don't go through shit like this. I almost had a nervous breakdown, thinking about losing my ID, bank card, etc, right now, of all times.
    see, one little thing out of the ordinary, like take my pants off in the garage, and it's pandemonium.
    so, don't take your pants off in the garage, kids.
    Beach Toy, OldGuy03, NWPirate and 8 others like this.
  9. Jul 21, 2024 at 10:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Headed to California
    stuck in Austin. Plane change
    I don’t like being in the wild
    civilization is not as far along as I have imagined
  10. Jul 21, 2024 at 10:54 AM
    Azblue
    The Dirty T ( ^_^)_且
    Yep, that is access to the drain, which in mine is the same as home plumbing stuff. One trip I noticed a small drip when my wife was using the shower and I was sitting outside. Opened that panel and tightened it about 1/4 turn, no more drip.
  11. Jul 21, 2024 at 11:02 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    These are remarkable political times
  12. Jul 21, 2024 at 11:15 AM
    Blue Thunder
    Washington
    If you don’t like Austin, CA is going to blow your mind.
  13. Jul 21, 2024 at 11:20 AM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Nothing is stronger than muscle memory. I do the same.
  14. Jul 21, 2024 at 11:31 AM
    Certain someone is no longer in the race :fistbump:
  15. Jul 21, 2024 at 11:35 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Almost forgot the tomatoes
  16. Jul 21, 2024 at 11:38 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    only going to that hell hole to settle a family estate
    in and out
    otherwise, I’d be driving a boat
  17. Jul 21, 2024 at 11:39 AM
    Bring me back something cool from the estate
  18. Jul 21, 2024 at 12:07 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I’ll do my best
  19. Jul 21, 2024 at 12:29 PM
    Esp if I can take it to Pawn Stars. I’ll split it with you
    OldGuy03 likes this.
  20. Jul 21, 2024 at 1:10 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
  21. Jul 21, 2024 at 1:25 PM
  22. Jul 21, 2024 at 1:28 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    We kept bass. Normally myself and many others don't like to keep bass just because it's more fun to let them get bigger but this particular lake they actually want you to keep the smaller ones so we kept a handful of small ones. It's seriously good seasoning I don't know anybody that wouldn't like it.
  23. Jul 21, 2024 at 1:35 PM
    I like bass. Only had it once, but it is superior to trout.
  24. Jul 21, 2024 at 1:51 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I had Chilean sea bass once, a long time ago. It was probably more how it was prepared (supposedly a nice restaurant) than the fish itself, but it seemed a little rubbery. didn't like it at all.
    caught a bunch of trout in one of the finger lakes 30+ yrs ago while staying at a customer's lake house and I remember that being quite good.
    can't remember if we did it on the grill or pan fried. I wanna go with pan fried. but it was good.
    gotta cook fish simple. restaurants always fuk it up, trying to be fancy.
  25. Jul 21, 2024 at 2:00 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    so, I have a concern about the trailer.
    the sales guy said they are selling a leftover 'new' 2022 and 3 leftover 'new' 2023s because they are overstock. He said they ordered extra because of a hurricane in Fla, expecting them to sell more because of losses, but they never sold. now they're basically half price.
    my concern is that the one I'm looking at has the shower compartment door missing (to dry out?) and the mattress is missing.
    I'm wondering what the odds are that these trailers got wet and the dealer picked them up at an auction for pennies on the dollar.
  26. Jul 21, 2024 at 2:02 PM
    Ah, a fellow skeptic who sees the kind of scummy things that are all too common in the vehicle/RV dealer world.
    I don't have trust issues! People have issues being trustworthy!
  27. Jul 21, 2024 at 2:08 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    exactly.
  28. Jul 21, 2024 at 2:32 PM
  29. Jul 21, 2024 at 3:26 PM
    snoope
    snoope The Old Man
    There you go jinxing the rest of us...o_O
    Kids were over Wednesday for a "Pool day" , granddaughter won but the Kids would never admit that :rolleyes::rolleyes:
    Anyhow, they packed up to leave and low & behold my son grabbed an extra Rubbermaid container on the bed;:eek2:
    Guess what's in it, ??? All the F@@KI^G hardware for Connie's Hutch :annoyed::cool:
    Now we all know who is now putting it back together next weekend....
    I told him ,Lifes Lessons some times hurt...:fistbump:
  30. Jul 21, 2024 at 3:28 PM
    NWPirate
    Zach
    WA
    If it smells like shit, you know it is. Buy the newest one they have
