Tundras don't have struts
Discussion in 'Suspension' started by jberry813, Jan 13, 2017.
  1. Jan 13, 2017 at 1:35 PM
    jberry813
    jberry813 [OP] The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    The level of suspension misinformation and incorrect verbiage and nomenclature on Tundras is spreading faster than herpes at ASU. Please educate yourself.
    While they are visually similar, struts and coilovers are two very different things. The term "strut" originates from a MacPherson strut based suspension system. In a traditional MacPherson suspension, components include a lower control arm, a hub/spindle assembly, and a damper/coil assembly (known as a strut) that bolts to the top of hub at the bottom of the strut and attaches to the body or frame buckets at the top of the strut. Note...there is no frame mounted upper control arm with a MacPherson strut suspension. The strut itself is an integral part of the actual suspension pivots and steering. Struts provide vertical and lateral support. If you remove the strut, there is nothing holding the suspension together and the hub and wheels would flop all over the damn place however they see fit. Also the spindle/knuckle takes a significantly larger linear load when compared to a coilover based system as the entire weight of the vehicle is supported by the spindle. In addition, since there is only a single arm, the camber changes much more significantly as the suspension cycles up and down. This is why MacPherson strut based systems are used in vehicles with small amounts of wheel travel.
    In contrast, a coilover (coil over shock) based suspension has both upper and lower control arms/links. The UCA/LCA have outer pivots that attach to the hub and inner pivots off the frame. The coilover itself plays no role in the suspension pivot points. You can remove the entire coilover assembly, and the suspension will pivot and turn exactly as it would with the coilover installed (the truck would just be sitting on it's nuts). The only purpose a coilover serves is to dampen the suspension oscillation (the shock's role), and to set vehicle ride height (the spring's role)...that's it! The double arm geometry allows for less extreme camber change as the suspension cycles. Every single Tundra since inception came from the factory with a coilover based front suspension. Yes...you have coilovers...stock. In addition, coilover does not mean adjustable. It simply means the coil spring surrounds the shock absorber and the assembly is independent of the suspension.
    Now I realize this will probably fall on deaf ears. Typical responses are "tomato tamaato" or "you know what I'm talking about." But then again, why not sound like you actually know what the fuck you are talking about? It's not going to hurt you to sound and be more educated. Its the same contrast with firearm magazines vs. clips.
    Go forth and be educated.
    ps8820, BOSSARU, JEVE615 and 81 others like this.
  2. Jan 13, 2017 at 1:45 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good info Jason ;)
    T-Rex266 and jberry813[OP] like this.
  3. Jan 13, 2017 at 1:48 PM
    Very detailed as usual Jason. Thanks for the tech.
  4. Jan 13, 2017 at 2:21 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Nice work!
  5. Jan 13, 2017 at 2:29 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    :thumbsup: As soon as I move to Lake Tahoe, I wanna buy you a beer. :rofl:
    jbeezy, Black Wolf, T-Rex266 and 2 others like this.
  6. Jan 13, 2017 at 2:54 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    Actually I have wondered what the difference was. Definitely wasn't going to ask on the forum...all I knew was coilover sounded cooler to me than strut. Thanks for the info
    jbeezy, GODZILLA, LiftMeUp and 2 others like this.
  7. Jan 13, 2017 at 2:55 PM
    jberry813
    Lake Tahoe
    LOL. What the fuck is going on here. Some moderator tomfoolery.
    @Sean266
  8. Jan 13, 2017 at 3:00 PM
    csuviper
    Broomfield, CO
  9. Jan 13, 2017 at 3:03 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Thanks prof...
  10. Jan 13, 2017 at 3:05 PM
    jberry813
    Lake Tahoe
  11. Jan 13, 2017 at 3:24 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Corrected back to normal LT. Dan
    zcarpenter92 and jberry813[OP] like this.
  12. Jan 13, 2017 at 3:31 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Thanks Jerry :rofl:
    All good info. I don't know shit and definitely don't know what the fuck I'm talking about, but this helps me talk a little bit more intelligently on this forum. Appreciate the write up.
    mdavis and jberry813[OP] like this.
  13. Jan 13, 2017 at 3:55 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    What did I miss?:notsure:
  14. Jan 13, 2017 at 4:10 PM
    Carlos@Camburg
    Carlos@Camburg Carlos @ Camburg Vendor
    Carlos
    Huntington Beach
    2015 Tundra DC
    Camburg UCA Bilstein 6112 KMC Wheels General Tires Rigid Lights
    sure the verbage might be off a little. but if you go into a shop asking for a double wishbone suspension, you're probably gonna look like a dummy too. lol
    call em shocks, springs & a- arms. lol
    jberry813[OP] likes this.
  15. Jan 13, 2017 at 4:21 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  16. Jan 13, 2017 at 4:36 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Dang, Jberry is on a roll today. Must be stuck inside because of all the snow.
    Black Wolf likes this.
  17. Jan 13, 2017 at 4:40 PM
    jberry813
    Lake Tahoe
    Oh good lord. I hate you guys :rofl:
    I didn't make this thread (at least not here in tundras). I made it on TW and a mod did some spy shit to make it seem like I made it here too.
  18. Jan 13, 2017 at 4:41 PM
    jberry813
    Lake Tahoe
    Not at all. I've been snow bashing all over town all week in 4wd and chained up. Actually just leaving Reno from picking up truck parts and goodies.
  19. Jan 13, 2017 at 4:48 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I hereby solemnly swear to never confuse, in person or in print, a coil over with a strut, so help me lawd!
    , upload_2017-1-13_16-47-50.jpg.
    Bob_Wiley, hagrid, GODZILLA and 8 others like this.
  20. Jan 13, 2017 at 5:30 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Thanks for that write up Jason. Great having a Mad Scientist on here that knows what they're talking about and follows it up with hard facts. PLEASE don't bash your head into the keyboard, it gets kinda messy.
    aperezsh and jberry813[OP] like this.
  21. Jan 13, 2017 at 5:40 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    I keep getting shit from my buddy who has a wrangler because I keep asking him if he is going to throw some coilovers on it. Keep forgetting that it is an independent coil and shock. Suspension is confusing.
  22. Jan 13, 2017 at 5:42 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    Another thing to consider on the trucks they have no strut towers in the engine bay. On my Corolla which have struts they are mounted through the tower in the engine bay.
  23. Jan 13, 2017 at 5:49 PM
    csuviper
    Broomfield, CO
    These are def your words, and since you were just talking about it on another thread it only seemed appropriate that you write it up here too.
    jberry813[QUOTED][OP] and D1227 like this.
  24. Jan 13, 2017 at 6:08 PM
    jberry813
    Lake Tahoe
    No joke. Litterally LOL. Even spit some beer.
    No promises
    I wouldn't call it "confusing" in the traditional sense. But if it's completely new, it's drinking from a fire hose. Look, I'm a computer/software tech geek. Just ask @Bob. This truck shit is just a hobby. But math is math...and I'm good at that.
    Correct. Tundras have a frame mounted coil bucket to support the coilover :cookiemonster:
    Touche
    Bob likes this.
  25. Jul 13, 2017 at 5:33 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    I'm new to the tundra world, so go easy on me. Rams had two different suspension setups for 4x2 and 4x4, one had springs and shocks the other had struts. Is there a different setup on the tundra for 4x2 and 4x4?
  26. Jul 13, 2017 at 6:12 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Nope. It's coilovers either way.
    831Tun likes this.
  27. Jul 13, 2017 at 6:29 AM
    Redbeard321
    Good news. That means a 2wd Tundra can use bilstein 5100s? That was my biggest pet peeve of the ram 2wd.
  28. Jul 13, 2017 at 6:51 AM
    Radworker
    Radworker New Member
    AZ
    07 Tacoma DCSB 4X Sport
    Dented Bumper
  29. Jul 13, 2017 at 6:58 AM
    csuviper
    Broomfield, CO
    Yes it can.
    zcarpenter92 likes this.
  30. Oct 14, 2017 at 9:17 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Thanks for the info. Called numerous shops around me a few months ago to get a quote on new shocks. Everyone kept telling me I have struts.
