Tundra Wireless Charger
Discussion in '2.5 Gen Tundras (2014-2021)' started by DaveR2D2, Apr 20, 2025.
  1. Apr 20, 2025 at 1:24 PM
    DaveR2D2
    DaveR2D2 [OP] New Member
    2021 Tundra Limited
  2. Apr 20, 2025 at 6:50 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Is it a kit or something you pieced together on your own?
  3. Apr 20, 2025 at 6:52 PM
    DaveR2D2
    2021 Tundra Limited
    Got a charger and cable from Amazon
  4. Apr 20, 2025 at 6:55 PM
    Yota303
    Washington
    Did the charger you bought include the piece that actually holds the charger in place that mounts to the bottom of the console lid?
  5. Apr 20, 2025 at 6:56 PM
    DaveR2D2
    2021 Tundra Limited
    Yes exactly
  6. Apr 20, 2025 at 7:05 PM
    Yota303
    Washington
    Nice! Looks like a clean and easy install. How did you attach it? If you can share the actual product you used that would be great and might help others that might want to do this same mod, including myself!
  7. Apr 20, 2025 at 7:38 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You wasted your time. The plastic is still too thick to effectively charge any phone that isn’t over 5 years old. All you made was a center console warmer.
  8. Apr 20, 2025 at 7:43 PM
    DaveR2D2
    2021 Tundra Limited
  9. Apr 20, 2025 at 7:46 PM
    DaveR2D2
    2021 Tundra Limited
    Really do you know anything? the charger works up to 30mm! bros
    Trooper2 likes this.
  10. Apr 20, 2025 at 7:47 PM
    DaveR2D2
    2021 Tundra Limited
    the charger works with these phones Google phone/LG/V60/V50/V40/V30+/G8/G8s/G7/smartphones or wireless earbuds like AirPods & Galaxy Buds., Samsung S24 Ultra/S23/S22/S21/S21+/S20/S20+/Note 20/10+ /9/8/7/S10/S9/S8/S7/S6, iPhone 16 Pro Max/16 Pro/16 Plus/16 /16 Mini/iPhone 15/15 plus/15 pro/15 pro max/14/14 plus/14 pro/14 pro max/13/13 mini/12/ 12 mini/ 11/ 11 Pro/ Xs Max/XS/SE2/XR/X/8/8 Plus
  11. Apr 20, 2025 at 8:10 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Many of the oem and aftermarket chargers have been known to overheat and stop charging…..I think that’s all he was saying. I have installed 3 so far and it always stopped charging or overheated after about 10-15 minutes. Hope you have better luck
    Yota303 likes this.
  12. Apr 20, 2025 at 8:32 PM
    DaveR2D2
    2021 Tundra Limited
    it works for all my androids and iphones from 5% to fully charged daily without any issue. I do not represent any OEM or aftermarket charger vendors but do take advantage of Amazon return policy as needed.
  13. Apr 21, 2025 at 8:29 AM
    seydou
    seydou Distinguished Member
    Do these allow AA or Carplay to function fully without the cable? Or are they simply to allow for charging without a cable?
  14. Apr 21, 2025 at 8:35 AM
    DaveR2D2
    2021 Tundra Limited
    It has nothing to do with your first question. its main purpose is the latter
  15. Apr 21, 2025 at 8:47 AM
    seydou
    Gotcha. I don't understand the need/desire for wireless charging if you have to plug in the phone for full functionality, so I'll add it to the list of mods I won't spend my money on. TEHO though.
    JMGmanAZ likes this.
  16. Apr 21, 2025 at 8:55 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    This ^
  17. Apr 21, 2025 at 10:32 AM
    DaveR2D2
    2021 Tundra Limited
    Thinking outside of the box can save money
  18. Apr 21, 2025 at 10:37 AM
    seydou
    True. Thinking outside the box can also mean questioning the need or usefulness of doing something.
  19. Apr 21, 2025 at 11:26 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Cut the OP some slack. Dude has 12 posts and he is trying to be a contributing member already. Beats 12 posts about lifts, tires, and how to get 30mpg.
    Toyota sells a wireless charging insert for this space also. (I installed it in mine). So all he did was creat his own version of the same idea.
    Props for sharing OP.
    1lowlife, French Avocado, j6y and 3 others like this.
  20. Apr 21, 2025 at 11:39 AM
    seydou
    You're right. Good job on the OP for figuring out a different way of doing it.
    Yota303 and 1UP[QUOTED] like this.
  21. Apr 21, 2025 at 11:45 AM
    DaveR2D2
    2021 Tundra Limited
    Everyone has his or her opinion about anything which is what free speech is all about in America
  22. Apr 21, 2025 at 12:26 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Ive been running a similar setup in my 2016 for the last several years. It was one of the earliest mods i did right after i bought the truck.
    It has charged my last 3 Androids without issue, my BIL iPhone and any other phone capable of wireless charging.
    Nice work !
  23. Apr 21, 2025 at 1:20 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    For those like me with '20+ that have CarPlay and did a wireless CarPlay adapter, console wireless charging is flawless since you don't need no stink'n wires. That said, I still haven't installed the wireless charger yet.
    JDR76 likes this.
  24. Apr 21, 2025 at 5:38 PM
    seydou
    Is the wireless CarPlay adapter still a dongle that needs to be plugged in to the port?
  25. Apr 22, 2025 at 5:23 AM
    00h2itr
    00h2itr New Member
    Carolina's
    It does, but you stealth install it under the center console, out of sight.
  26. Apr 22, 2025 at 7:40 AM
    seydou
    How often does it lag or glitch? When I am connected to the head unit by blueooth, it can often be frustrating when on a call or streaming audio content.
  27. Apr 22, 2025 at 7:46 AM
    00h2itr
    00h2itr New Member
    Carolina's
    I don't really have many issues. Takes a few seconds to register/connect as I'm putting my seatbelt on, leaving the parking spot/driveway. So long as I don't start the truck say on a cold morning, it connect, and then I walk away and it disconnects, it's pretty dang flawless. It was one of the first mods I did, and I specifically sought out a '20+ for CarPlay knowing I'd do the wireless dongle. I've got a CarLinkIt setup.
  28. Apr 22, 2025 at 8:01 AM
    seydou
    Do you have the original head unit?
  29. Apr 22, 2025 at 8:30 AM
    00h2itr
    00h2itr New Member
    Carolina's
    Sure do
  30. Apr 23, 2025 at 8:15 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I use a dongle for wireless Apple CarPlay as well. I find that it works great and is even less glitchy than the wired connection.
    I’ve been tempted to install a wireless charger. I’d really only need it on road trips. For now, on long drives, I switch to the wired connection but it would be nice to not have to do that.
