Tundra window weatherstripping
Discussion in 'General Tundra Discussion' started by paddyboy, Sep 30, 2015.
  1. Sep 30, 2015 at 10:44 AM
    paddyboy
    paddyboy [OP] New Member
    Patrick
    '07 Tundra CrewMax Limited
    Hi All,
    New to this but wanted to share this info. I have an '07 Limited Crew Cab. My weather stripping around all 4 door windows along the bottom edge (sort of the wiping edge that rubbed against window when lowered and raised) had deteriorated away to nothing. I tried for several weeks to "specifically" identify the part numbers and a tutorial on how to install them. Got bits and pieces of info but never everything I needed to purchase and install. Seemed lots of folks had the same issue but no real/complete solutions. Lots of info I got was contradictory as well. OK, got it all now and here are the part nos. and the best news to tell you it is a "breeze" to do yourself, i.e. 10 mins per window. Roll window completely down. Just unsnap the end of the strip that has the "hard" plastic end on it (it has a clip) by gently prying it away from door edge. I carefully inserted a small rigid putty knife and just carefully pried it away. Then just slowly and gently pull the rest of the strip away from the window and out of the window channel. No biggie. Mine tore in a couple places but no issue, it all came out easily. Just re-assemble in reverse order tucking the molding piece under the section an each door post and sliding it into exactly the same position. You will also have to gently snap the entire length down into the window opening until you hear it click into the channel inside the door/window cavity. Carefully/slowly insert the clip back into the "starting point" slot until it clicks in, and you're done. Just be gentle and patient and you will get it no problem.
    Each strip was approx. $29.00 from Toyota dealer and here are the part nos.
    Left Side Front- 68210-0C020
    Left Side Rear- 68164-0C020
    Right Side Front- 68160-0C020
    Right Side Rear- 68163-0C020
    grave, deptrai, Skew12 and 9 others like this.
  2. Sep 30, 2015 at 12:05 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Thank you for the write up and part numbers.
  3. Sep 30, 2015 at 12:09 PM
    x2. Did you happen to get get any install pix of this so we can update our DIY thread with detail?
    Trpl7 likes this.
  4. Sep 30, 2015 at 12:14 PM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    Good to know this is potentially something to keep an eye out for down the road. Thanks for the info.
  5. Sep 30, 2015 at 12:58 PM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
    Pics would be nice. I don't have this problem yet, but I know eventually I will. thanks for the info.
  6. Sep 30, 2015 at 1:20 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice writeup!
  7. Sep 30, 2015 at 2:09 PM
    Welcome from CO. Great write up. Your off to a good start. What's next??
    Gatorbisquit likes this.
  8. Oct 1, 2015 at 7:42 AM
    paddyboy
    Patrick
    Sorry guys for not including pics...dumb on my part. Told you I was new at this. I will take the advice to heart for future posts.
    Law323 likes this.
  9. Jun 16, 2016 at 6:32 AM
    glewis25
    glewis25 New Member
  10. Jun 16, 2016 at 6:57 AM
    bigsapz
    bigsapz New Member
    Beast
    This was by far one of the EASIEST installs ever but, I was so intimidated initially. Lol
  11. Jun 16, 2016 at 7:01 AM
    glewis25
    glewis25 New Member
    glad the video help; the dealer wanted to charge me between $150 and $200 (it was so easy; After I installed them, I took one of them off again and made a video to share) LOL
  12. Aug 1, 2016 at 1:48 PM
    dragon_coma
    dragon_coma New Member
    Sky
    2008 CrewMax 4x2 5.7L
    Sparks has these as a package, $69 total (all 4 Windows). I was also quoted $29/ea from Toyota.
    68210-CRW is the Sparks Toyota part number, which includes all 4 PNs mentioned above.
    Blang805 likes this.
  13. Aug 1, 2016 at 2:23 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nice write up!! Welcome from South La!!
  14. Aug 1, 2016 at 6:04 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Thanks man. I had already purchased a replacement for my front driver door, but was dreading the install. Sounds like it ain't no thang.
  15. Aug 1, 2016 at 6:50 PM
    15whtrd
    15whtrd Mr. Blonde
    I did it on my wifes 08 Scion. Super easy. I noticed they looked identical to the tundra except smaller. Which led me to believe it has to be a similar install. Helps me to not worry about replacing when the time comes. I like to replace stuff before it becomes an eye sore. Thanks for the write up, video and part numbers.
    FYI you guys can get these from @Roman from Toyota of cool springs for a nice price.
    Roman likes this.
  16. Aug 1, 2016 at 7:38 PM
    I forgot to follow up. I passed along this info to one of my coworkers who had the same issue on his 07. Went to the dealer with the part#s and got everything replaced $100 and some change. He did his own install. Said it took him a 1/2 hr to do. :thumbsup::thumbsup::thumbsup::thumbsup:
  17. Aug 1, 2016 at 8:47 PM
    MichaelMPerez
    MichaelMPerez New Member
    Michael
    sealing gaps would ensure warmer feel inside and save 10 to 15 percent energy. I had 3 inch gap at bottom of my window which had me frozen the whole season
  18. Jul 15, 2018 at 6:12 AM
    FLTundraLAX
    FLTundraLAX New Member
    Michael
    2007 Tundra CrewMax Limited AT
    PaddyBoy, it’s been three years since you created this thread but thank you. Your post text, the part numbers & glewis25’s video made this easy. Spent an hour to do all four but that included scrapping off the FL sun melted weatherstripping that looked like tar on my glass. Thanks.
    NewImprovedRon likes this.
  19. Nov 28, 2018 at 11:55 PM
    dragon_coma
    Sky
    What! Wish I had known that earlier...
  20. Feb 9, 2019 at 1:37 PM
    Mr. Cade
    Mr. Cade New Member
    2014 Crewmax Platinum
    I need to replace the rubber seal that goes around the power rear windshield, on my 14' Crewmax.
    Anybody know what that part is called or where to buy it? I talked my local dealership's parts department and the guy wasn't quite sure which part to order ... Then he said the rubber seal was $221.00
    Sooooooo, FTS.
    looking elsewhere now
  21. Feb 9, 2019 at 3:04 PM
    Mr. Cade
    Mr. Cade New Member
  22. Feb 11, 2019 at 9:41 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Mr. Cade and NewImprovedRon like this.
  23. Sep 5, 2019 at 6:52 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Does anyone have part numbers for a 2005 DC SR5? Please and thanks.
  24. Sep 5, 2019 at 8:58 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Replaced these on our 07 a while back. As mentioned, really easy and worthwhile. Old ones were worthless, new ones actually functional!
  25. Sep 5, 2019 at 9:16 PM
    artsr2002
    'Yonder
    I need to replace my front drivers side. The inside surface has scratched up my window. The only ones I can find for my 2005 DC are about $100/piece. Ridiculous.
  26. Sep 6, 2019 at 7:11 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
  27. Sep 6, 2019 at 7:38 AM
    Roman
    Roman
    Franklin, TN
  28. Sep 6, 2019 at 7:41 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    :oops: dangit, thanks Roman!
    Roman[QUOTED] likes this.
  29. Sep 6, 2019 at 8:45 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    2010 DC here. Looking for both sweeps for all 4 windows.
    Anyone have a good kit or P/N they've used?
    Thanks in advance.
    @Roman
  30. Sep 6, 2019 at 9:07 AM
    Roman
    Roman
    Franklin, TN
    OBXTundra[QUOTED] likes this.
