Tundra wheel size question
Discussion in 'Wheels & Tires' started by Truckenstein, Feb 22, 2020.
  1. Feb 22, 2020 at 4:00 PM
    Truckenstein
    Truckenstein [OP] New Member
    2018 Tundra
    New to the community had a question about wheel size. Will a 18x9.5 +25mm wheel with a 305/65r18 or a 325/65r18 have any issues hitting the stock UCA? I’m getting a 3/1 lift.
  2. Feb 22, 2020 at 4:01 PM
  3. Feb 22, 2020 at 4:04 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from Western NC.
  4. Feb 22, 2020 at 4:11 PM
    Truckenstein
    2018 Tundra
    Thanks Jim. Good info. I’m more worried about the width than height the wheel 9.5” wide and doesn’t have a huge offset.
    Jim LE 1301 likes this.
  5. Feb 22, 2020 at 7:04 PM
    tdiantonio
    tdiantonio New Member
    Welcome from PA
  6. Feb 22, 2020 at 7:20 PM
    :hattip:
  7. Feb 22, 2020 at 7:22 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    I have that wheel size and offset and anything over 295 I was under the assumption new UCA would be necessary.
  8. Feb 22, 2020 at 7:35 PM
    Truckenstein
    2018 Tundra
    Highon firewood you have any pictures so I can see what yours looks like?
    HighonFirewood likes this.
  9. Feb 23, 2020 at 3:11 AM
    HighonFirewood
    2019 Tundra
    Ray10s. 18x9 +25. Planning a 3/1.5 lift with new UCAs and moving up from 33’s to 35’s.
    French Avocado likes this.
  10. Feb 23, 2020 at 3:19 AM
    HighonFirewood
    2019 Tundra
    Ray10s. 18x9 +25. Planning a 3/1.5 lift with new UCAs and moving up from 33’s to 35’s. Your planned tire size can be achieved with 275/70r18s. I have these on stock suspension and they are 33.2”. 305/65r18 is 33.6”.
    I’m looking to move up to 295/75r18. 35.1”
  11. Dec 9, 2020 at 9:16 PM
    Kmaiboy
    Kmaiboy New Member
    2018 White TRD Sport CM
    what tire size are you running in picture with no lift?
  12. Dec 9, 2020 at 9:32 PM
    HighonFirewood
    2019 Tundra
    275/70/18 Nitto RGs.
    Kmaiboy[QUOTED] likes this.
  13. Dec 10, 2020 at 8:40 PM
    Kmaiboy
    Kmaiboy New Member
    Any rubbing?
    I'm stock height and have 18x9 +20 wheels and thinking about doing 285/65/18 but scared it will rub and don't really want to trim.
  14. Dec 11, 2020 at 6:02 AM
    HighonFirewood
    2019 Tundra
    No rubbing. I have +25 offset. I think you may rub with the wider profile of that tire. 275/70/18 is 33 inch height with less then 11 width. The 285/65/18 is less than 33 (32.5 maybe?) and over 11 width increasing the odds of a rub on full lock
