Tundra weight distribution
Discussion in '2.5 Gen Tundras (2014-2021)' started by Henry2019, Aug 12, 2020.
  1. Aug 12, 2020 at 5:19 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    I have noticed that my front tire makes more contact with the ground since it has more weight than the rear of truck. If thats the case should i air my tires more in the front and less in the rear to compensate for the weight distribution? I don’t tow nor have payload and just do daily commuting.
    thanks
  2. Aug 12, 2020 at 5:40 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    There’s a sticker on the inside of the driver’s side door that tells you the psi for front and rear.
    BravoDeltaRomeo likes this.
  3. Aug 12, 2020 at 5:48 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    Sticker says to run 3 PSI higher in the rear which doesn’t make sense to me since i daily commute with no payload.
  4. Aug 12, 2020 at 5:50 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    30 psi is a joke for the front tires. Your handling will suck and they wont wear properly.
    i have stock tires as well and run the fronts at Around 40 front about 36 rear. Much more optimimal.
    The factory tire recommendations are for a loaded bed, not daily driving.
  5. Aug 12, 2020 at 7:42 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Isn't that why you rotate the tires every 6 months or 5000 miles?
    BravoDeltaRomeo and Ruggybuggy like this.
  6. Aug 12, 2020 at 8:13 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Do a chalk test to get the correct psi for your particular tires & weight. Yes, you’ll have more psi in front than back. YouTube for psi chalk test.
    I have 37 inch ridge grapplers and am sittin pretty at 36 in front and 30 in rear. It’ll be different once winter hits, so you’ll want to chalk test again when it gets cold & air up accordingly.
    Cpl_Punishment and HulkSmurf14 like this.
  7. Aug 15, 2020 at 11:31 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    I believe in the rotations yes but at the same time i feel like wearing the tires evenly just on air alone is more optimal for longevity.
