Tundra trd pro front end metal / frame squeek
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Jjames80, May 6, 2018.
  1. May 6, 2018 at 7:28 PM
    Jjames80
    Jjames80 [OP] New Member
    Joe
    2015 tundra trd pro
    , ko2 tires, air suspension, focal speakers alpine sub And amp, road armor bumpers, sheepskin seat covers
    After checking all the obvious bushings and front end parts. If there is a distinct metal to metal cranking or squeeking remove the skid plate. It takes a 12mm, 15mm, 18mm and a hex head. There will be no more noise. Here is how I fixed it.
    1. Remove skid plate
    2. Clean skid plate
    3. Buy some nylon washers and silicone them where the bolts go so that the new washer is the only thing touching the frame
    4. Reinstall skid plate using loctite on all the bolts and the two nuts at rear
    5. Noise is eliminated.
    Email joecjames@verizon.net if you want pictures. Toward the rear of skid plate there were about (5) places that were rubbing metal to metal making the stressed noise.
    GarTX526, HelenaTRDPro and Kilos like this.
  2. May 6, 2018 at 7:31 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Nice job! You can post pics on here so it can be referenced in the future. The Pro skids are known to squeak and pop like crazy.
    Welcome btw!!
  3. May 6, 2018 at 7:54 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME!
  4. May 6, 2018 at 8:38 PM
    Welcome from Texas
  5. Jun 24, 2018 at 6:23 PM
    LKN Yota
    LKN Yota New Member
    07 WHITE TUNDRA SR5 TRD, 15 TUNDRA PRO CrewMax
    Good Idea, Thanks
  6. Mar 10, 2019 at 10:46 PM
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    Pertains to 18-19 models also?
  7. Apr 17, 2019 at 1:11 AM
    Andrew19
    Andrew19 New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    I hear some popping noises close to the front end when I brake hard. Could that be the skid plate
    mzim likes this.
  8. Aug 12, 2019 at 7:11 PM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    I have this also. While backing out of garage when i brake harder, pop! Then if i do it again going back it stops when braking. If i Then go fwd and brake, it resets it to pop in reverse when braking harder again.
