Tundra to Sequoia sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by T_dublecab14, Jun 7, 2017.
  1. Jun 7, 2017 at 7:16 AM
    T_dublecab14
    T_dublecab14 [OP] New Member
    RC
    2014 doublecab 4x4
    TRD
    Has anybody done the mod from tundra sway bar or stabilizer bar to sequoia? Is it direct fit, is it the long bar only or does the whole system need to be replaced???
  2. Jun 7, 2017 at 7:54 AM
    Bob likes this.
  3. Jun 7, 2017 at 8:07 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Yep I did it. You don't need any other parts except the sway bar itself. The OD and all the dimensions of the sway bar is the same as the Tundra. The only difference is the ID of it is smaller so the sway bar is thicker/heavier. It's direct bolt in.
    NewImprovedRon and T-Rex266 like this.
  4. Jun 7, 2017 at 8:08 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yes, I've done it as well. It's just the bar, you reuse the fastening hardware, bushings (unless you want to upgrade them) and the links.
    T-Rex266 likes this.
  5. Jun 7, 2017 at 9:00 AM
    Mannishboy
    Mannishboy New Member
    Indianapolis, IN
    2015 DC 4x4 Limited, Blue Ribbon Metallic.
    TRD exhaust, TRD cai, TRD rear sway bar, TRD shift knob, Sequoia front sway bar, bed extender, bed step, Weathertech floor mats and window vents, spray in bed liner, Morimoto fogs, Access tonneau bed cover.
    I'm thinking of doing this as well. Does it make a noticeable difference?
  6. Jun 7, 2017 at 9:07 AM
    jberry813
    Lake Tahoe
    I give it a solid "meh" rating.
    The TRD rear makes WAY more of a difference. But for a truck that's lifted 3" and on 35's, my truck handles like it's on rails.
    NewImprovedRon likes this.
  7. Jun 7, 2017 at 9:10 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Direct fit, should cost you about $115 to 130 at your local dealer. Great thing to swap and in conjunction with the TRD rear bar your truck will be well behaved.
    T_dublecab14[OP] likes this.
  8. Jun 7, 2017 at 9:22 AM
    Mannishboy
    Indianapolis, IN
    Yeah, I did the TRD rear sway, and it made a huge difference. I don't plan on lifting my truck. I was just wondering if adding the sequoia bar is worth it for strictly highway driving.
  9. Jun 8, 2017 at 7:08 AM
    T_dublecab14
    RC
    2014 doublecab 4x4
    TRD
    Thx for the input guys that really helps!!
  10. Jun 12, 2017 at 9:46 AM
    T_dublecab14
    RC
    2014 doublecab 4x4
    TRD
    don't know where you're at but I just priced them here in Houston area $175-185!
  11. Jul 27, 2017 at 6:11 PM
    Mannishboy
    Indianapolis, IN
    Just swapped out the front sway bar with the Sequioa sway bar about 3 days ago. There IS a noticible difference. Granted, I have the TRD rear sway, and I'm not lifted, and running stock tires on 20 inch rims. My truck is destined for pavement only. But on my commute, i take a sharp 30 degree turn every day and that's where i notice it the most. Almost no roll at all. The truck handles much better, especially on turns from a stop. Well worth it imo.
    Wynnded likes this.
  12. Jul 27, 2017 at 7:12 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Hit up @Roman I think he can set you up with one for around $125 if I remember right. I found a guy that bought one for his truck. Never installed it because he decided to go with a long travel setup. He sold to me for $70.00. It does make a difference, especially on the mountain roads I drive.
    Roman likes this.
  13. Jul 27, 2017 at 8:08 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Pretty much the same scenario for my truck. It's brilliant handling in the twisties, for the truck it is.
    Tiamat likes this.
  14. Aug 13, 2017 at 5:11 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Big time difference. Especially when install the trd sway bar. There is a reason on the 2018 is coming with front and rear trd swaybars.
    ChavoB likes this.
