Tundra thread last resort
Discussion in 'Performance and Tuning' started by Tonytlr1000, Jun 17, 2017.
  1. Jun 17, 2017 at 4:11 PM
    Tonytlr1000
    Tonytlr1000 [OP] New Member
    Tony
    13 Tundra SC
    TRD Supercharger, Unichip, Magnaflow
    ok this is my last resort. I've been to 2 Toyota Dealerships, 2 tune shops and every internet page I could find to give me a solution for my Tundra.
    I have a 2013 Tundra Flex Fuel 4x4 that I've been running a TRD Supercharger/Unichip combo since day one. The SC was put on by a Toy mech but not the dealership. The truck has run amazing for the last 38k miles but in the last month the truck is now throwing P1072 & P1075 codes which indicate that it is running too rich in Bank 1 & Bank 2.
    Took it to the dealership which they found the alcohol level was up to 30%. They told me they had to reprogram the truck and off I went. It lasted 15 miles until the dash board lit up like a fireworks show. The dealership said it must be the Unichip causing it so call them. I contacted Unichip which they said no way it's their chip. They said that if their chip was malfunctioning that my truck wouldnt even run.
    I then went to a couple tune shops and they all didn't want the job due to the truck being a Flex Fuel.
    I've changed the filter, I've replaced the Mass Air Flow Sensor, replaced both upstream Oxygen sensors with OEM new sensors, ran a full tank of fuel injector cleaner, checked for vaccum leaks, I only use 91 octane fuel.
    I clear the codes and within 10 miles they come back again. I am completely out of ideas. I am hoping that somebody has that one solution that will do the trick.
    I really don't want to take off the SC. Help!
  2. Jun 17, 2017 at 4:18 PM
  3. Jun 17, 2017 at 4:22 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    This is why u don't sc a flex fuel truck...
    But since u did. Now you have to deal with the headache of making everything run correctly. I'm wondering after the dealer reflashed the ecu, if it doesn't want to play nicely with the uni chip now...
    It's still only throwing those two codes? Which btw those codes aren't correct. P0###....
    Law323 and T-Rex266 like this.
  4. Jun 17, 2017 at 4:31 PM
    Tonytlr1000
    Tony
    13 Tundra SC
    Oh,
    the correct codes are P0172 & P0175.
    I agree Flex Fuel was a mistake but was told it was a good option to put on a SC because of the large fuel lines and fuel pump that could handle the SC.
  5. Jun 17, 2017 at 4:33 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome to the forum; sorry had to be this way tho.
  6. Jun 17, 2017 at 4:35 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Who ever told u that isn't very bright...
    U need to find out what your alcohol density is reading. And what your fuel trims are
    T-Rex266 likes this.
  7. Jun 17, 2017 at 5:21 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    i gotta admit... i'm not sure i like the response from unichip. that aside...
    What lights are showing since the dealership visit and what codes are being thrown? my guess is that the immediate problem may be unrelated to the original rich banks codes....
  8. Jun 17, 2017 at 11:09 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Give me a call. I can send a solution that will correct this problem.
    760-877-4234
    HARPER306, Harris1881, DVYota and 5 others like this.
  9. Jun 18, 2017 at 9:00 AM
    Tonytlr1000
    Tony
    13 Tundra SC
    Kieth I'll give you a call next week since I am in Mexico!
    Thanks for the reply.
    The 4Lo light is flashing, engine light, trac light, slip light are all steady.
  10. Jun 18, 2017 at 9:39 AM
  11. Sep 6, 2018 at 5:46 PM
    Vpempek
    Vpempek New Member
    Did u ever get it fixed having the same thing going on
  12. Apr 5, 2019 at 3:28 PM
    frogger
    frogger just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
    bump
    having same code after installing my s/c
  13. Jun 9, 2020 at 8:34 PM
    SaulofTarsis
    SaulofTarsis New Member
    2012 Tundra
    Any solution?? Im having exact same coded/probkem and lights. Also flex fuel.
